Keyless entry
Discussion in 'Technical Chat' started by hillbillytoyo, Feb 21, 2011.
  1. Feb 21, 2011 at 10:40 AM
    hillbillytoyo
    hillbillytoyo [OP] Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I have an 08 double cab base model. My truck already has power locks. My question is how hard would it be to equipt my taco with keyless entry? How much? If anyone can help I would be very thankful.
  2. Feb 21, 2011 at 10:55 AM
    Dewey7015
    Dewey7015 Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    Basically, call a dealership with your VIN#, and they can look up on the computer if the truck has the correct ECU for keyless entry.. I ordered a keyless FOB off ebay before I did this...needless to say, my truck doesn't have the correct ECU or brain to add factory keyless.
    I still have the FOB if you want to buy it for $25..
    Hope this helps. If not, Amazon has pretty basic keyless entry systems for under $50.
    Dewey
  3. Feb 21, 2011 at 11:20 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    I'm interested in keyless entry as well. Specifically a keypad though. When it comes to access to my truck, I would love to have a keypad on the door instead of having to carry a remote device. I miss my F150 when it comes to this issue. Anyone who has ever accidentally locked themselves out likely would agree.
  4. Feb 22, 2011 at 8:46 AM
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    The dealership I bought my truck from isn't much help. I am going to call another dealership to see if they can help me out. Is the FOB you ordered from ebay a Toyota factory FOB or aftermarket?
  5. Feb 22, 2011 at 8:48 AM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    pep boys hasw do it yourself kits for 40$ the dealership is hella expensive
  6. Feb 23, 2011 at 3:44 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    Toyota factory, but after following the directions
    And it didn't work, I called the dealership. The fob I bought works, my truck will not go into "program mode" you have to do this sequence of steps, and your doorlocks are supposed to cycle. That's where I think the dealership was right. My truck doesn't have the right ecu.
  7. Feb 23, 2011 at 10:24 PM
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    Do you know the sequence?
  8. Feb 25, 2011 at 3:27 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    I will post once i get to work.
  9. Feb 25, 2011 at 5:09 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    To Program Wireless Remote Transmitters:​
    Begin with:​
    The driver’s door open and unlocked.
    Key out of the ignition.
    1. Insert and remove the key from the ignition switch 2 times within 5 seconds.
    NOTE:​
    Steps 2 and 3 should be performed within 40 seconds.​
    2. Close and open driver’s door ​
    TWICE.
    3. Insert the key into the ignition and remove it.
    NOTE:​
    Steps 4 – 6 should be performed within 40 seconds.​
    4. Close and open the driver’s door twice.
    5. Insert the key into the ignition.
    6. Close the door.​
    NOTE:​
    Steps 5 and 6 should be reversed for the following models ONLY (close door first,
    then insert key into ignition):​
    2000 – 2005 Celica
    2001 – 2003 Prius
    2001 – 2005 ECHO
    2001 – 2005 RAV4
    2003 – 2004 Avalon
    7. Turn the ignition switch from “Lock” to “On” and back to “Lock” at about 1 second
    intervals to select the desired mode:​
    1 time for ADD mode.
    2 times for REWRITE mode.
    3 times for CONFIRMATION mode.
    5 times for PROHIBITION mode.
    8. Remove the key from the ignition.
    9. To confirm your mode selection, the power locks will now cycle “lock” to “unlock” a
    number of times corresponding to your key cycles in step 7.
    NOTE:​
    If Confirmation or Prohibition modes have been selected, opening the door will
    complete the procedure.
    Programming​
    Procedure
  10. Mar 20, 2011 at 8:27 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
