keytechniques keyhole covers and bumper plugs
Discussion in 'Group Buys' started by keytechniques, Mar 14, 2010.
Thread Status:
Not open for further replies.
  1. Mar 14, 2010 at 7:51 PM
    keytechniques
    keytechniques [OP] Active Member
    Dev
    Silver Spring
    Keyhole covers by KeyTechniques Starting at $11 shipped!!
    [​IMG][/QUOTE]
    Each cover will be modified to fit and will be individually tested before they are painted to OEM colors and shipped out.
    Bumper plugs
    These cover up the front licence plate holes to give your truck a clean look.
    Ordering
    Attention as of September 8th 2010 we have made ordering very easy.
    Please visit our website.
    http://keytechniques.net/Tacoma-main-page.html
    [ Instructions on using your Keyhole covers
    Warning
    * Your keyhole covers are not colored plastic they are painted so please treat them with care and don't manhandle them
    Mounting:
    The covers consist of two parts.
    1. Cover
    2. Stem
    The stem on the xb2 type cover comes with a thin coat of contact cement to roughen up the stem and add tension to it. Observe the diagram closely to figure out the orientation of the eccentric stem to the door lock and insert the cover by stabbing it downwards and pushing the stem into the keyhole, then move it around until it is flush as can be. You will notice that the cover goes only one way due to the eccentric stem. If it does not go in on the first try changing the angle until it goes in but don't be rough with it. Remember that you will not get it to be absolutely flush due to the irregular thickness around the hole but you will find that it comes within acceptable range.
    After you have them seated well add a small bead of contact cement on the stem, Wait 10 minutes then insert them into place. The contact cement only touches the hinged door in one small area on the out side of the lock and the rest is floating on the inside and touches nothing. This will insure that no one can easily remove the cover or any chance of it falling out. I recommend this step to ensure your satisfaction. Contact Cement is a low tension adhesive which is water resistant available at any automotive or hardware store for under $2.00. Please only use this adhesive and not a stronger one.
    Removal:
    You will need to first push the cover down and insert your driver’s license or credit car through the gap and fish it out. the adhesive point on the lock hinge stretches and the cover is free to come out.
    Reinsertion:
    Take a Q-tip doused in Alcohol and clean the adhesion point on the out side of the lock hinge which dissolves easily and replete the procedure.
    The adhesion method is non destructive and can be cleaned up easy with any solvent.
    *Your covers use some of the best materials for manufacture including a UV resistant clear coat which is special ordered from Germany.
    Treat your covers well and it will give you many years of good service
    Personal note: I am a car enthusiast just like you and trusted on many forums for my efforts and services. Please PM me if you have any complaints or problems and I will try to respond ASAP to help solve your problem.
    Colors If you don't see your color listed on our website doesn't mean we don't have it. Please send me an email to keytechniques@hotmail.com .
  2. Apr 17, 2010 at 3:14 PM
    Tricky
    Tricky Well-Known Member
    Palmetto, Fl
    09 TRD Sport DC
    Anytime Fog Lights Bakflip HD Billstein 5100's Blacked Out Scoop Debadged FJ62 TOYOTA Smile Grillcraft Upper & Lower K&N Intake Magnaflow Cat-Back OEM Roof Rack Pioneer Speaker Upgrade Redline Hood Struts Slimcubby's HIDs Toytec 1.5 AAL
    2 Keyhole covers
    1E7
    2009 DC Tacoma
  3. Apr 17, 2010 at 3:20 PM
    jandrews
    '09 FourDubDee TRD OR
    Love the reflection in this pic...on your way back from the store?
  4. Apr 18, 2010 at 8:51 AM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Do you have radiant red? I think the code is 3L5.
  5. Apr 29, 2010 at 10:18 AM
    TacM31
    TacM31 Well-Known Member
    Tyler
    Houston, Texas
    '05 PreRunner Lifted
    6" Pro Comp Lift, aFe Magnum Force Intake, ATS Running Boards, Viper Alarm and Remote Start, RBP Grille, Custom Leather Seats, Flowmaster Super 44, Halo Projector Headlights, HIDs, Debadged, Aries Bull Bar, Bumper Plugs, 21" Stubby Antenna, Fog Lights Anytime Mod, Blacked Out Tacoma Badges
    Pair of bumper plugs
    BSP - 209
    2005 DC Tacoma
  6. May 4, 2010 at 6:10 AM
    keytechniques
    Dev
    Silver Spring
    Yes we have 3L5.
    Thanks
    dev
  7. May 23, 2010 at 7:42 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    subscribed.
  8. May 30, 2010 at 9:28 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Ordered & PAID
    a) qty = (2) Two
    b) paint code = 1E7 (SSM - Silver Streak Mica)
    c) Veh mod = 2010 Toyota Tacoma
  9. May 30, 2010 at 6:03 PM
    keytechniques
    Dev
    Silver Spring
    Keep the orders coming. We are going to make the latest batch Tuesday and have the orders out Saturday.
    Thanks
    dev
  10. May 30, 2010 at 7:28 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Did you ever get any 8p1 in stock?
  11. May 30, 2010 at 8:39 PM
    keytechniques
    Dev
    Silver Spring
    Sorry it's just that I need at least two others who are interested in this color for me to make the investment in the paint.
    Thanks
    dev
  12. May 31, 2010 at 2:13 PM
    Fern
    Fern TEXAS IS HOT!
    Fernando
    San Antonio,Tx
    '12 SUPERWHITE SPORT 4x4
    285/70R17 COOPER STT PRO | MOTO METAL 957 | 3" 885 COIL LIFT W/ AAL | MAGNAFLOW MUFFLER | AVID OFFROAD LIGHTBAR W/ 22" LED BAR
    Thinking bout it. Hmmm...
  13. Jun 26, 2010 at 1:50 PM
    Taco Ron
    Taco Ron Male Member
    I can vouch for Dev. I prototyped his Scion rear wiper plugs back in the day and he was great to work with and the product was stellar.
  14. Jun 26, 2010 at 4:02 PM
    keytechniques
    Dev
    Silver Spring
    Why thanks Ron. It been awhile. We are about to venture into other markets now.
    Thanks
    dev
  15. Jul 3, 2010 at 6:15 PM
    hun23
    hun23 Member
    Delano, CA
    10 SW PreRunner TRD Sport
    pair of license plate covers
    SW - 040 super white
    2010 tacoma sport
  16. Jul 3, 2010 at 6:44 PM
    keytechniques
    Dev
    Silver Spring
    Thanks for your order. We will be making it this coming Monday and it will ship out when it cures.
    Thanks
    dev
  17. Feb 12, 2011 at 8:15 PM
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Sub'd for future reference. Didn't know anyone did a color match cover! Looks like a nice item.
  18. Mar 10, 2011 at 8:11 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Ordered some bumper plugs
  19. Mar 14, 2011 at 6:51 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Ordered some keyhole covers.
  20. Mar 14, 2011 at 7:21 PM
    Cape Codder
    Jack
    'Spose it's time I post this.
    Installed last spring and it's looked like this since.
    Color Match is perfect.
    Never think about it being there.
    But I'd buy it again.
    CC
Thread Status:
