Knock on Steering?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, May 1, 2009.
  1. May 1, 2009 at 2:35 PM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    Hey guys
    When I go over speed bumps and come down off of them, there is a slight knock in the wheel. There is also more play to the left in the steering wheel.
    I am planning to put my billys 5100's on tomorrow but dunno if I should try to get it looked at under warranty before I put the billy's on.
    Lets just say it would be a hassle to not proceed with the installation tomorrow.
    Maybe the new shocks will fix the problem??
  2. May 1, 2009 at 2:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds normal. Most Tacomas are like this. Check out the slip joint connector on the steering coloum and make sure it is tight.
    1 Near the fire wall:
    And one near the steering rack:
  3. May 1, 2009 at 3:00 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    hmm. Thanks for posting that Chris, mine is getting a little bit of a clunk too. I was wondering if it was UCA balljoint play from my lift, but i'll check these out first.
  4. May 1, 2009 at 3:05 PM
    papabear050
    Thanks Chris!!!
  5. May 1, 2009 at 4:25 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Not saying that chris is wrong, butI've never felt that but.... judging from what you're telling me, I'd double check your tie rod ends and bushings, only takes a couple seconds at the least. I had a bushing go out in another vehicle and I was able to feel it on bumps in the steering wheel as well.
  6. May 1, 2009 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good idea. Cant hurt to check. :)
