Kill Switch Mod Write Up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfInferno, Apr 20, 2010.
  1. May 8, 2011 at 10:19 PM
    #61
    chacotaco
    chacotaco Well-Known Member
    Travis
    Lawrence KS
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Does the yellow side have lower current?
  2. May 9, 2011 at 5:11 PM
    #62
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    I think CM is sending me a message. I ask for real world directions like "That wire is under the steering wheel" and he replies with another beautifully rendered schematic that probably has a ton of information to those who can understand it, but doesn't really tell me where to find the wire in a "dumbed down" sort of way. I think he's saying "If this doesn't answer your question, maybe you shouldn't be cutting wires that might disable your truck"! :D
    Message received. I'm not complaining - CM has given me a ton of help the last few weeks. It just cracks me up. With the plan still evolving it's probably not something I should jump on yet. But I'm game when there's a clearer consensus.
    Don't know why I love the idea of a kill switch so much, but I do.
  3. May 9, 2011 at 8:17 PM
    #63
    primer
    T
    OK
    I do owe you for all the help. Unfortunately my keen perception doesn't include winning lotto numbers.:eek:
  4. May 10, 2011 at 10:52 AM
    #64
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Word of advice: If you ever have your truck serviced at a shop, be sure they know about your kill switch. I had a battery replaced once, and forgot to tell the shop about my kill switch, and they spent a LONG time trying to figure out why my truck wouldn't start before they finally called me. My battery cost about $300 because of the labor involved:eek: Never more, quoth the raven, never more.
    Gunshot-6A likes this.
  5. Aug 26, 2011 at 11:58 AM
    #65
    pilotj
    pilotj Well-Known Member
    Jay
    Grand Mesa, CO
    2001 Tacoma SR5 TRD 3.4L 226,000 like new!
    Deck plate w/baffle, grey wire mod, defroster switch mod, LED footlights, LED cap lights, magnetic theft deterent...
    Ok, I made a device that keeps the EFI power circuit open and allows the vehicle to crank but not start.
    The cranking will attract attention to your vehicle. They can crank till the batterys dead.
    Or, you can connect this device to any circuit that will dissable the engine.
    To start your vehicle, turn the key to the ON position and swipe a magnet across the
    area with the hidden switch, and start your vehicle. When you turn the vehicle off, the device resets.
    so you need to swipe the magnet every time to start, and there is no need to remember to arm the device. I also include a failsafe feature that
    deactivates the device to allow you to deactivate the device for mechanics or if you just want to disable
    the device until you want it active.
    There are a multitude of circuits you can disable with this device. It can be used for autos, trucks, boats, motorcycles, anything with an ignition switch and engine!
    It comes with instructions for installation.
    I know that something like this was mentioned previously, but I have the devices and they're ready to ship!
    Installation time: depends on the locations you choose, but estimate one to two hours.
    I installed this on my 2001 Tacoma, now I don't worry about my truck being stolen.
    Its cheap insurance!!!
    Please email me here for more information or to order.
    Price: $50.00 Shipping Included
  6. Aug 27, 2011 at 8:52 PM
    #66
    primer
    T
    OK
    Emailed. Seeking more info.
  7. Sep 7, 2011 at 5:01 PM
    #67
    jobrec
    jobrec Active Member
    Joshua
    Mesquite, tx
    07 PreRunner SR5 Debadged 2x4
    3" suspension lift, nitto terra grapplers on 18" he835 helo wheels, KDC-X395 radio, Alpine 500w amp, JL audio 10" thinline subwoofer
    On the second gens there is that tab you pop up and push in by the shifter to override the lock
  8. Sep 7, 2011 at 5:20 PM
    #68
    joes06tacoma
    Joe
    Central Coast, CA
    Not foolproof, I agree. I still think it would stop the average crackhead or high school kid. It would certainly throw them off if they were not familiar with the override. Anything that disrupts their quick getaway would help. I know on a Ford if the brake interlock fails, all you have to do is put the key in the off position (not lock), shift to neutral, start truck, then put it in gear and drive. Simple enough and does not require tools. But I have seen an extra switch wired into that circuit on law enforcement vehicles. Just gives the officer another minute to get the bad guy before he steals the car. A thief does not want to waste another minute outside your house in a running vehicle that makes noise when started.
