Krylong black flat paint
Discussion in 'Product Reviews' started by Justin, Dec 17, 2012.
  1. Dec 17, 2012 at 7:45 PM
    Justin
    Justin [OP] Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    I was thinking of using this to paint my grill black. Anyone know if it works actually?
  2. Dec 17, 2012 at 7:52 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    It will make the grille black, but it will chip when rocks or bugs hit it because spray can paint is non catalyzed meaning it uses no hardener.
  3. Dec 17, 2012 at 7:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    BBQ paint on the aluminum Satoshi mesh, Krylon Fusion white on the inner surround (factory white on the outer shell)
  4. Dec 17, 2012 at 7:55 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The plastic-specific paints are much better than traditional spray paint.
    They bond much better and hold up pretty well.
    That picture was taken last weekend, I've got over 20k on that grille without touchups.
  5. Dec 17, 2012 at 7:56 PM
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    What can you get that won't chip/ would hold up better?
  6. Dec 17, 2012 at 7:56 PM
    koco
    Bay Area Ca.
    '01 Taco
    Yep, they sure are...more flexible.
  7. Dec 17, 2012 at 7:57 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Take it to a body shop.
  8. Dec 17, 2012 at 7:58 PM
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    No way of DIY?
  9. Dec 17, 2012 at 8:00 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    This falls under the category of "If you have to ask, you lack the skills and equipment"
    Krylon Fusion, or the comparable RustOleum "All surfaces" is the best you are going to be able to get without going to a 2-part catalyzed paint shot from a pro-level gun. Airless sprayer doesn't count ;)
  10. Dec 17, 2012 at 8:01 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    I always use this paint when painting something flat black. I painted my skid plate with krylon and had good results. It is holding up well so far. Make sure to have good prep work and use a good primer and it should be fine.
