KUAFU Skid plate?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PooTaco, Feb 7, 2024.
  1. Feb 7, 2024 at 6:46 PM
    PooTaco
    PooTaco [OP] Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    Wondering who has this skid plate from Amazon and if there's a better aluminum skid around the same price?
    How easy does it make oil changes?
    What are the size of the bolts?
    I want to get stainless steel.
    Thanks.
    AmateurTaco1313 likes this.
  2. Feb 7, 2024 at 6:52 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It would help people if you linked the product page.
    Junkhead likes this.
  3. Feb 7, 2024 at 7:02 PM
    PooTaco
    Utah
  4. Feb 7, 2024 at 7:17 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  5. Feb 7, 2024 at 7:20 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I've had no issues with mine I got from Amazon. Holes lined up fine and looks good.
    Junkhead and PooTaco[OP] like this.
  6. Feb 7, 2024 at 7:24 PM
    gudujarlson
    Minnesota
    AFAIK, neither Amazon nor Alibaba manufacture skid plates or anything else. They sell other company’s products.
  7. Feb 7, 2024 at 7:52 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    I have that skid, works great did have to move the front bolts to the center and center to the front IIRC. I say go for it
  8. Feb 7, 2024 at 10:01 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have that one that was sold under another name I got from ebay.
    The plate is fine, good thick aluminum. The only 2 downside were a few edges weren't smooth as others and the spacers weren't pre attached in the right locations. Two of the pairs needed to be switched to get it to mount up properly but after that it fit perfectly.
    The port hole to get to the oil filter comes off with 4 5mm hex screws.
    PooTaco[OP] likes this.
  9. Feb 8, 2024 at 12:19 PM
    PooTaco
    Utah
    Ordered.
    Bolt sizes?
  10. Feb 8, 2024 at 12:21 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Did you try using the search function?
  11. Feb 8, 2024 at 12:24 PM
    gudujarlson
    Minnesota
  12. Feb 8, 2024 at 1:57 PM
    PooTaco
    Utah
    I did but wanted to verify the size also, stainless steel hardware is not cheap.
  13. Feb 9, 2024 at 8:11 PM
    PooTaco
    Utah
    I might sand the coating off the bottom, give the skid a raw aluminum finish.
    Bad idea?
  14. Feb 11, 2024 at 10:39 PM
    PooTaco
    Utah
    Quick question on hardware, I plan on adding stainless steel, would I see any issues with adding stainless bolts into the tacoma frame? Would the aluminum skid plate react to stainless hardware?
  15. Feb 11, 2024 at 11:05 PM
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    I’m planning to install a similar generic plate. I do wonder if all the knockoffs look like they were made in the same place, like lostar, kuafu, and the nameless ones that just say Direct Replacement for PTR60-35190, PTR60-35160.
    If you add items to your eBay watchlist, eventually someone will make you an offer with the best discount. Mine arrived a few days ago, but have not had time to unpack and attempt install yet.
    i don’t think it’s worth bothering to attempt to remove the powdercoat. Plus who knows what the People’s Republic Chinese made the powder? coating out of, probably safer not to disturb too much of it in case it’s Pb dust. I may grind or file off any sharp edges. I bet would be too much work to neatly remove the entire coating, unless you have special equipment, or it was coated exceptionally poorly and practically peeling on its own.
    i have a stainless center plate from millercat, and it’s black now with black fluid film. I will probably paint black over the powder coat, fluid film black the knockoff front skid. Same for rear bare aluminum skid when i get one.
    there are other forum threads on these plates, but i’m also curious on verifying thread sizes and bolt sizes, and tried searching before without much that was helpful. Some reviews suggested swapping for new rivnuts was necessary, others suggested everything worked out the box as supplied,and others suggested new bolt hardware only.
    Ultimately i plan to buy a sheet of steel or aluminum to make 2 overlapping flat pieces, to better secure the catguard plate, so if highly organized associations are looking to do some early recycling, hopefully they move on to trucks in whatever parking lot that merely have a single cat guard to remove, unless they are attracted to the extra challenge.
  16. Feb 12, 2024 at 1:51 AM
    PooTaco
    Utah
    What is PB dust?
    I was just planning on removing the bottom layer of the paint for that naked look.
    Mine should be here on Tuesday.
  17. Feb 12, 2024 at 4:14 AM
    ThisBen
    ThisBen Well-Known Member
    Ben
    2019 Toyota Tacoma Sport - MT access cab
    Pb = lead
  18. Feb 12, 2024 at 4:16 AM
    AmateurTaco1313
    ROK
    Enough for now
    it will work fine, don’t over think it man
    PooTaco[QUOTED][OP] likes this.
  19. Feb 16, 2024 at 8:13 PM
    PooTaco
    Utah
    Well, I got my first one last week and the front corner was bent, sent it back for a replacement and the second one came today and was bent even worse than the first one....:mad:
    I'm gonna try one more after contacting the seller, if the 3rd has issues I will look at another manufacturer.
    Bertw192 likes this.
  20. Mar 22, 2024 at 3:06 AM
    explrm0r
    explrm0r I need more money....
    Rock
    Zeeland, Mi
    2020 White Tacoma TRD Sport
    Rago Fab console, DIY DMM
    I have the ECOTRIC version of that skidplate, everything went together really easy and it was in really good condition. Everything lined up, only issue which i havent completed fixed is the back 2 bolts, the smallest of all of them, for whatever reason only go into the weldnuts in the frame about half way. Guessing they might be the wrong thread pitch possibly, or the alignment was off just enough that it cross threaded. I waited a while to put it on because of the great weather we have in Michigan, the weather got nice, i installed it, now the weather is cold and nasty again, so will wait until i fix those back bolts.
    Other than that, i really was impressed with it so far.
