Kyle's SR Access Cab Build
Discussion in '3rd Gen. Builds (2016-2023)' started by kmorgan3, Sep 24, 2019.
  1. Sep 24, 2019 at 11:47 AM
    kmorgan3
    kmorgan3 [OP] Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Introduction and Progress
    Vehicle
    2019 Tacoma SR V6 4x4 in Super White purchased August 20, 2019 in Salem, OR
    I bought the SR because I wanted a canvas to work with. My only requirements were that the truck is a long bed, 4x4, and a V6 to tow. Purchasing the SR meant doing away with a couple convenience features that need to be added later.
    Current as of 11/06/2022
    ~32,000 miles on odometer
    Starting point 08/20/2019
    ~4 miles on odometer
    Build Components
    Suspension
    • Fox 2.5 0-3” Front Coilovers (from Accutune)
    • Total Chaos Spindle Gussets
    • JBA Offroad Upper Control Arms
    • Archive Garage 12" Shock Relocation Towers (2.0 series)
    • Archive Garage Hammer Hangers
    • Archive Garage U-Bolt Flip Kit
      • Archive Garage Yellow Speed Bumps
    • Fox 12” 2.0 Remote Reservoir Rear Shocks (from Accutune)
    • Dobinson's Medium-Duty Leaf Pack
      • Dobinson's Bushing Kit
      • Dobinson's Greasable Pin Kit
    Wheels/Tires
    • Method 701 16x8 0/4.5 Satin Black Wheels
    • 285/75/r16 Falken Wildpeak AT3W
    • Cab Mount Chop + Pinch Seam Flattening
    • Extended rear brake lines from Runnin4Tacos
    Drivetrain
    • Nitro 4.88 Axle Gears
    • ARB RD132 Air Locker (Rear)
    Lighting
    • Custom Retrofit Headlights:
      • Morimoto M LED 2.0 Projectors
      • Custom Amber DRL Boards
        • VLEDS Load Resistors for Turn Signal Function
      • MESO Side Markers (Amber LEDs)
      • Acrylic Turn Signal Cover
      • Matte Black Krylon Paint
      • Custom Wire Harness (TRD -> SR/SR5 Conversion)
    • 40” Single-Row Lightbar (Roof Rack Mounted)
    • Diode Dynamics SS3 Sport Amber Fog Lights
    • Diode Dynamics SSC2 Driving Pattern Ditch Lights (Amber Backlight)
    • Cali Raised Low-Pro Ditch Light Brackets
    • 3" LED Bumper Lights
    • MESO Ultimate 3rd Brake Light
      • 2 amber KC Cyclones
      • 2 red KC Cyclones
    • VLEDS Footwell Lighting Kit
    • LED Reverse and license plate lights
    • MESO Ultimate Map Lights
    • MESO Ultimate Dome Lights
    • Custom Bed Lighting
    • Custom Underhood Lighting
    • Prototype Turn as Tail Harness + Lights
    Other Electrical
    • Custom dual battery setup
      • Slee side-by-side tray
      • 2x Northstar AGM Group 35s
      • RedArc BCDC 1220
      • Bussmann modular fuse holders (400A rating)
      • Military battery terminals
      • Custom brackets and cables all over the place
    • Bussmann RTMR
    • MESO Switch Panel (Left of Steering Wheel)
    • 3D Printed Overhead Console Switch Panel
    • Custom T-Harnesses to Illuminate Switches:
      • Left of Steering Wheel (Cargo Light)
      • Below Head Unit (ECT PWR Switch)
      • Overhead Console (R44 Connector)
    • Custom Aftermarket Switches (OE Blue)
    • MESO Extended Fuse Cover
    • License Plate Light Disable In Reverse
    • Thinkware F70 Dash Camera w/ Hardwire Kit (Park Mode!)
