Larger Towing Capacity?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geaux1022, Jan 17, 2010.
  1. Jan 17, 2010 at 1:44 PM
    geaux1022
    geaux1022 [OP] New Member
    Hi everyone, new member here. You guys have a great site, and I was hoping you could help me out with a towing capacity question.
    I have a boat+trailer that weighs around 3,500 lbs fully loaded. I'm in need of an upgrade from my current SUV, an old Jimmy. I'm considering purchase of a 2005 Tacoma with the following specs:
    Prerunner 2WD
    4.0L V6, 245 hp and 282 lb-ft. of torque
    No towing package
    Would this allow for a comfortable tow for my boat? I would add an aftermarket receiving hitch prior to towing and the 60 minute ride to the lake requires only small hills. I know the listed towing capacity of the truck is 3,500 lbs, right at the weight of the boat, but that's also the listed capacity for the smaller 2.7L, V4's from the same year. Wouldn't there be some added capacity here considering the larger engine?
    I've been searching around the Internet for the answer to my question with no luck, so if this has already been addressed I apologize in advance.
    Thanks much for your help.
  2. Jan 17, 2010 at 2:36 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you're towing, I'd try to find a factory tow package. If not though, at least get a transmission cooler added. My truck's limit (prerunner v6 trd off-road) is 6500lb max weight. I've tow'd close to that, it wasn't all that fun lol. However I tow'd my 280z full of stuff + dolly was probably right at about 3500lb and it didn't even seem to hardly phase it. I was passing a lot of people going up 6% grades doing about 70+ (Grants Pass, OR)
  3. Jan 17, 2010 at 2:39 PM
    VancityCK
    VancityCK Well-Known Member
    Vancouver
    09 Magnetic AC TRD Offroad
    Tow capacity for a v6 without tow package is 5,000 lbs. Get a sufficiently rated hitch and you're good to go. I regularly tow close to 4,000 lbs with mine, no problem.
  4. Jan 17, 2010 at 2:46 PM
    Silver 10
    Silver 10 Well-Known Member
    Joe
    Valparaiso, Indiana
    10 SR5 DBL Cab 4x4
    Nitto Terra Grapplers, Leer XL100 cap , Cabelas Bug shield , Tinted windows, Bed Mat, Husky Floor Liners front and rear, seat belt mod, Rear TSB, K&N Air filter
    get a class III hitch and trans cooler and you should be fine. I think the factory also comes with an oil cooler as well. I dont foresee this being an issue. I would say to tow in 4 not overdrive. It will tow 3500 better than your jimmy. Good luck
  5. Jan 17, 2010 at 3:17 PM
    JKD
    JKD Well-Known Member
    You sure about that? I thought it was 3500 if you didn't have the tow package.
  6. Jan 17, 2010 at 3:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    It would seem you are correct sir!
    Code:
    [B]Weights and [URL="http://www.toyota.com/help/glossary/213.html"]Payload[/URL]/Towing Capacities[/B]
                                              Curb weight (lb.)
                    3835
                                              Gross Vehicle Weight Rating (GVWR) (lb.)
                    5250
                                              [URL="http://www.toyota.com/help/glossary/213.html"]Payload[/URL] [B][URL="http://javascript%3Cb%3E%3C/b%3E:TMSSite.disclaimerHotlink%28'/disclaimers/payload.html'%29;"][3][/URL][/B] (lb.)
                    1415
                                              Tongue load (lb., standard/maximum)
                    350/650 [B][URL="http://javascript%3Cb%3E%3C/b%3E:TMSSite.disclaimerHotlink%28'/disclaimers/max_tow.html'%29;"]
    [*][/URL][/B]
                                              Standard towing capacity (lb.) [B][URL="http://javascript%3Cb%3E%3C/b%3E:TMSSite.disclaimerHotlink%28'/disclaimers/tow.html'%29;"][4][/URL][/B]
                    3500
                                              Maximum towing capacity (lb.) [B][URL="http://javascript%3Cb%3E%3C/b%3E:TMSSite.disclaimerHotlink%28'/disclaimers/max_tow.html'%29;"][5][/URL][/B] [B][URL="http://javascript%3Cb%3E%3C/b%3E:TMSSite.disclaimerHotlink%28'/disclaimers/tow.html'%29;"][4][/URL][/B]
    Check out the Toyota Guide to Towing to learn the proper techniques:
    [URL="http://www.toyota.com/pdfs/towguide_part1.pdf"]PART 1[/URL]
     Selecting the Right Toyota Truck or SUV for Your Towing Needs
    [URL="http://www.toyota.com/pdfs/towguide_part2.pdf"]PART 2[/URL]
     Towing Trailers, Boats & Driving with a Trailer
    [URL="http://www.toyota.com/pdfs/towguide_part3.pdf"]PART 3[/URL]
     State Towing Laws, Toyota Tow Ratings & [URL="http://www.toyota.com/help/glossary/213.html"]Payload[/URL] Capacities
                    6500
                                              Gross Combined Weight Rating (GCWR) (lb.) (with Towing Package)
                    8100 (11,100)
                                              [B]Fuel tank (gal.)[/B]
                    21
    [COLOR=Red][B]
    "Maximum towing capacity and tongue capacity requires V6 engine with available Towing Package. See Owner's Manual for details."[/B][/COLOR]
    http://www.toyota.com/tacoma/specs.html
  7. Jan 17, 2010 at 3:32 PM
    VancityCK
    Vancouver
  8. Jan 17, 2010 at 3:36 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I'm pretty sure the canadian taco's also have the oil coolers already installed in all vehicles too. I could be wrong... but I got my specs from the u.s. site...
