Kill switch
Discussion in 'Technical Chat' started by kenny3932, Jan 9, 2008.
  1. Jan 9, 2008 at 2:07 PM
    kenny3932
    kenny3932 [OP] Member
    north west Indiana
    TRD prerunner SR5
    2004 V-6 motor, tuff country 3" suspension lift, aftermarket wheels. custom grill insert
    Thinking about installing a kill switch on my 01 taco 3.4L V-6. I don't know if I should go with fuel or ignition cut off. If I go with ignition I would be lost under the dash with all that wiring. I guess putting a toggle on the hot wire to the ignition would be my best bet if I can find which wire to tap into. Any suggestions? :confused:
  2. Jan 9, 2008 at 2:24 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    This sounds fun. I'm leaning towards the full pump cut off. I'm probably wrong, but I think that's what my brother in law has. His truck shuts off after about a minute if you don't do "something."
  3. Jan 9, 2008 at 2:44 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
  4. Jan 9, 2008 at 3:19 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    do you have a five speed or auto
  5. Jan 9, 2008 at 3:20 PM
    kenny3932
    north west Indiana
    TRD prerunner SR5
    Excellent. thanks for the help. I didn't know such a product existed.:D
  6. Jan 9, 2008 at 3:21 PM
    kenny3932
    north west Indiana
    TRD prerunner SR5
    auto
  7. Jan 9, 2008 at 3:24 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    that's neat. I just don't want to carry any more junk around on my keys. It's tempting to keep in the cab and activate it by hidden switch, then again, I guess you're kind of defeating the easy installation advantage.
  8. Jan 9, 2008 at 3:48 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Neither did I! :D I think someone on TN pointed it out after a guy's truck was stolen. He started it to warm up, locked the doors, and walked to his garage to grab 1 more thing. Came back 30sec later to an empty driveway! I had to go through my history to find it since a google search didn't find it again. Only things I found were relay kits and instructions to splice the wires yourself.
    I suppose someone could still steal your truck if they knew it was there and brought a stock relay with them. But that would require breaking a window, popping the hood, replacing the relay, and then hot wiring it.
    Near as I can tell there's no light flash, chirp or dash light to clue a thief into the need to bypass it so it should work pretty well. Only problem I can see is if the battery in the fob dies. You could still unlock the doors and swap the stock relay in if needed. Maybe hide the stock on in the truck somewhere just in case?
  9. Dec 19, 2010 at 9:48 AM
    krudawg
    krudawg Well-Known Member
    Ted
    Goodyear, AZ
    06 PreRunner V6 SR5
    I had a friend that kept getting his 67 Mustang stolen at Oakland Airport. He kept getting it back because he had installed a fuel shutoff valve, which was located under the drivers seat. The car would drive 3 tenths of a mile and "Mysteriously" flame out just prior to the freeway. In fact the system worked so successfully that he was trying to figure out how to install some kind of recording device inside the car that was activated by the engine when it flamed out. He thought it might be kind of funny to listen in on the conversations after the car stopped running.
