KO2 Balancing Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josh S, Jul 20, 2016.
  1. Jul 20, 2016 at 10:42 AM
    Josh S
    Josh S [OP] Well-Known Member
    Josh
    Topanga, CA
    2016 Tacoma Limited 4X4 DC & 05 Tacoma 4X4 Double Cab
    05: Big Tires, Big Black Wheels, Leveled and raised a couple inches, Extra leaf in the back 16: Stock. For now.
    Last week, I took a 3000 mile road trip on my new 265/70/17 KO2's and FN Konig Countersteer wheels. Between 62-75mph, I'm getting a super annoying shimmy in the steering wheel. Starting at around 55mph, i feel the shimmy in my seat. I stopped twice at two different America's Tire to have them re-balanced, but the ride is still shaky at freeway speeds. Both shop techs said they've had a very difficult time with the KO2 tires, and there's nothing else they can do to eliminate it (other than sell me a different set of tires). Anyone else run into this problem and find a solid fix? I had the original KO's on my 2005, and loved 'em.
  2. Jul 20, 2016 at 10:45 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I had the same issue with Duratracs. This is why I plan to stick with the OEM Good Years for now. I keep smashing on them thinking they'll blow at anytime in tough AZ terrain, jagged rocks, cacti, mesquite thorns, etc....they just keep on tickin'!!! Also their road manners are much better than more aggressive A/Ts i've had in the past. Also I suspect larger tires will exacerbate the issues with the doggish transmission/motor combo and I definitely want to avoid making that any worse than it already is. Those bigger tires, more ply = more rotational mass.
  3. Jul 20, 2016 at 10:58 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    Other factors can cause shimmy such as wheel alignment. I have same tire in C load on the 4Runner with no issues.
  4. Jul 20, 2016 at 11:01 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    My KO2s are great on the road.
    Tacohotshot likes this.
  5. Jul 20, 2016 at 11:05 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Try rotating the tires. Also check to see how much weight is needed to balance. Sometimes it works well too break the tire bead and rotate the tire 90 degrees and reseat the bead.
    Tacohotshot and Lawfarin like this.
  6. Jul 20, 2016 at 11:10 AM
    Siblue
    So Cal
    25 Tundra TRD pro
  7. Jul 20, 2016 at 11:32 AM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    I've had some of the same issues with mine. The first time the tire shop put on E load instead of C load tires and one of them was out of round. I thought the whole truck was going to shake itself apart! Second time they got the right ones on at least (265/70/17 C rated KO2 on TRD Pro wheels) and it was ok up till about 45-50 and it would start to shake. Had them balanced again and it was better at low speed but would still shake at 65 on the highway. The third time (road force + Toyota wheel adapter) it was better yet and seems to be perfectly balanced up to 70. Anything over 70 it'll still shake a little, not on the steering wheel though rather the passenger seat will wobble back and forth and you can feel it's a little off so the turnpike (75) isn't too fun but funnily enough if you get up over 80 (not really practical in the Taco + AT tires or legal) it smooths back out again :rofl:. After three balances I've just learned to live with it since it's fine everywhere else and I don't usually go 75 more than once a week or so for maybe an hour compared to a lot of 65-70 on the local highway going to work and back every day. I'd hate to mess it up even more.
    My brother has them in, uh, 325 something size I think on his Super Duty :eek: and his had to go back a few times but it got to be pretty much perfect, so I'm a bit envious and know that it is possible. Just harder than a regular tire plus rocks get in the tread and can throw it off till they fly out. I also had the original KO's in 275 or 285/70/17 on my Tundra and it was perfect. It was also the OEM tire at the time on the RW package.
  8. Jul 20, 2016 at 11:36 AM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I've learned that if you have shimmy at certain higher speeds and if you go even faster, the shimmy goes away, that is definitely a balance issue.
    Maybe try a performance shop, rather than a big box tire shop to re-balance? I had to do that.
