Key cylinder replaced with generic.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JGR, Apr 18, 2021.
  1. Apr 18, 2021 at 6:12 AM
    JGR
    JGR [OP] New Member
    2005,4door, 4X4
    Flat bed
    Key cylinder locked up, replaced with generic from parts house. Now it will turn over, but won't start. Any suggestions?
  2. Apr 18, 2021 at 6:18 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Transponder isn't programmed.
  3. Apr 18, 2021 at 7:03 AM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
  4. Apr 18, 2021 at 9:42 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Take your old cylinder to a locksmith and have them rebuild it for around 50 bucks. Until then, take your old key and place it near the key slot before you try and start it.
    69L46Vert likes this.
  5. Apr 19, 2021 at 10:34 AM
    JGR
    JGR [OP] New Member
    2005,4door, 4X4
    Flat bed
    Thanks will try transponder bypass box, cylinder came out in pieces.
  6. Apr 19, 2021 at 11:18 AM
    Larzzzz
    Larry
    MA
    Ooooooook then.
    Good luck
  7. Apr 20, 2021 at 8:46 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Take the new lock cylinder to a locksmith to have it rekeyed to your old keys, or have your truck programmed to the new keys that came with the new lock cylinder.
    Jeff