    • Uniden Pro 505XL Bearcat CB Radio
      • Cali Raised CB Antenna Extension
      • 3' Firestik CB Radio Antenna
    • Aftermarket Keyless Entry
    • OEM Remote Tailgate Lock
    Habitat
    • Smittybilt Overlander Roof Top Tent
    • Diamondback SE Bed Cover
    • KB Voodoo Hi Rise Crossbars (Steel)
    Truck Bed
    • BAMF Bed Accessory Mounts
    • Full-size Shovel + Axe
    • At The Helm Bed Channel Stiffeners
    • OEM Bed Mat
    • Mountain Hatch Tailgate Insert (Red)
    • Expedition Essentials Bed Cubby Mount
    • ARB Single Air Compressor
    Exterior
    • Victory 4x4 Access Cab Rack w/ Cutout
    • Victory 4x4 Strike Rock Sliders
    • At the Helm High Clearance Rear Bumper
    • RCI Offroad Front Steel Skidplate
    • Ko'o Gas Cap Cradle
    • Redline Tuning Gas Hood Struts
    • MESO Puddle Pods
    • Fumoto 133S Oil Valve Body
    • Toyota Aluminum Oil Filter Housing
    • Gray Grille Emblem Decal
    • Black TACOMA Tailgate Lettering
    • Black TACOMA Door Emblems
    Interior
    • Expedition Essentials 3TPAM
      • RAM X-Grip Mount
    • Clazzio Seat Covers (Black/Black/Black)
    • Victory 4x4 Center Console MOLLE Panels
    • Custom TRD Pro Shift Knob
    • MESO Steering Wheel Logo Cover
    Taken Off/Sold
    • SOS Concepts Bed Bars - were uneven
    • Faux Predator Tube Steps - flimsy
    • SPC Upper Control Arms - defective bushing and poor customer service
    • TRD Pro Fog Lights - just not bright enough
    • Stock SR5 Black Wheels - not the correct back-spacing for 285's
    • Spidertrax 1.25" Wheel Spacers - kind of a hazard
    • Spyder Auto headlights - flat-out terrible.
    • Interior LEDs - replaced with MESO
    • Custom Fuse/Relay Block - Replaced with a Bussmann
    • Cheap 3" LED Ditch Lights - Replaced with Diode Dynamics SSC2
    • Rear Bilstein 5100 shocks - Replaced with 12" Fox 2.0's
    • Front Bilstein 5100 shocks - replaced with Fox 2.5’s
    • Factory leaf pack w/ 3-leaf AAL - Replaced with Dobinson's Medium
    • Taco Garage DSM - Took off to prototype a new product
    Awaiting Install
    • Custom 3D Printed Switch Panel
      • Retrofit Tundra Cab Light SPDT
    • Diode Dynamics Backlit SSC3's
    • Prototype Bed Lighting System
    • 14" 650lb coils for Fox 2.5's
    • RCI aluminum transmission skid w/ cat guard
    • BAMF Hybrid Front Bumper
      • Winch (TBD)
      • Diode Dynamics 30" Stage Series Lightbar
      • Diode Dynamics SSC2's
      • R4T Bumper Caps
    Planned (Misc.)
