L5 Speaket hits the rear seat... How can I fix it?
Discussion in 'Audio & Video' started by OCTaco, May 26, 2010.
  1. May 26, 2010 at 8:23 AM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    I bought the TacoTunes box for the L5 speaker and installed it behind the rear driveside seat. Whenever I want to bump it, the speaker will hit up against the seat and sound like crap... How can i fix this??? TacoTunes supposively designed the box so this wouldn't happen and im sure i installed it right.
  2. May 26, 2010 at 8:27 AM
    krytikel
    krytikel Well-Known Member
    California
    2017 Tacoma TRD Inferno sport 4X4
    OME lift
    There's 2 things you can do...you can remove the child safety hooks to make the box sit back more or you can try to remove the plastic pieces from the back of the seats. I never removed the child hooks so my seats don't go all the way down when I drop the rear seats. Try removing the plastic from the rear seats first.
  3. May 26, 2010 at 8:28 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    If i do this it's just going to hit the wires and foam on the rear of the seat right? Then it will be the same problem..
  4. May 26, 2010 at 8:29 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    I already cut off the child safety hooks, but idk if i wanna tear up my seat like that. I have cutting stuff out of my truck, its too permanent you know?
  5. May 26, 2010 at 8:29 AM
    krytikel
    California
    OME lift
    It will defiantly let the sub flex more. To do it, you have to remove the rear seats and there should be some phillip screws back there (I think 4 total) and then you just push down on the plastic and it should come off. Hope this helps!
  6. May 26, 2010 at 8:32 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    If i take the plastic off, will the seat still hook? and will the seat be all flimsy?