  9. Sep 7, 2011 at 5:21 PM
    #69
    joes06tacoma
    Joe
    Central Coast, CA
    This is probably the best idea yet, unless it gets tripped while driving.
  10. Sep 7, 2011 at 6:21 PM
    #70
    pilotj
    Jay
    Grand Mesa, CO
    There is no way to trip it unless you have a problem turning the key off while you drive. If you have that problem, you have a problem.
  11. Nov 12, 2011 at 7:18 AM
    #71
    pilotj
    Jay
    Grand Mesa, CO
    I see questions about using a hidden switch, and what amp rating to use. My system uses a 30 Amp relay, so you can install with almost any circuit, but the device is wired for 10 Amps.
    Since I began making, using and distributing this system, there has never been a failure.
    It's easy to install and very cheap insurance!
    Email me for information and to order.
    Tacoma World Members: $50.00 Shipping Included, USPS Priority Mail
    Non-Tacoma World Members: $60.00 Shipping Included, USPS Priority Mail
    Check with your insurance company to see if you can get a discount with this device installed!!!
  12. Jan 20, 2012 at 4:35 PM
    #72
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    ruffridha9 likes this.
  13. May 27, 2012 at 10:24 AM
    #73
    sosa1624
    sosa1624 New Member
    ontario, canada
    10 Double sr5 leveled
    piaa fogs, front leveled, aem intake.
    Hey does anybody realize that the key you put in the ignition has an imobilizer system in it that cuts fuel to the engine if not sensed by the ECU
    VE7OSR and Gunshot-6A like this.
  14. May 28, 2012 at 5:28 PM
    #74
    chacotaco
    Travis
    Lawrence KS
    Im sure everyone knows that. However, your remote is probably on your keys, and your remote is great for finding your car. Loose a set of keys and this is great peace of mind.
  15. May 28, 2012 at 6:01 PM
    #75
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Quick noob question here. I have a base model standard 5 speed (does not have start clutch cancel), the clutch has to be pressed all the way in to start. Could I rig a switch into those wires instead of hacking into the ignition wires? Does any one know where to find the wires?
  16. May 28, 2012 at 9:16 PM
    #76
    joes06tacoma
    Joe
    Central Coast, CA
    Not all Tacomas have them. My 2009 that I drive at work does not have one. My 2006 TRD does.
  17. May 28, 2012 at 9:18 PM
    #77
    joes06tacoma
    Joe
    Central Coast, CA
    Yes you could. The switch is visible under the dash. Just follow the wires back into the harness until you're in a spot that's somewhat difficult to access for a thief and splic your wires. Of course, this does not prevent pushstarting, and it is also easy to bypass from under the hood. But if the thief is just your average punk, it may be all you need to get them to move on.
  18. Jul 17, 2013 at 9:25 AM
    #78
    ThrSitRep
    ThrSitRep Member
    Greg
    Puna, Hawaii
    hilomoto.com
    Frantz bypass oil fiter
    A well configured kill switch is the best and cheapest anti theft mod you can do.
    I like this mod but when I do it, I''ll route some wire down to a place under the carpet and mount a nice momentary switch so I can use my foot.
  19. Jul 21, 2013 at 3:54 PM
    #79
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    To those who were talking about making the switch inline with the brake for an auto - there's still an easy way to get your truck in gear. That little hatch looking cover thing in front of the shifter can be taken off. If you press the button underneath it you can change the gears without even putting the keys in. I'm guessing that's for if you are getting towed :p
  20. Mar 6, 2016 at 4:31 PM
    #80
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Has anyone done this on an automatic? Without factory alarm
