Kerosene Seafoam
Discussion in 'Performance and Tuning' started by Buffalofan, May 4, 2008.
  1. May 4, 2008 at 4:06 PM
    Buffalofan
    Buffalofan [OP] Well-Known Member
    Chicago
    2001 Tacoma V6 SR5 TRD Package Lunar Mist
    I was at Advanced Auto Parts today and they guy told me about Kerosene Seafoam and that he uses it every third oil change. He said to pour it into the engine oil and run the truck for 10 minutes before performing the oil change.
    He said if you have never done it before you will probably see a whole bunch of gunk come out. He did not recommend it for engines with 100+ k miles because the gunk could actully be keeping the seals together and by removing it, it would cause a huge problem.
    My 2001 Taco only has 67,000 miles on it. I use Mobile 1 Full Synthetic and change my oil every 3k, so I was thinking of trying it.
    Any of you engineers out ther have an pros or cons for me?
  2. May 4, 2008 at 4:10 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Are you sure it's called Kerosene SeaFoam? Does it look like the bottle below? I've used it many times in all of my cars and it's great stuff.
  3. May 4, 2008 at 4:14 PM
    Buffalofan
    Chicago
    I did not see what it was but they guy called it SeaFoam (wasn't sure how he was spelling it) but said it was a kerosene based product.
    So you have not had any issues? I get nervous putting stuff in my cars without getting a good word from people.
    Thanks for the good word.
  4. May 4, 2008 at 4:26 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  5. May 5, 2008 at 5:19 AM
    Buffalofan
    Chicago
    I checked out the video and pics from one of the links you sent me. I can't believe the smoke you get. I can just hear my neighbors complain, as our home are packed as close as sardines in a can.
  6. May 5, 2008 at 9:37 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yeah, the smoke is the crap being burned off from the inside.
  7. May 6, 2008 at 7:34 AM
    Budisweiser
    Budisweiser Member
    fort scott, kansas
    2008 tacoma 4x4 DC off road.
    This is truely great stuff. I use it in all my vehicles as a fuel stabilizer and decarber. Lawnmower, motorcycle, bass boat. I didn't even winterize my boat this year (kansas) just used the seafoam in the tank/fuel system when storing. She fired right up this year....
  8. May 6, 2008 at 8:56 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    Sounds kinda like Marvel Mystery Oil which I have used in the past in other vehicles and have friends that still use it in their tanks today
  9. May 6, 2008 at 4:34 PM
    Buffalofan
    Chicago
    So the Advanced Auto Parts guy said the day I am doing the oil change to pour the whole bottle into the engine oil and run the care for 10-20 minutes, then change the oil as usual.
    Does this sound right?..as I do not want to damange anything.
  10. May 6, 2008 at 4:41 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I wouldn't put the whole bottle, just follow what's on the can.
  11. May 6, 2008 at 4:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i wouldnt add the entire bottle......just go by the instructions, use half the bottle thre your brake booster line, a 3rd in your oil, then a third in the gas tank, run for a while, then change your oil.
  12. May 6, 2008 at 4:45 PM
    MurphMan
    MurphMan Senility Rocks!
    Murph
    Maine
    '08 Tacoma TRD Sport
    * AFE Stage 2 XP CAI System * Westin Platinum Series Black Step Bars * TruXedo Lo Pro QT Soft Roll-Up Tonneau * Dee Zee Heavyweight Truck Bed Mat * WeatherTech Extreme-Duty Floor Liners * WeatherTech In-Channel Window Visors * Sony Xplod CDX-GT81UW Receiver * Sony Xplod 2-way speakers * Boss Audio BASS600 Amplified Subwoofer * Billet Grille Mod
    Jeez no! Half a can at the most. Idle for about 5 mins. Throw a full can into the gas tank and top it off. Great for cleaning out the fuel system.
  13. May 6, 2008 at 4:50 PM
    Buffalofan
    Chicago
    I am not very hands on with truck/car stuff. I can just do the regular maintenance stuff. I get nervous when I read about slowly adding it the brake booster or a vacuum line, hell I don't even know where those are at anyway...I am not sure how to add it slowly to a tube anyway.
    Would I be able to get away with just adding it to the engine oil and gas tank?
  14. May 6, 2008 at 4:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    oh yeah, you can do that. its really easy to add it to the brake booster line though.....under hood driver side, big round thing with a hose going to it(hose goes to the intake), just pull the hose off and stick the hose a litle into the can of seafoam. the truck will try to cut off......pull hose back a bit, then repeat till half the can is gone. let it sit for a few minutes, then crank her up and get ready to dessimate mosquitos:D. when you crank it back up.....rev it a bit, you will clean all that carbon build up from the intake and all.
  15. May 6, 2008 at 5:01 PM
    Buffalofan
    Chicago
    Sounds easy enough, but one more question...do I the brake booster first and add the rest to the engine oil and gas tank or vice versa?
    I really appreciate all you help and advice!!
  16. May 6, 2008 at 5:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....i usually go for the brake booster line first, half a can, then add the rest to the gas tank. i never add it to my oil(i run synthetic, so i dont really need it in there).....but you should have no problems putting some in your oil.......just be sure to change your oil and filter soon after doing so, and i'd probably go ahead and change the fuel filter too.....if you havent done it in a while.
  17. May 6, 2008 at 5:12 PM
    Buffalofan
    Chicago
    I have run synthetic for the life of the truck , maybe i don't need to add it to the oil either.
    If you don't add it to you oil do then I imagine you can do this procedure anyting without having to change the oil.
  18. May 6, 2008 at 5:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, not really, cause its cleaning your intake, thus a small amount will end up in your oil. if you have been running synthetic for the life of your truck.....i would say there is no need to add it to the oil. just my thoughts though.
  19. May 6, 2008 at 8:28 PM
    Buffalofan
    Chicago
    Heres a stupid question, when you finish putting in half the can do you reconnect the brake booster line and let it sit until you crank her up again?
  20. May 7, 2008 at 2:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, as soon as you get half the bottle in thru the brake booster line....go ahead and reconnect the line.
