Kenwood 5140 + SWI-JACK - installed w/custom Metra kit - QUESTIONS & PICS
Discussion in 'Audio & Video' started by netmagi, Jan 7, 2010.
  1. Jan 7, 2010 at 7:11 AM
    netmagi
    netmagi [OP] Membrrrrrr
    Slatington, PA
    09 TRD OR
    Last night I replaced my much "lesser" aftermarket HU with a Kenwood 5140 and integrated a PAC SWI-JACK to get back my steering wheel controls.
    It took 4+ hours! Admittedly, I'm very detail-oriented and particular when doing this kind of work. I soldered/heat-shrunk all connections, and used bullet connectors wherever I spliced into factory wiring for the SWI-JACK. It would have probably been ~1.5 hours if I just threw it all together :)
    I purchased the Metra dash kit, but was really displeased with out-of-the-box quality. They hadn't done a good job of trimming off the excess plastic after molding it, and the paint seemed light in the upper left hand corner area. I also didn't really like the silver color. It's not an exact match to any of the silver already in the truck, and I'm not a big fan of silver to begin with. So, I trimmed the excess plastic they missed, and picked up a can of charcoal colored spray paint with a slight texture to it, and re-sprayed. I'd prefer if the color was a little darker, but it looks 5x better than the silver in my opinion.
    Overall, the 5140 is great, but I do have a few problems:
    1) It "wobbles" a bit when i hit bumps on the road, etc. I'm 100% positive everything is tight, but the Toyota metal brackets are just too thin.
    2) There is lag when using the steering wheel audio controls. It's about half a second, but it means it's very difficult to flip through tracks quickly, or make small adjustments to the volume. The controls all consistently work, they just all consistently lag, which is annoying :)
    3) The volume on the 5140 cannot be adjusted while it's "busy" doing other stuff, like loading the full interface for playing MP3's, or reading ID3 tags. This is frustrating since, everytime you change a track if you're playing mp3's from a USB stick, it reads the ID3 tag for song info and album art. This means you can't adjust the volume for the first 3-10 seconds of the song. If the song is too loud when it first starts playing, you can sit there turning the knob until you're blue in the face, it won't adjust the volume until it finishes reading all the tag info.
    I'm curious to hear if anyone/everyone else is having any of these problems, and if you've done anything to resolve. I'm guessing 2 and 3, are just normal and I'll need to live with them, but the wobble will drive me crazy. . The roads in Northeast PA are all bumpy :)
    -Rich
  2. Jan 7, 2010 at 7:16 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Does the swi jack illuminate the steering wheel controls?
    Is it worth it, with the lag?
    I'm thinking about getting one. I lost that functionality when I upgraded my HU.
    Thanks,
  3. Jan 7, 2010 at 7:19 AM
    netmagi
    Slatington, PA
    09 TRD OR
    Yes, my controls are illuminated when headlights are turned on, and yes I'd say it's still worth it. I programmed the button-most button on the steering wheel controls to mute the audio, which alone is almost worth the cost of the whole SWI-JACK to me. . I really need to be able to quickly mute it to answer calls, etc.
  4. Jan 7, 2010 at 7:20 AM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Nice and Clean, good work. I was disssatisfied with the Metra as well, seemed chincy. Currently looking for replacement.
  5. Jan 7, 2010 at 7:28 AM
    IrishPilot
    IrishPilot Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    Great tune ;)
  6. Jan 7, 2010 at 7:36 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    1. mine too but be glad you dont have the schoche kit, it sucks in comparison to the metra
    2. you get used to the lag, my lag seems to be miliseconds though (i have the 5120 though)
    3. I dont have this problem, My 5120 reads my ipod seamlessly. I have never read from a thumb drive though to know if there is a diff.
  7. Jan 7, 2010 at 8:46 AM
    P-Dub
    P-Dub Well-Known Member
    Paul
    SF Bay Area
    06 Blue 4x4 TRD Sport DC LB
    TRD skid plate, OEM roof rack, OEM running boards, TruckCovers USA rolling tonneau cover, 3000K HID Foglights
    Looks great! Almost exactly like mine but I've got the 512 only. You should of just got the black Metra dash kit, I'm also not a fan of silver in the truck so I went with the black install kit. I should of just used the mode button for the mute too instead of using it for the source select, not really helpful if you have to go through 15 sources just to jump from DVD/CD to the tuner.
  8. Jan 7, 2010 at 11:26 AM
    lost1700
    lost1700 Well-Known Member
    Blake
    Florida
    2010 DC PreRunner
    At first I thought my Scosche sucked but now that I have had it in a couple of weeks it isn't that bad. My head unit sits in there solid despite the cheesy plastic brackets. The color match is a little off but I hardly notice it anymore.
  9. Jan 7, 2010 at 1:38 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    I had a sosche kit. It sucked. The place brakets to hold the HU in place doesn't offer any security at all.. if somone want your HU they just have to rip it out. My Metra kit doesn't wiggle or wabble or move. The quality is much better the sosche and if someone wants my head unit, they have to unbolt it from the truck.
    If you don't like the metra kit, then you won't be happy with any kit.
  10. Jan 7, 2010 at 1:43 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Zero complaints or issues with the Scosche kit. Using the DNX -512.
  11. Jan 7, 2010 at 7:36 PM
    azTRD
    azTRD Well-Known Member
    When I first installed my scosche dash kit I thought it was flimsy with the plastic brackets after I finished installing it... but after messing with it for a bit, I realized that I didn't install it correctly (I didn't clip the front trim piece into the side brackets). After installing this kit correctly, it snapped in and was totally SOLID before I even put the bolts back in.
    I know a lot of people bash Scosche on this forum, but if you install the kit correctly... it is a solid kit for double din stereos.
    The biggest downside is that the color doesn't quite match.
  12. Jan 8, 2010 at 5:35 AM
    Dark Knight
    Jeff
    NC/SC
    mine is installed correctly. I didnt mean to bash on the scoche kit IMHO I thought the scoche kit was not made as well as the metra after having worked with both on a couple occasions. I do get a little wiggle with mine but nothing to worry about.
  13. Jan 8, 2010 at 5:42 AM
    Jigzor
    Pennsylvania
    The plastic brackets had me worried at first but it hasn't been an issue. The metra kit allows for the use of oem metal brackets right?
  14. Jan 8, 2010 at 12:42 PM
    CRFan1
    CRFan1 Well-Known Member
    Northwest Indiana
    Tacoma Pre-Runner
    DNX5120, Audsion AMp, Hertz Speakers
    I have a 5120 and mine has zero movement...not sure which dash kit as I had an installer do it. ANd yes, my steering wheel controls have about a .5 sec delay. Better than not having it. You get used to it. Nice install:)
  15. Jan 8, 2010 at 12:56 PM
    05TRD4WD
    05TRD4WD Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
    i have the same setup and mine doesnt move at all
