KO2 C load - 2 Versions?
Discussion in 'Wheels & Tires' started by ejewels, May 13, 2020.
  1. Mar 27, 2021 at 10:01 PM
    pandonsf
    pandonsf Well-Known Member
    Brandon
    Millbrae, CA
    2019 Tacoma TRD Off-Road
    I was curious if they were 58lbs, I switched from wildpeak e rated and saw a mpg improvement so wasn’t too worried. But wonder how much better it would be with the normal c rated
  2. May 2, 2022 at 1:46 PM
    bajashane
    bajashane Member
    shane
    Baja
    Just an update tires lasted me only around 30k miles/2years they were great up until now they are loud with 4/32s left! debating on getting the lighter c loads or switching to Geolander G015 or michelin at2s
  3. May 2, 2022 at 2:55 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Something is seriously wrong if that is all you have gotten out of those. You have any pics?
    SR-71A likes this.
  4. May 2, 2022 at 3:02 PM
    bajashane
    bajashane Member
    shane
    Baja
    i thought the same thing but our local discount tire salesman told me that typically people are lucky to get 35k out of them here! our summers are brutal normal temps are 115 degrees and the asphalt is so hot! (El Centro CA) i imagine that is why!
  5. May 3, 2022 at 6:42 AM
    Sungod
    St Augustine
    Sounds plausible since heat is the #1 wear factor, but you are getting about half of what you should. I'm guessing your shoes might melt with temps like that!
  6. May 20, 2022 at 8:06 PM
    Sliding West
    Sliding West Mad Props!
    Dave
    Vancouver
    20 AG Pro
    SPC UCA Westcott Design Front Icon Progressive Add a Leaf Greenlane Step Slider Retrax Pro Retractable Cover Weatertech Visors EGR Hood Deflector Meso Headlight Trim Plates Meso Red Start Button Meso Vent rings Meso Blackout Start and 4X4 ring Meso Total Tail Stage 1 Meso V5 Turn signals Meso Puddle Pods Meso Overhead Hexrack Meso door handle covers VLED Vanity, License, and Plate reverse lights Tacoma OEM bed step Raptor Lights Meso Ultimate Red/White Interior Lights KTJO Grab Handle KTJO Door Pocket Lights Ice Blue Durabump Front SCS SR8 17x8.5
    Was just at Costco and they mentioned all 3 C's were available and their explanation was the s version had deeper thread and was the newest version... Thought I'd come see what you guys were saying. One thing I noticed is that the weights are listed as the same and a small diff in tread width when using their compare.
  7. Jul 8, 2022 at 11:09 AM
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    nah the S was discontinued per when I called BFG 2 years ago when I made this thread. Even if not discontinued, I doubt its the newest version. The C load with 113Q rating is what you want. If you want a heavier tire, go for the 113S version or just get the E load version.
    SR-71A likes this.
