KO2 E Rated Vibrations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Victory, Sep 10, 2019.
  1. Sep 11, 2019 at 6:28 PM
    #41
    Victory
    Victory [OP] Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Was typing that maybe I need one as you responded. Can alignment cause rear end vibration? I’ve never had it aligned as I’m just 21,500 miles, and my factory tires wore perfectly even, but did wear down to 4/32 in that time.
  2. Sep 11, 2019 at 8:55 PM
    #42
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    There are cases where the carrier bearing housing has been installed upside-down. Look at your driveshaft angles right there. There's about 1/4-1/2 inch of difference in height depending on which way it is installed.
  3. Sep 11, 2019 at 8:58 PM
    #43
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    I'm a 2nd Gen, but have the same tire and same size. I don't have any vibration issues on mine while driving highway speeds. Your tires might not be correctly balanced
