Kill Switch Mod Write Up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfInferno, Apr 20, 2010.
  1. Apr 21, 2010 at 8:48 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Great idea .You also might want to wire a back up switch also.Did my sisters 04 taco and switch gave out . Wired it in side of console so wires wasnt easy to get to.Wired another one behind glove box for back up.Main one goes out just turn on back up.
  2. May 4, 2010 at 12:00 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Questions..
    1. If the switch "goes out", wouldn't the circuit in essence be cut, hence what would the sense of a secondary switch be if the current wouldn't go pass the first switch.
    Had something like this in college in my '99 accord.. Put an inline with the fuel pump though, so the sucker wouldn't even start.. (no gas)..
    2. Is this something similar where if you flipped the switch off (while car was running) the car would stop? Or is this just to start the car?
    3. How easily bypassed would this be unless you found the switch?
    After just spending another couple hours "researching" TW, I see that the whole "key chip" security can be bypassed as well. Will be doing this mod soon..
    Hemitruk: Not sure if my eyes are bad looking at your small avitar... are those BHLM on your taco?
  3. May 4, 2010 at 5:33 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    1) If you put the secondary switch in the same circuit you're right. However, and this would be more complicated, but if you would wire up a parallel circuit and put the switch in that secondary circuit, it would work as expected.
    2) It's not a switch per see. It's a momentary push button closing the starter circuit. Not needed after the car is cranked up.
    3) Not at all, unless the thief knows the wiring diagram of the vehicle and traces the starter circuit wires. That is, if he would even suspect it's the starter circuit that is broken, and not some other anti-theft mechanism.
    I hope I got this right. I'm sure others will chime in :)
  4. May 4, 2010 at 10:42 AM
    SurfInferno
    SurfInferno [OP] Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    couldn't have said it better myself. I have already had friends take my keys thinking they are funny and try and move my truck to a diff parking spot or drive it around and they come back worried that my truck is broken.
    And i do have BHLM
  5. May 4, 2010 at 12:10 PM
    raycie
    Oahu, HI
    In need of $$$
    sorry.. Bhlm was for hemitruk cause he is in hawaii, and I may want some help.
    would a switch on the fuel pump be "better"? Just asking.. This would be a pretty fast mod. As for the "switch", anyone know of a factory switch that could be used in place of a aftermarket one? I was even thinking of putting a second foglight switch, hooking this up to that, and putting it in the off position when I park somewhere sketchy. But if one of the factory dash buttons were momentary, that would help too. Just like the "in pain sight" but not what yould expect idea..
    RA77 likes this.
  6. Jun 10, 2010 at 4:03 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Oznium.com has some switches that will work. They're listed as Scion switches, but I made them work in my 08 regular cab std. Had to shave a little of dash plastic with a razor knife. The old plug and new switch still stayed in place after shaving.
    They don't look like regular factory push button switches, but work better (and look better:) ) than the blue, thru plug ones.
    Can't post pics with my blackberry. I'll post a link when I get home.
  7. Jun 10, 2010 at 4:14 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Just my 2 cents, but I would cut/splice the wire much deeper into the firewall or even in the engine bay, if it goes there, because if the thief in question knows anything about hotwiring, he's going to see the ignition wire going to that switch.
    If everything looked intact from the driver's seat, then that switch could be for anything, and a thief will be less likely to figure it out.
    Good for keeping your friends from stealing your keys and going on joyrides, though :thumbsup:
    RA77 likes this.
  8. Jun 10, 2010 at 4:15 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  9. Jun 10, 2010 at 4:53 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    anyone interested in magnetic kill switches? PM me. I used to install them on Hondas and Mazdas all the time.
  10. Jun 10, 2010 at 5:08 PM
    SCFirefighter
    Stephan
    Cary, NC
    Tell me more?
  11. Jun 11, 2010 at 7:44 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Haha. Joke is on them. Next time I would start screaming at them saying they broke it.
  12. Jun 11, 2010 at 3:53 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  13. Jun 11, 2010 at 3:57 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    He's talking about a hidden magnetic sensing switch (right?). You have to swipe a magnet across it to start the vehicle. Can be hidden anywhere you can put a wire.
    My grandfather had one in his Grand Marquis. He never complained about it. If it was crap, we would have heard!
  14. Jun 11, 2010 at 4:00 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Where abouts in Ventura do you live? :spy:
  15. Jun 11, 2010 at 4:02 PM
    #35
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    that one place in ventura that is secret
  16. Jun 11, 2010 at 4:11 PM
    #36
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Nice I had one on my '71 c-10, it was a toggle up under the dash though and mine would kill the motor if you kicked it off.
  17. Jun 14, 2010 at 7:47 AM
    #37
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    sorry, i was working on my retrofit this weekend.
    What I am referring to is a magnetic reed switch. Similar to that used in home alarm installs. But yes, basically you hide the switch behind a panel, in the seat, etc. That way nothing is visible. All you do is run a magnet over the area, it triggers the switch and the additional relays keep the circuit closed which allows your car to start, when you turn the key.
    As for battery kills and ignition kills, that is definitely not the best way to go. While it is still semi effective on an auto, anyone can still pop the clutch on a manual and bypass that system. What you want to cut is the fuel pump circuit.
    Ill do a write up this weekend, and post it if i have time. If anyone wants one, I will look into making the kits.
  18. Jun 14, 2010 at 8:54 AM
    #38
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    That could be a real bad idea.... I can already see someone accidently hitting that going down the highway!! Can you say siezed engine??
  19. Jun 14, 2010 at 9:10 AM
    #39
    Crom
    Nick
    San Diego, CA
    Millions
    I am very interested if you write something up. A quick bit of research has shown that fuel pump cut off switches are indeed the most effective way of preventing drive-away-auto thefts.
    It will not hurt the engine if the fuel pump stops. It would be no different than running out of gas. However, if the fuel pump does stop, about 5 seconds later the engine would quit and the power steering would go out, so you my have a problem steering the vehicle.
    I recall once upon a time that fuel-pump-cut off switches were illegal, but I did some searching of the interwebz and I can't find any credible source where it says that it's illegal. It could have been a Kalifornia thing too...
    If anyone knows for sure, please let me know.
  20. Jun 14, 2010 at 9:14 AM
    #40
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Why don't you just disable the fuel injectors or the coils?