  9. Jul 20, 2016 at 11:42 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Had the dealer do mine; mount and balance was $20/each.
    6000 miles later, no problems; have had it up to 80mph.
  10. Jul 20, 2016 at 12:20 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    If they are having that much trouble balancing them it might be a good candidate for dynabeads
  11. Jul 20, 2016 at 12:23 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    my duratracs had the same problem, got a road force balance and they're good now
  12. Jul 20, 2016 at 12:28 PM
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
    I had mine put on at town fair tire, i had to have them re-align twice and re-balance them 3 times but i still have a slight wobble at higher speeds. When i get the tires rotated next i am going to bring it to toyota to have them re-balance the tires once more to hopefully smooth it out.
  13. Jul 20, 2016 at 12:35 PM
    Gander
    Gander Well-Known Member
    Ellis County Texas
    2012 TRD 4x4 Tacoma
    I have had 2 sets on two different trucks and no issues at all.....were put on the factory rims on TRD Taco and Tundra
  14. Jul 20, 2016 at 12:39 PM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    Two of my Duratracs have the same issue. The steering wheel and passenger seat vibrate like crazy at hwy speeds when the bad tires are up front. Roadforce balancing did not help. My next tire will probably be a Michelin since they don't seem to have this issue as often.
  15. Jul 20, 2016 at 12:39 PM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    try a road force balance and make sure they line up the yellow/red dots on the sidewall correctly. and if you need to find a hunter road force machine goto the hunter website and they track all shops that carry which model of wheel balance machines bought.
    http://www.hunter.com/gsp9700
  16. Jul 20, 2016 at 1:09 PM
    splitbolt
    NW Arkansas
    Is the Haweka adapter still a thing?
  17. Jul 20, 2016 at 1:31 PM
    plasticsnaks
    plasticsnaks Well-Known Member
    Brett
    South TX
    2019 DCLB Off-Road
    Eibach stage 1 -wheeler’s 2” aal-spc uca’s FN 5 Star w/Falken Rubitrek AT 265/70r17. Nitro 4:88’s KDMax tuned Leer 100r
    Op,
    Did you install hub centering rings on your konigs ? Unless the newer countersteers are hubcentric, the rings may be needed. Dustin at FN used to sell the centering rings with those wheels. Also important to not use an impact wrench on the countersteers. Tighten lugs by hand and tighten evenly using criss-cross pattern. Also already stated use the haweka adaptor (lug centering adaptor) when they balance the wheel/tire.
  18. Jul 20, 2016 at 3:31 PM
    littlechilds
    littlechilds skyhawk
    Cowtown
    16 trd sport Upgrade package DCLB
    KO2 tires, TRD pro rims. BP skid plate, Extang 2.0 cover, dipped grill and badges
    I'm having major issues with my K02's since purchase date 4k ago, had them balanced 3 times…each time I could feel a difference, but they either got worse over time, or a shake would reappear. It has never been perfect.
  19. Jul 20, 2016 at 3:42 PM
    dreadedsoldier
    dreadedsoldier Well-Known Member
    Utah
    2016 Quicksand TRDOR
    A road force balance is what you need. You can have perfectly balanced tires but they can still be out of road force. What happens is the tires don't seat on the rims in a good pattern and they sit egg shaped. This will cause them to give you a high speed vibration no matter if they are balanced to zero. I have a road force balancer at my disposal and what I have to do if the road force is bad is rotate the tires on the wheel until they find their sweet spot. Find a road force balancer and I can almost guarantee they will be out of spec. A good road force will be under 30lbs for a truck. Had 35/12.5/17 tires on my wrangler and had to mess with them a couple times to get them right. Hope this helps
    ensaladas likes this.
  20. Jul 20, 2016 at 4:34 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Aftermarket wheels and lugs, who would ever have thought how difficult and can be sometimes..not saying this is your issue, but if you just have 60 degree conical lugs you may not have these mounted the way they need be, double check and see if you need ET lugs...and check your torque. Get some bite and snug em up.
