King Coilover Height Adjustment
Discussion in 'Suspension' started by buggin, Jul 16, 2012.
  1. Sep 13, 2017 at 12:20 PM
    #81
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    That will make a difference for sure. You would need a little less preload to keep the same ride height. Instead of 600lbs per inch of compression, it would take 650lbs For every inch. You can still fully collapse the shock, would just take more weight/force to do it.
    If you are concerned about block height, the stiffer spring will most likely have a higher block height, but unless you are running a ton of preload, you don't really have to worry about coil bind.
    If you click that link above to @deeezy 's build, he did the opposite thing, and went with a lighter spring.
  2. Sep 13, 2017 at 12:46 PM
    #82
    bullaculla
    Da big big island!
    Here is a good resource for suspension. Scroll down and watch the video.
    http://www.crawlpedia.com/spring_rate_calculator.htm
  3. Apr 23, 2018 at 2:18 PM
    #83
    Arellano510
    Arellano510 Member
    Arturo
    2017 inferno tacoma trd off road
    How much lift you have like this?? How much tread is it in inches??
  4. Jun 9, 2018 at 11:14 PM
    #84
    RenneR’sTaco
    RenneR’sTaco Well-Known Member
    JP
    2018 White Double Cab Off Road Short Bed
    I have the extended length King’s not sure which spring came with it but how many threads should you see for 2.5-3” if lift? The way it sits now unchanged is like 4 on driver and 3 on passenger. What is a good ballpark range?
  5. Jun 10, 2018 at 11:40 PM
    #85
    Surfer991
    Surfer991 Member
    Jake
    2017 Tacoma MGM TRD sport
    King 2.5 ext front/rear king 3.0 bypass Baja kits uca's
    I have the 600# springs and my thread count is 7 on drivers side and 6 on pass and it gave me just under 2.5 inches of lift, hope that helps.
  6. Jun 11, 2018 at 8:02 AM
    #86
    RenneR’sTaco
    JP
    Thanks ya it seemed as if right out of the box even the factory setting gave me like 2 and a quarter but then quickly settled down. I am now showing 11 and 10. Just barely clears the cab mount right now. Going to get it aligned. Was curious what everyone leaves there’s at. Thanks
