Keyless Entry For 2016 2017 Tacoma SR SR5
Discussion in '3rd Gen. Tacomas (2016+)' started by HarlanBFlorida, Oct 26, 2017.
  1. Jun 5, 2018 at 12:25 PM
    dxlusby84
    dxlusby84 Member
    I can answer the first question: the key is still required. The kit adds a separate fob with lock, unlock, and panic buttons.
    Hopefully someone else more familiar with aftermarket part button start can answer your other question
    facefirst likes this.
  2. Jun 6, 2018 at 4:44 PM
    jbrady33
    jbrady33 New Member
    Maryland
    07 Prerunner SR5
    Hi All,
    I can confirm that 2018 Tacoma SR is the same directions, the original poster has tem in color which is very helpful.
    one weird issue - Lock works perfect, unlock take 3 clicks and both doors unlock at the same time. Anyone else see this?
    PS: Parking lights do not flash if you leave it in "daytime running lights" that is included in the doc/instructions
  3. Jun 7, 2018 at 10:49 AM
    jbrady33
    jbrady33 New Member
    Maryland
    07 Prerunner SR5
    Another item, it appears several Toyota dealers are selling the on eBay, same exact item.
    Mine came from Daytona Toyota - you might want to start away from then. Emailed multiple times with no response (it's been a week)
  4. Jun 7, 2018 at 10:58 AM
    dxlusby84
    dxlusby84 Member
    I emailed McDonough and they were very responsive and shipping was fast. Should be getting my kit tomorrow :D
  5. Aug 16, 2018 at 6:12 PM
    chasetaco
    chasetaco Member
    Chase
    Pensacola, FL
    2016 Toyota Tacoma Double Cab SR
    Does anyone have a link to a video on how to install this?
  6. Sep 9, 2018 at 7:26 PM
    quintara2001
    quintara2001 Member
    yes let me know if someone can post pics of the wiring harnesses and what they did my connectors do not match the instructions (2018 Tacoma SR with power locks)
  7. Oct 27, 2018 at 11:32 PM
    Blackwolf65499
    Blackwolf65499 New Member
    Forrest
    2018 Sliver Tacoma SR
    I’m curious if this will work with my 2018 sr crew cab. It was a rental before I bought it. So it has most of the continence package besides keyless. I read on the website that it doesn’t work if you have the TDS system. How do I go about finding that out??
  8. Nov 11, 2018 at 2:24 PM
    schultzj01
    schultzj01 Well-Known Member
    San Diego
    2017 DCSB SR 4x4 MGM
    Anyone have luck with programming an additional remote? Took mine for a swim....
  9. Dec 21, 2018 at 6:02 PM
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    Thank You VERY MUCH for posting this very hard to find information. I am going to install an EBAY aftermarket keyless entry unit in my new 2019 SR and hopefully these connectors are the same.
  10. Dec 27, 2018 at 2:57 PM
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    I am going to get a quote from the dealer to do this job, I will let you guys know, maybe someone did already?
  11. Dec 27, 2018 at 5:45 PM
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    I received a quote from a local shop that does alarms and radio upgrades as well as keyless entry and remote start installs. They quoted me $169 for keyless or $199 to add keyless access and an alarm system. Parts and labor included. The equipment would be compustar brand so I guess you could look that up and find local installers. I actually put in a system from ebay which comes with 2 key fobs. It only cost $12.55 and works well. I only hooked up 4 wires to the unit and all were located in the drivers kick panel. I hooked up +12V , ground, door lock signal and door unlock signal. I did NOT hook up horn and parking lights because I do not have those connectors located for a 2019 model at this time I am going to upload a file below which is the dealer install instruction for a 2016 model. The toyota control unit is available for about $125 BUT then you have to make must make compatible keys which may cost near $400 That is just Crazy. Go with an aftermarket system...
  12. Dec 27, 2018 at 10:45 PM
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    Here are some comprehensive wiring diagrams for Tacoma 3rd gen 2016+ I found on another thread. I am Not sure if these will apply exactly to my 2019 since some connectors appear different than whats listed. Anyone with 2019 wiring diagrams would be greatly appreciated the share.
  13. Dec 28, 2018 at 4:08 AM
    Sgt.Tee
    Pete
    NE Pa
    Thank you for the write up
  14. Jan 14, 2019 at 12:22 PM
    tractng
    tractng Well-Known Member
    So do you have to program each transmitters? Looking to get this module for my 2019 SR.
  15. Jan 14, 2019 at 12:49 PM
    #35
    TK11
    TK11 Well-Known Member
    Tom
    CA
    2007 & 2019 Tacomas
    Similar topic: I wonder if there's a way to convert an Off-Road key fob truck to a "smart key" version like is available on the Sport. Ever hear of that?
  16. Jan 14, 2019 at 8:31 PM
    #36
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    Well, if you are thinking of getting the ebay $12 kit then I can say that my fobs were already BOTH programmed. However ,you can reprogram them if desired. It seems that it must be done very quickly (within several seconds) to get both fobs reprogrammed. The biggest issue for me has been locating the correct connector and pins for the lights and horn. Still waiting for 2019 diagram for that.
  17. Jan 14, 2019 at 8:46 PM
    #37
    tractng
    I plan to get the Toyota part one. I think the fob can be programmed one at a time (not have to be done same interval). Can someone confirm.
  18. Jan 14, 2019 at 10:21 PM
    #38
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    Ok, I understand, however I think the toyota keyless requires that you Also purchase and program toyota keys which may cost about $300 each. I am not absolutely sure about that but you should do your research first because it could get quite expensive. Another alternative is an aftermarket keyless entry installed complete for less than $200 and some include an alarm system in that price. check out vendors for viper and compustar
  19. Jan 15, 2019 at 1:21 AM
    #39
    baileyjfit
    baileyjfit Well-Known Member
    Bailey
    Texas
    2017 Stormtrooper
    I could use a push to start upgrade along with the keyless entry... haha
  20. Jan 15, 2019 at 2:55 PM
    #40
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