    RCI Aluminum T-Case Skid
    RCI 3rd Member Skid Plate
    RCI Aluminum A-Arm Skid Plates
    Rear Bed Track (ripped from a 2nd gen)
    Recovery Boards (mounted to bed track)
    Sound Dampening
    Service Log
    • 3,000 Miles: New springs (OME), shocks (5100), and leafs (Headstrong)
    • 3,100 Miles: New tires (Falken Wildpeak AT3W 285/75/16)
    • 3,300 Miles: 4-wheel alignment
    • 5,000 Miles: Engine oil change @ dealer
    • 7,400 Miles: 4-wheel alignment
    • 8,400 Miles: 4.88 Nitro Gears + ARB Air Locker
    • 9,100 Miles: Axle gear oil change + T-Case oil change (w/ new gaskets)
    • 9,700 Miles: JBA Upper Control Arms installed + greased
    • 9,730 Miles: Engine oil change + tire rotation @ dealer
    • 9,810 Miles: 4-Wheel alignment
    • 10,700 Miles: New seals in front differential assembly
    • 14,865 Miles: 15K service; tires rotated
    • 14,885 Miles: Engine oil change; Fumoto + Aluminum oil filter housing installed | New cabin air filter (OEM)
    • 14,895 Miles: New engine air filter (OEM)
    • 16,621 Miles: Replaced all 3 seals inside ARB Air Locker
    • 16,621 Miles: Rear differential oil drain + fill\
    • 17,212 Miles: New leaf springs + bushings + Fox 2.0's in the rear
    • 17,720 Miles: New rear brake lines + fluid flush with Prestone DOT3
    • 17,767 Miles: Fuel pump recall
    • 17,801 Miles: Greased UCAs + leaf springs
    • 21,153 Miles: Engine oil change
    • 30,950 Miles: Engine oil change + engine air filter + cabin air filter
    • 31,100 Miles: Front/Rear Diff oil change + T-Case + Grease suspension and front U-Joints
    • 31,200 Miles: Tire rotation (front to back no cross)
    • 35,550 Miles: Engine oil change
  2. Sep 24, 2019 at 11:53 AM
    kmorgan3
    Kyle
    PNW
    I have run this truck through its paces this past month. So far, I have decided to keep the truck fully stock as I went through the tail-end of a summer steelhead season and a full archery elk season here in Oregon. I wanted to get a feel for all the quirks of the vehicle -- what I like and what I don't like as I abuse it the way I have abused my vehicles in the past. So far I can say that I am extremely impressed with this truck and am surprised the stock tires held up against the dirt and gravel roads it has run the past 5 weeks.
    Here she is at 2,600 miles (I usually don't drive that much in a month -- it's just this time of year) on 9/24/2019:
    This weekend I will be doing a CMC and installing Bilstein 5100s w/ OME 888's, SPC UCAs, and a 3-leaf AAL with my dad. Any tips would be appreciated. We have the grinder and welder ready as well as all the tools to get the suspension swapped over.
    Next week I will be putting the 33's on.
    irayfz6 and trackdaybro like this.
  3. Sep 28, 2019 at 12:35 PM
    kmorgan3
    Kyle
    PNW
    Driver side strut and control arm is done. Wasn’t too bad except for that stupid UCA bolt. That thing was a nightmare to get out. We used the method without spring compressors to get the new coil and 5100 mated together. Worked way easier than using compressors.
    irayfz6 likes this.
  4. Sep 29, 2019 at 8:05 AM
    kmorgan3
    Kyle
    PNW
    Long day yesterday. Ended up getting the two fronts and one rear done. The leaf springs weren’t as hard as advertised. We got sidelined by rain otherwise I think we would have finished. I got the stock wheels wrapped in the 33’s.
    Today: finish passenger rear. Torque rear shock nuts when vehicle is on the ground. Torque the rear leaf spring bolt when truck is on the ground. Grease new ball joints. Check all rub points and then CMC + trim all necessary plastic.
    irayfz6 likes this.
  5. Sep 29, 2019 at 3:30 PM
    kmorgan3
    Kyle
    PNW
    That’s all she wrote. Got the wheels and tires mounted and balanced. Doctored up the rest of the suspension and took it for a few joy rides. Haven’t noticed any rubbing yet. We’ll hold off on the CMC until the suspension settles and we notice rubbing. For now there’s been 0 need for trimming. We’ll see after I get the alignment, but theoretically that should only push it further from the cab mount.
  6. Sep 30, 2019 at 9:28 AM
    kmorgan3
    Kyle
    PNW
    SOS Concepts bed bars installed. Took a full day to get a decent rattle can job on them, but I think they'll hold my tent nicely.
    Stepsez and irayfz6 like this.
  7. Oct 3, 2019 at 6:50 PM
    kmorgan3
    Kyle
    PNW
    Custom alignment done today. I had them keep toe and camber within factory spec and then set caster to a minimum of +3°. Looks like they barely had to touch the UCA’s to achieve those numbers, but overall pretty happy with it.
    irayfz6 likes this.
