KO2s load rating ‘e’ worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Daingerous, Mar 26, 2020.
  1. Mar 27, 2020 at 9:02 AM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    No. Very poor traction in the rain and a pretty rough ride... I switched to cooper at3 xlt's and they perform much better
    ColoradoTJ and Pops1416 like this.
  2. Mar 27, 2020 at 10:33 AM
    Woolybugger
    Woolybugger Well-Known Member
    Aaron
    2005 blk acess cab trd 4x4
    King coilovers
    boston23 likes this.
  3. Mar 27, 2020 at 10:39 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I run E rated tires. My buddy is running 35 E rated. I find that lowering tire pressures gives a great compromise in ride quality. My tire shop states I should run no less than 40, but it feels terrible. I run 36 front and 34 rear.
    There is a slight takeaway running low pressures which is wearing down of tires at an accelerated rate. I find that rotating tires often combats this very well.
  4. Mar 27, 2020 at 10:41 AM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    I have had Load E on my taco for like 70k and other than being a little heavier they are a lot more durable. I have ran over a toolbox on an expressway, last week I pulled out 3 screws and a screwdriver out of my tire and none of them went through. If you are in areas with shitty roads or lots of debris run the Load E, it will save you a lot of hassle
    FJ to Taco and Nick2014 like this.
  5. Mar 27, 2020 at 11:48 AM
    jetfishn
    jetfishn Well-Known Member
    The BFG KO E have three ply sidewalls very few tires have this 3 ply sidewall just a handful of offroad tires, its much better if you drive offroad in sharp rocks like quartz, flint, slate, the sidewalls are much more resistant to puncture, I run offroad mining in Nevada and have no troubles with E rated BFG's, have seen several sidewall punctures on standard b range offroad tires with others in our group. Also the E range is much better if you tow a travel trailer with heavy tongue weight, you may pay a little more for the BFG KO E range but you will get much longer treadwear over most other tires too. I run 38 lbs all around for towing my travel trailer for better overall control and mpg, but unloaded around town I run 32 lbs and its much softer ride, very noticable.
    Shaggs likes this.
  6. Mar 27, 2020 at 12:01 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Ahhh the SL, C, E load TacomaWorld argument. It's a classic.
    E load tires are overkill on a Tacoma. The ride will be significantly harsher, louder and your MPG will suffer noticeably. Your gains will be in tire durability in the most extreme of conditions. Forest service roads, deep snow and ice do not count as extreme conditions.
  7. Mar 27, 2020 at 12:33 PM
    Daingerous
    Daingerous [OP] New Member
    2015 Grey Tacoma LTD.
    Okay so I would like to get 6 ply tires but I can only find the Duratracs 265 width in a 4 ply.
    Could I run a 275 width tire on my rim that I believe is meant for 265s?
  8. Mar 27, 2020 at 12:42 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Lol. My wife's Subaru is now running a thicker ply tire than my tacoma is now...
  9. Mar 27, 2020 at 12:53 PM
    tacoma2g
    tacoma2g Well-Known Member
    Midwest Ohio
    2015 DCSB
    I love my tires, so I'd recommend E. My wheels are to help me get over certain things in the woods and not worry so much about puncturing. There's a lot of broken branches, etc.
    I also only drive 2 miles to work everyday and the ride isn't too bad.
    jetfishn, Fightnfire and Shaggs like this.
  10. Mar 27, 2020 at 2:05 PM
    Shaggs
    NorCal
    honestly I never had Ride issues with load E tires... my gf doesn't like how the steering feels but other than that they ride just fine, even at 38psi
    jetfishn likes this.
  11. Mar 27, 2020 at 2:10 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    My sl rated winters don't ride any better than my e rated wildpeaks. play with tire pressures and the ride is fine. People running 36+ psi on e rated tires are just asking for back problems.
  12. Mar 27, 2020 at 2:25 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Significant, no. Even my stock tires were louder. If you're worried about MPG then don't drive a truck!
    Now if you're paying for my tires, upgrades and my gas then I will gladly take your advice.
  13. Mar 27, 2020 at 2:54 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I've thought about going to C loads for better mileage and rotational inertia, but with the harsh lava here in Hawaii, I'm glad I have my E load KO2's. I can't advise for snow since I rarely drive in it in Hawaii.
  14. Mar 27, 2020 at 3:29 PM
    JStarr
    JStarr Life Off the Road
    Jonathan KH6X
    Kaupo Southeast Maui, Hawaii
    Tacoma 3rd Gen 2017 quicksand TRD OR, T4R 5th Gen TRD ORP silver , Tundra 2000 TRD OR silver, Deere 5300 4wd, Wrangler 1994 ARB air lockers, 1998 BMW R100RTL.
    E Rating decision depends on how you run the truck. For paved roads and soft graded dirt, you probably don't need the 10 ply E's.
    I run fast daily over unfinished roads with sharp lava rock chunks on the roadway and sticking into the roadway from stacked rock walls on the sides, and sharp deep potholes. The E rated KO2's have never had any problem with intrusion or cracks in the tread or sidewalls in 5 sets over a number of years. I change them out at around 25k, as added insurance. They still look pretty good and this has saved me much grief. Tire changes is no longer the fun adventure it was when I was younger, especially late at night in the rain in wild places.
    The OEM's and other lesser tires have all succumbed to road hazards, usually holes in addition to nails and pieces of iron.
    When the Tacoma is running light, I keep the tire pressure at 31 cold/33-34 hot. If I load up the bed, they go up a couple of pounds. Lower pressures soften the ride over the rough stuff and add to traction in the mud. I'm not running on highways or other fast pavement.
  15. Mar 27, 2020 at 4:05 PM
    #35
    tacoma2g
    Midwest Ohio
    2015 DCSB
    I actually had insane issues with SL Wildpeaks AT3W’s, they’d never balance on my truck. Tried NINE different tires at a Falken dealer... said screw it and went BFG. Dealer’s first try - perfect.
    On a side note:
    Falken let me return all tires!
  16. Mar 27, 2020 at 4:15 PM
    #36
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Do any of y'all running E rated tires notice steering wheel wobble after your truck sits for 12+ hours? I've ran Cooper STT Pro & now Nitto Ridge Grapplers, which I've noticed this w/both sets. After my truck sits overnight, or longer, I get steering wheel shake for the first 3-4 miles after driving again. I'm pretty sure it's flat spots forming & then they smooth out after a few miles.
  17. Mar 27, 2020 at 5:29 PM
    #37
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Marshall R What Pirellis' did u go with? Thanks.
    Green Jeans likes this.
  18. Mar 28, 2020 at 7:53 AM
    #38
    badger
    badger Well-Known Member
    07 SR5
    It can happen with any tire, but because E's are heavier, the effects are felt more. Those of us old enough to remember the early days of offroading with bias ply tires know how good we have it now. My 69 Bronco with 35" bias ply tires rode like a bucking horse for a good 10 miles, till that flat spot smoothed out. Luckily I was young then and my kidneys could take it. Radial tires have made life a whole lot better.
  19. Mar 28, 2020 at 8:00 AM
    #39
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    It reminds me of the bias-ply tires and that exactly what I think of every time it happens. I’ve never noticed this with a C or D rated tire and I’ve never noticed it with an E rated tire on my 3/4 ton or 1 ton trucks. I think it’s the combo of E rated tires and a light vehicle that makes it so apparent.
    badger[QUOTED] likes this.
  20. Mar 28, 2020 at 8:04 AM
    #40
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    +1 Best tire I’ve ever had, hands down...