  9. Jan 17, 2010 at 3:43 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Per USA site..
    6500lb towing capacity.
    Notes:
    (1) When equipped with optional Tow Package. Without Tow Package, standard tow capacity is 3500 lbs.
  10. Jan 17, 2010 at 4:14 PM
    geaux1022
    Thanks to everyone who has responded so far - I appreciate the help. In trying to find my answer I ran into the same confusion and conflicts between sources that you guys are seeing. I mentioned this in my first post, but even though it's listed almost everywhere as 3,500, it blows my mind that it would have the same capacity as the 2.7L engine. I could easily be missing something though.
    I'm not sure this is smoking gun proof, but since my OP I found the following, which is not Canadian but also suggests the 5,000 number earlier referenced:
    http://www.toyotaoffroad.com/Articles/Toyota/2005_Tacoma/2005_Tacoma_s.pdf
  11. Jan 17, 2010 at 5:07 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Without the tow package, the 3500lb limit probably comes from the ball mount in the bumper being a class II hitch. If you add a class IV receiver you should be able to handle 5k-6.5k lb, but I'd agree with others who reccomended the trans cooler (assuming an AT), especially for summer use.
    Leaf springs may or may not matter depending on the trailer. If you're using a 4-wheel trailer there'll usually be less tongue weight. None of the brochures ever mentioned anything about the tow package including different springs, but you might want to check if the truck you're looking at is covered by the TSB for the rear spings and if the fix has been done since you'll probably want that if you'll be towing/hauling much.
  12. Jan 17, 2010 at 5:21 PM
    Silver 10
    Joe
    Valparaiso, Indiana
    10 SR5 DBL Cab 4x4
    Just roll with it. You wont have a problem this just get the class III or IV and an oil cooler, you wont have problems, its 3500LBS not 6000
  13. Jan 17, 2010 at 6:07 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    The truck w/o the tow package does not come with a hitch so all tow ratings are based on a bumper mount ball. That also includes a max of 350# for the tongue weight. Anything more and you'll rip the bumper off or bend the hell out of it.
    IMO if you're going to tow anything but a small rental trailer then you're going to want to tow package and the good class IV factory hitch.
  14. Jan 17, 2010 at 6:14 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    True
  15. Jan 19, 2010 at 9:41 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    so if i have a TRD OR package with the tow package, i can haul 6000lb?
  16. Jan 19, 2010 at 12:28 PM
    bmgreene
    Brian
    L.A. Westside
    Manual says 6500 lb. Obviously performance will vary depending on what sort of terrain/climate you're trying to do that in (not sure I'd reccomend trying to tow 3 tons over some of the passes around Lake Tahoe at 2PM in the middle of summer, for example), but on a relatively flat run you should be all right.
  17. Jan 19, 2010 at 12:36 PM
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
    Thanks dont think i will ever haul anything over 3000 lb but dosent hurt to know what your truck is capable of
  18. Jan 19, 2010 at 1:25 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Towing is not as much about power, as it is braking.
    Think.
  19. Jan 19, 2010 at 1:46 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I've towed close to or just over 6500lbs... you know it's there. However, it made it up free-way overpasses and everything with really no issue around 40mph and not pushing it all that hard in the power band/gear. They're surprisingly capable... however the trailer was driving me more than I was driving it.. that's what scares me more than engine power.
  20. Jan 19, 2010 at 5:22 PM
    j4x4ar3
    Jay
    Austin, TX
    Sorry but you're wrong in this case. In most states any trailer more than 1000# has to have it's own brakes. (some states it's 1500-2000#). The truck brakes are designed to stop the truck at minimum it's GVWR and trailer brakes are designed to stop the trailer at the minimum of it's GVWR so stopping isn't really the issue if your trailer brakes are setup properly.
    There are way to many nuances into towing properly as you can be under your tow capacity yet over the GVWR for your truck... even worse over your payload capacity. A properly matched trailer/truck is the key even if pushing the max for the GVWR and payload of the truck. The only downside of towing at your max time after time is extra wear and tear on your truck. For the occassional towing it's not a big deal.
    BTW if you're ever in any towing forums and the guys with the "big trucks" all try and tell you that you'll be slow going up hills and not have enough power, tell them to go pound salt because I've seen many a 1 ton DRW hauling a large 5er going pretty darn slow... I've even passed a few pulling my trailer.