  8. Oct 10, 2019 at 8:32 PM
    kmorgan3
    Kyle
    PNW
    Put some black door emblems on so now it actually looks like a Tacoma. Not sure why Toyota decided that door emblems were a place to cut costs on the SR, but whatever. Also got my tent on but had to use shims since my bed bars are very uneven. New bars should be on the way.
  9. Oct 16, 2019 at 1:57 PM
    kmorgan3
    Kyle
    PNW
    Update:
    Ordered new headlight projectors so that I can have LED DRLs and blacked-out reflectors. Installed some knock-off predator tube steps temporarily until I absolutely need sliders (won't be for a while -- I don't wheel much in the winter). I really need to install my keyless entry...
    irayfz6 likes this.
  10. Oct 16, 2019 at 2:07 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Lookin' good so far!
    irayfz6 and kmorgan3[OP] like this.
  11. Oct 16, 2019 at 10:06 PM
    kmorgan3
    Kyle
    PNW
    Here’s the cheap predator tubes from eBay — they work fine for now and look great.
    irayfz6 likes this.
  12. Oct 16, 2019 at 10:41 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Good lookin ride! Can’t wait to see where you go with it!
    kmorgan3[OP] likes this.
  13. Oct 17, 2019 at 9:49 AM
    kmorgan3
    Kyle
    PNW
    Quick shot after cleaning my boat and truck a couple nights ago. So far I haven't noticed much of a power loss towing the boat with the 285's on. Granted my drifter only weighs about 1,200 lbs. When I use the ECT PWR button I'm getting around 15 mpg on the freeway while towing vs. 16 mpg and being slightly underpowered without the button engaged. Without the boat and driving standard freeway miles I am averaging around 19.5 mpg.
  14. Oct 21, 2019 at 1:54 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Sweet set up !
    irayfz6 and kmorgan3[QUOTED][OP] like this.
  15. Oct 21, 2019 at 2:08 PM
    godzilla67
    godzilla67 Well-Known Member
    Portland,Oregon
    2013 Tacoma Regular cab Base Model 2WD
    Great Truck! Got to love the new Oregon plates. I have the same set.
  16. Oct 21, 2019 at 2:35 PM
    kmorgan3
    Kyle
    PNW
    Smokey Bear was a no-brainer when I bought the truck haha.
    Update: Picking up a diamondback se cover later this week. It was a deal I couldn’t pass up. Figuring out a different way to mount my tent now. Really like the KB Voodoo bars.
    irayfz6 likes this.
  17. Oct 23, 2019 at 2:55 PM
    kmorgan3
    Kyle
    PNW
    Planned for this weekend:
    1. Pre-wire everything for fog lights. This includes soldering together a wire harness that has H11 plugs. Have a switch and a relay ready.
    2. Install bed lighting with an always-on (key-independent) switch. Contemplating whether to add a voltmeter in the bed as well.
    3. Install new headlights. This includes pulling out the shitty stock bulbs and upgrading to LED or HID (I have both).
    4. Install Diamondback SE Cover.
    5. Install keyless entry (finally).
    Next week:
    1. Install KB Voodoo bed bars.
    2. Plug fog lights in.
    3. Start planning a fuse/relay block. Probably won't build right away but I'll need a clean way to wire accessories eventually.
    irayfz6 likes this.
  18. Oct 24, 2019 at 2:48 PM
    2017 Oregon Tacoma
    2017 Oregon Tacoma Well-Known Member
    Michael
    Oregon
    2021 Tacoma Off-Road
    Looks Good. You bought yours in Capital Toyota Salem? Thats where I got mine
  19. Oct 24, 2019 at 2:54 PM
    kmorgan3
    Kyle
    PNW
    Yeah I did! They were great. I wanted this specific truck with the blackout package so they searched high and low and found it. They had it trucked-in from Seattle. I guess they did some sort of inventory swap with the dealer up there to get it.
  20. Oct 25, 2019 at 7:44 AM
    2017 Oregon Tacoma
    Michael
    Oregon
    Nice looking build..
