Keys locked inside, 2nd set won't unlock it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dana3502, Feb 14, 2021.
  1. Feb 14, 2021 at 1:58 PM
    Dana3502
    Dana3502 [OP] New Member
    2009 Red 4-door Tacoma
    Man I hate that automatic locking feature!! I was getting stuff out of the bed when my Tacoma decided to lock itself with the key and fob inside. I am at home so I grabbed the second set. The second fob does nothing. Even the second key won't go fully into the door so it has to be an insane Toyota "safety feature" not a case of my fob battery being dead. What's the trick? I can't refer to the owner's manual because, of course, that is locked inside. Any advice is greatly appreciated!
  2. Feb 14, 2021 at 2:04 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I would probably spend the 50 bucks for the locksmith and figure out why it happened and how to prevent it from happening a second time. Hopefully someone on here knows the trick and can help you out.
  3. Feb 14, 2021 at 2:09 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Did you look in the Owner's Manual? :p
    Locksmith X2
    Something is Off with the key. It should unlock the door.
  4. Feb 14, 2021 at 2:12 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I did something very similar recently. Unlocked the truck with a single fob click (which only unlocks the driver door), opened the door, realized I forgot to grab something, laid my keys on the drivers seat, closed the door, and heard the truck auto-lock as I started walking off. I thought the auto-lock sequence would get interrupted by opening the driver door so what happened made no sense to me.
    Anyway, when I got my second fob out it unlocked the truck just fine, so I recommend replacing the battery even if you think it’s good, to rule that out.
    As for not being able to unlock the door with the key...when’s the last time you used the key in the door? Does it insert all the way? You may have some corrosion inside the lock mechanism and you could spray some silicon lubricant inside and then try the key again. Kroil Penetrating Oil is really good for corroded locks, if that’s the problem.
  5. Feb 14, 2021 at 2:15 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I don't think I have the auto lock feature. I've got a manual transmission so maybe it's saved for the autos.
    I would hate that feature
    Good luck OP
    Key-Rei likes this.
  6. Feb 14, 2021 at 2:18 PM
    Knute
    Doesn't the Auto-Lock disable if the fob is in the cab???
  7. Feb 14, 2021 at 2:19 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Spray the door cylinder with a lubricant or penetrating oil or try the passenger side cylinder. If still no dice then change the spare fob battery
    06Tacooo, Dana3502[OP] and Hook78 like this.
  8. Feb 14, 2021 at 2:19 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    https://www.toyota.com/t3Portal/document/om-s/OM35883U/pdf/OM35883U.pdf
    Pages 32-35 (of the manual not the PDF).
    -FOB battery depletes after 1-2 years whether you use it or not.
    -Nothing about the manual door lock being disabled by the auto lock feature
    -Your FOB and/or key on your second set should work fine. There’s no special security. The doors are just locked. Unless something aftermarket has been installed.
    Dana3502[OP] likes this.
  9. Feb 14, 2021 at 2:20 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Nope
  10. Feb 14, 2021 at 2:25 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I'd have bet a nickel it does. Sure seems to on my Gen 1 and Gen 2 trucks and my Lexus RX350. Now you've got me nervous -- any idea what led this to happen, or if it can be repeated? I never quite trust those systems and often lower a window if for some reason I'm leaving the keys in the truck.
    06Tacooo and shakerhood like this.
  11. Feb 14, 2021 at 2:33 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    It’s perplexed me ever since. However, I’ve also had some issues lately where my headlight auto-off feature isn’t always working properly. Since, as I understand it, that feature is also tied into the door open/closed status, there’s got to be an intermittent issue with whatever circuit communicates if my driver door is open or has opened. I’m not skilled with automotive electronic circuits so I’ll probably never figure it out.
    Edit: maybe I should just speak for myself given that it might be a one-off weirdo problem with just my truck. But I don’t know for sure. And now there are two data points not just one.
  12. Feb 14, 2021 at 2:44 PM
    Dana3502
    Thanks for your help guys! A little WD-40 did the trick. I've only had the truck about 6 months and I guess I have never used the key in the door. I was having the same issue with both sides. I do need a new battery in the second fob I think. It has enough juice to lock it, but not unlock it. Not sure why that would be the case. If a new battery doesn't do the trick, it might be a programming issue.
    JimIowa, Jimmyh and Steves104x4 like this.
  13. Feb 14, 2021 at 2:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe it’s only active (disabled) with the keys in the ignition?
    MoneyMan55 and winkel like this.
  14. Feb 14, 2021 at 3:00 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Nice!
    If reprogramming is necessary you should be able to do it yourself. Try this thread:
    https://www.tacomaworld.com/threads/2015-keyfob-programming.361834/
    According to the 2009 manual the auto lock security feature is disabled by opening any door.
    TnShooter[QUOTED] likes this.
  15. Feb 14, 2021 at 3:05 PM
    TnShooter
    Deogee
    STOCK
    You are right. I was thinking of the wireless lock function
    I don’t have Auto Lock.
    Except when using the wireless fob to unlock the door.
    If I don’t open the door with in so many seconds. It locks itself again.
    Hook78[QUOTED] likes this.
  16. Feb 14, 2021 at 4:16 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I think we’re both referring to the same thing? Here’s what I was referencing from the ‘09 manual for the OP. Maybe Toyota just changed the name of the feature. Or is one feature for manual door unlock and the other for FOB unlock?
  17. Feb 14, 2021 at 5:01 PM
    TnShooter
    Deogee
    STOCK
    Toyota does differentiate the 2.
    However, I don’t think it’s relevant in this case.
    As I don’t know how OP’s truck Automatically locked itself.
    I’m not saying that it didn’t, I just don’t know any other circumstances where the truck “locks itself”
    Other than using the unlock on the wireless FOB and NOT opening the door?
    No big deal. At least OP got the doors open.
  18. Feb 14, 2021 at 7:19 PM
    Knute
    Well, that sucks.
  19. Feb 14, 2021 at 8:06 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah I think you’re right, it’s a FOB thing only.
  20. Feb 15, 2021 at 4:48 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Glad I don't have "auto locking!"
    Won't help this time, but what I did after looking my keys in a vehicle a few decades ago was to never shut the door unless I was holding the keys in one hand. I hold my keys up where I can see them, then shut the door.
    I would ensure both key fobs and the 2nd set of keys work in the future.
    Hook78 likes this.
