Key Reprogramming/Programming Original Keys
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmoney92, Dec 1, 2014.
  1. Dec 1, 2014 at 7:53 AM
    gmoney92
    gmoney92 [OP] Member
    Tampa
    '14 TRD Sport
    I recently had to get a Locksmith to come to the airport and make me a Key for my car on the stop. The key he made works but now my old keys don't work anymore.
    Is there a way to get my old keys working again? Anyway to reset the car key memory or anything on that sort?
    Thanks in advance!
    TheManSpider likes this.
  2. Dec 1, 2014 at 11:29 AM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Yes. All keys and fobs must be inside the car while the programming is done.
    Look up a TW member neneago to get the programming instructions, and if you'd like an all-in-one key with the fob chip inside. I got one for my Tacoma and another for my wife's Element. two cars with two keys and two fobs was took much junk in my pocket!
  3. Dec 1, 2014 at 1:32 PM
    SprtBkr
    SprtBkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 5.7L Double Cab 4x4 Inferno
    On a '14 TRD Sport, I believe you have to use Toyota Techstream via the OBDII port, unless that locksmith is trying to copy the chip in your key.
    Is there a G stamped in the metal of the key? Mine has the G, and I couldn't find a locksmith to do it, so I ended up buying an OBD Cable and Techstream CD from an ebay seller to program mine. I refused to pay the dealer $100 to do it for me.
    I'd ask the locksmith what they did.
  4. Dec 1, 2014 at 2:00 PM
    SprtBkr
    Scott
    Denver, CO
    I've never heard this information before. It doesn't sound right. You program keys and fobs one at a time. Unless you intentionally wipe the memory, you don't automatically lose what's already paired with your vehicle.
    Here is a write-up I put together about programming the keys and the remotes.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/350507-how-program-new-key-remote-2014-tacoma.html
  5. Dec 1, 2014 at 4:07 PM
    wanna taco
    alan
    SF Bay Area
    nenenago did use a techstream for my new key, but he cautiioned that all keys must be in the car at the same time. I'm so tech challenged that I took my tacoma to the guy and just watched him, not wanting to screw up all my keys and fobs :notsure: Any further explanation on this should come from neneago himself, all I know is he did good for me! :D
  6. Dec 1, 2014 at 8:22 PM
    gmoney92
    Tampa
    '14 TRD Sport
    The locksmith said that he didn't wipe out the memory and my old keys should work. But when I turn the key the car just makes an attempt to start but it doesn't actually get to start.
    I called the dealer and they wanted $105 to program the keys and a local locksmith wants $89. I feel like that is too much money but I might have to pay it.
  7. Dec 1, 2014 at 8:23 PM
    gmoney92
    Tampa
    '14 TRD Sport
    My new key and my old keys do have a 'G' on them.
  8. Dec 1, 2014 at 9:38 PM
    wanna taco
    alan
    SF Bay Area
    nenenago did the programming thing on the new key I bought, then while still connected to the tech stream, he put each key in the ignition and started the truck. At the time, I thought that was just to confirm, but apparently, it was needed. Get hold of the guy, I know he can advise you on getiing your keys working, and you might just decide on an all-in-one key, which would cost less than another locksmith to program your old keys! :D
  9. Dec 2, 2014 at 6:42 PM
    neneago
    neneago Well-Known Member
    Sugar Land, Texas
    Had you lost your key and thats why the locksmith came to the airport to help you out?
  10. Dec 2, 2014 at 6:50 PM
    neneago
    Sugar Land, Texas
    Heres how the Toyota Immobilizer ECU(transponder chip computer) Works.
    To add keys, You must insert a programmed MASTER key first. This allows the car to go into programming mode by using locksmith computer or the dealer computer. If no keys are present or a valet key is present...The Immo ECU must be reset. By resetting, ALL keys are erased and the first key inserted after the reset becomes the Master.
    So, it's impossible he could erased your keys UNLESS he did a reset. By doing a reset, he knows all keys will be erased. So if this is the case....you got scammed.
  11. Dec 2, 2014 at 7:00 PM
    wanna taco
    alan
    SF Bay Area
    Hey! I figured you'd show up here sooner or later! Just puttin' in a plug for ya!
  12. Dec 3, 2014 at 12:52 AM
    Bravo1
    Bravo1 Member
    Rear spring TSB, tailgate lock, 5100s at 1.75
    I just purchased one of the "all-in-one" keys from neneago but mine has the dot on it instead of the G. The vehicle is a 2010 Tacoma DCSB. The dealer wants $89 to program it and I thought that was a bit steep.
    I'm going to check with some locksmiths in the area but is the Techstream and OBDII concept a better route? It looks a lot cheaper!
  13. Dec 3, 2014 at 6:36 AM
    SprtBkr
    Scott
    Denver, CO
    My dealer quoted me $55 and a local locksmith quoted me $95. The Techstream and OBDII is cheaper, and it's the method the dealer uses. Not sure what aftermarket options are available for locksmiths. Oh, and my key was a G chip on a 2014, so it might be different for a Dot on a 2010. I'd be curious to hear what you find out. I used this method to program 2 keys from neneago.
  14. Dec 3, 2014 at 2:34 PM
    gmoney92
    Tampa
    '14 TRD Sport
    I had no choice as I had to get a key to drive home as I was stuck in an airport 3.5 hrs away from my house. I had no way to get in the house to get my spare so I had to get the key made in the spot.
    I was wondering if I called ToyoCare and told them I lost my key if they would tell me they would tow me to the nearest dealer or if they would send a locksmith to make me a new key.
  15. Dec 3, 2014 at 2:38 PM
    gmoney92
    Tampa
    '14 TRD Sport
    Also, I called my insurance(geico) and they told me that they would reimburse me up to $100 dollars for the locksmith service. They also said if I would have called me them and they would have called a locksmith in their network it do it would have been a lot cheaper.
    This is how my idea of calling Toyocare came up. I would like to see what Toyocare would be able to help me out with.
  16. Dec 3, 2014 at 2:46 PM
    neneago
    Sugar Land, Texas
    Gmoney.... When you are driving now..Is the immobilizer light on? Hopefully it is. This mean the car is in auto registration mode.
  17. Dec 3, 2014 at 2:58 PM
    gmoney92
    Tampa
    '14 TRD Sport
    I have not payed attention to that. What does "auto registration" mean?
  18. Dec 3, 2014 at 3:02 PM
    neneago
    Sugar Land, Texas
    It means you can add your keys that are at home. The light must be ON while driving and the light should also stay on when the car is turned off.
  19. Dec 8, 2014 at 6:08 PM
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    Do you have a link for the product?
  20. Dec 8, 2014 at 8:41 PM
    SprtBkr
    Scott
    Denver, CO
    EBay and Amazon links rarely stay good for long. Search for a Mini VCI 16 Pin OBDII Cable Cars Diagnostic Scanner For TOYOTA Techstream w/ CD from ebay.com or Amazon.com for around $25.
