La Grange ohv wheel trip May 18th sunday wheel trip for Dave!!!!!!
Discussion in 'Northern California' started by SpeedwayBlueAlex, Apr 30, 2014.
  1. May 20, 2014 at 5:41 PM
    #421
    TRDrunner
    TRDrunner Well-Known Member
    Victor
    Vacaville
    2014 Tacoma TRD Offroad
    Oh definitely! Im excited to see it cause if it works then I may do it in the future!
  2. May 20, 2014 at 6:06 PM
    #422
    the glen
    the glen Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Hey Dave, where r u trying to relocate the shock to? I'm actually hitting the collar of my driver's side shock on the band that wraps around my leaf spring. The 2.5 icon is a fat ass shock. I would like to move it so it looks like the passenger side. Will the relocation work for my situation?
  3. May 20, 2014 at 6:31 PM
    #423
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    The relocation moves them so they are strait up and down.
  4. May 20, 2014 at 9:31 PM
    #424
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    not quite...it's a 9* angle of the shock and they are both facing \ of the rear axle
  5. May 20, 2014 at 9:33 PM
    #425
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Glen for your situation it may help but the relocation is for 12" shocks. You would need to buy new 12" shocks and relocate them. The 12" shocks being used in the relocation kit are 2.0 not 2.5 like you have. If I were you I would maybe try a different leaf pack to see if it is that Deaver pack that you are running.
  6. May 20, 2014 at 9:34 PM
    #426
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Glen check this out:
    http://www.tacomaworld.com/forum/ba...-b-m-f-2nd-gen-rear-shock-relocation-kit.html
  7. May 20, 2014 at 9:55 PM
    #427
    SpeedwayBlueAlex
    SpeedwayBlueAlex [OP] Well-Known Member
    Alex
    Modesto
    SWB 4x4 TRD OFF-ROAD 6-SPEED
  8. May 21, 2014 at 7:49 AM
    #428
    the glen
    Glen
    penisula
    Hey Dave, so I talked to yoga Dan at wheelers off road in Oregon, where I got my icons, and apparently quite a few people have this same issue. He recommended taking off the one band that is hitting the shock. Removing just one won't hurt and should stop the rubbing. I'll give it a try so I don't trash these expensive mofos.
  9. May 21, 2014 at 8:21 AM
    #429
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Yoga dan... Awesome.
  10. May 21, 2014 at 9:26 AM
    #430
    SpeedwayBlueAlex
    Alex
    Modesto
    Hahaha:rofl:
  11. May 21, 2014 at 10:09 AM
    #431
    the glen
    Glen
    penisula
    Yota Dan, stupid auto correct.
  12. May 21, 2014 at 4:37 PM
    #432
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    yes sir. Alex I told you before...Do it right the first time. If you are dead set on LT then save up and go LT. 12" relocation is gonna net you 2" more rear travel but will cost close to $1,000 (new shocks, new leaf pack, extended brake lines, new bump stops, the BAMF kit, installation (needs to be welded).
  13. May 21, 2014 at 4:39 PM
    #433
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Good call! Taking off one of the leafs? or the band that wraps around the leafs (whatever you call that thing "clamp"?) For some reason the Deavers rub the 2.5s and I'm not sure why? Where exactly is the shock body contacting the leaf springs?
  14. May 21, 2014 at 4:41 PM
    #434
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Yeah Glen those 2.5s are badass man...I know for sure better than the 2.0s. After wheeling at LG all day I felt the shock body on my 2.0s and could feel them heated up pretty good. I want to get a thermometer or whatever you need to measure the temperature on the shock and see exactly how much I'm heating them up. 2.5s will definitely keep cooler longer after miles and miles of abuse. Definitely worth the extra $$$ if you are gonna be wheeling long distances and running in the desert for sure :thumbsup:
  15. May 21, 2014 at 4:44 PM
    #435
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
  16. May 21, 2014 at 7:16 PM
    #436
    the glen
    Glen
    penisula
    Thanks Dave, yeah I remember reading that before I got them. It kinda pushed me in that direction. I need to find some fire roads where I can get a little more speed.
  17. May 21, 2014 at 7:35 PM
    #437
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Yeah that sounds like a blast
  18. May 21, 2014 at 9:13 PM
    #438
    SpeedwayBlueAlex
    Alex
    Modesto
    Yeah you're right I just need to do it right the first time instead of being impatient like always am thanks dave youre the man
  19. May 28, 2014 at 7:47 PM
    #439
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    La Grange FTW!!!!!! :D
  20. May 28, 2014 at 8:38 PM
    #440
    SpeedwayBlueAlex
    Alex
    Modesto
