KTJO Bolt and lock install video?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by btrumpatori, Mar 18, 2020.
  1. Mar 18, 2020 at 10:28 AM
    btrumpatori
    btrumpatori [OP] Well-Known Member
    I received the KTJO Bolt and lock kit last week and was looking for videos of the install process. I found one in which the lighting is suboptimal. I found a bunch for the Pop n' lock kit but obviously this is somewhat different. The KTJO install pictures are of both kits.
    Wondering if anyone knows of an install video to help a relatively newb out?
  2. Mar 18, 2020 at 10:37 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    No video but a play by play courtesy of @KTJO 4x4 herself.
    https://www.tacomaworld.com/threads/3rd-gen-tacoma-tailgate-lock-opener-installation.614461/
  3. Mar 18, 2020 at 10:40 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Speedfreak[QUOTED] likes this.
  4. Mar 19, 2020 at 4:13 AM
    static305
    static305 Member
    adam
    2019 White Tacoma TRD Sport
  5. Mar 19, 2020 at 6:32 AM
    btrumpatori
    2020 TRD Sport
    That's the video I referenced - a bit dark in terms of whats going on in the tailgate. If this is the only one I'm sure I can figure it out.
  6. Mar 19, 2020 at 7:33 AM
    siniquezu
    siniquezu Well-Known Member
    The wiring is also super confusing because it changed after the video was made. The button wiring instructions are also very poor. So bad that I gave up trying to install it. I'm having trouble with the tailgate not dropping and I can't even find a place to trouble shoot. The only instructions given are an email address in the kit.
  7. Mar 19, 2020 at 7:38 AM
    static305
    static305 Member
    adam
  8. Mar 19, 2020 at 10:16 AM
    ILiketoFish
    ILiketoFish Member
    Did you try removing the rubber plugs that the tail gate rests against? I had such a hard time getting my tailgate to drop then I removed the plugs and it now drops every time. Try it out. If it works and you want to keep the plugs you can try shaving them down until you get it to drop.
  9. Mar 19, 2020 at 10:18 AM
    ILiketoFish
    ILiketoFish Member
    If you get stuck I can help you out. Just let me know. The instructions aren't that clear. I remember using 2 or 3 different set of instructions...just don't remember where I saw them.
    Malvolio likes this.
  10. Mar 19, 2020 at 4:15 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    My tailgate would not drop until I shaved the tailgate rubber stops down. Now it works every time. I have a manual trans and I am still trying to install the tailgate switch.
  11. Mar 20, 2020 at 1:55 PM
    btrumpatori
    Thanks for the info. To be clean, I have only the lock/unlock actuator to install. No opener, no switch.
