King shock help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FeArMyTaCo, Feb 8, 2010.
  1. Feb 8, 2010 at 9:17 AM
    FeArMyTaCo
    FeArMyTaCo [OP] doin' work
    brett
    las vegas
    09 dbl cab prerunner debadged
    flowmaster 40 series,k&n c/a intake,kings rr front and rear, grille craft grille, 285 big o a/t, 17" moto metal rims, 90 watt 6 strobe whelen kit.
    I had a buddy install my king coilover with rr who had already put the same kit on his Tacoma but on mine the hose for the reservoir on the passanger side just barelly rubs the uca and is mounted the exact same as the driver side not sure What to do besides move res back in the mount a little bit or try to tighten hose that connects to shock to res to move it outta the way, any help will be appreciated
  2. Feb 8, 2010 at 2:00 PM
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    Call King Shocks and ask for "technical assistance" they will put somebody on the line that can tell you would be the best solution for your particular issue.
    They have always been more than helpful for me.
    714-530-8701
  3. Feb 8, 2010 at 2:02 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  4. Feb 8, 2010 at 2:26 PM
    FeArMyTaCo
    brett
    las vegas
    Thanks you I did get ahold of them and they said to try tightening the 90 where the hose comes out of the shock so I'm gonna try that Wednesday when I can take them off for now I got some hose and cut it in half and ziptied it over the res hose between the uca the hose so the wear is on the scrap hose and not my shock hose. I'll try to get some picks up tomorrow all I have is my I phone rightnow
  5. Feb 8, 2010 at 2:26 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I had the same thing with my Fox shocks and did the following:
    1. With the shock in an upright position and the reservoir raised high with the nozzle facing up, slowly depressurize the shock.
    2. Let the reservoir hang to minimize oil leakage. Loosen the 90 degree bend hard-line in the reservoir line, rotate it to the direction it should face, re-tighten.
    3. Pressurize the shock WITH NITROGEN to 200psi.
    4. Mount the reservoir.
    5. Have a beer.
  6. Feb 9, 2010 at 11:10 AM
    FeArMyTaCo
    brett
    las vegas
    Thank you! I just spoke with kings and they said to just take it off and tighten the 90 comin out of the shock and that should give me my clearance because it's just barely rubbing will post back update on sun. I'm just gonna do it sat I get off to late on the weekdays to get the shock refilled if I empty it. Thanks again for the help!
