Largest size tires on 3in lift
Discussion in 'Wheels & Tires' started by xxsoccafreak09xx, May 19, 2011.
  1. May 19, 2011 at 9:15 PM
    xxsoccafreak09xx
    xxsoccafreak09xx [OP] Well-Known Member
    Louisiana
    2009 Prerunner Lifted
    17" dick cepek rims with 33" nitto mudgrapplers tires, 3" lift, Fishing rod rack.
    I have a 2009 tacoma prerunnner trd, looking for some new tires. i have 33x12.5 17r and looking for some 35s but will the 35s fit??
  2. May 20, 2011 at 4:58 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Only if you have an aftermarket front bumper and are also filling to cut your fenders......not the fender plastic, the actual metal fenders....
  3. May 20, 2011 at 6:46 AM
    xxsoccafreak09xx
    Louisiana
    so its more complicated than just cutttin the plastic? and the 4.0 will not push those big tires that good
  4. May 20, 2011 at 6:47 AM
    TexasTacoma37
    Most who switch to 35's regear, but some are running them on stock gears....
    And yes it's way more involved than just cutting plastic.
    Check out these member's builds, they have all fit 35's on a 3" of lift
    relentlesstaco
    jhodge83
    1337taco
  5. May 20, 2011 at 6:48 AM
    robdawg14m
    robdawg14m Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Apline IDA-X100 Head Unit Massive P 950.5 Amplifier 100x4 + 550x1 Diamond Audio 10" D1 Sub Focal K2 Component 165KR Debadged 33x12.5 Toyo MT 18" ATX Artillery Toytec ultimate lift kit LR UCA's Wet Okole seat covers
    Buy some aftermarket fenders and you will be good.
  6. May 20, 2011 at 6:51 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    no you wont.
    i have my fenders flares removed, cab mounts chopped, and metal fender trimmed, and cut out the pinch weld to clear my 305s (wide 33s). For 35s, u will need to do this and more.
  7. May 20, 2011 at 6:55 AM
    xxsoccafreak09xx
    Louisiana
    i have been looking for bfgoodrich km2 and found 35s for 260 a piece but cannot find any 33s!!!!!
  8. May 20, 2011 at 7:01 AM
    especk
    Erik
    Redding, CA
    i have pics of what i had to cut away on page 12 of my build page. Look at the pics near the bottom of thatpage.
    if u cant find KM2s in that size for whatver reason, duratracs are a good tire and nitto makes good tires also.
  9. May 20, 2011 at 7:04 AM
    xxsoccafreak09xx
    Louisiana
    yea my buddy has some duratracs and he got them for a fair price, nitto tires are too expensive
  10. May 20, 2011 at 7:09 AM
    xxsoccafreak09xx
    Louisiana
    do you know a good website for cheap tires???
  11. May 20, 2011 at 7:11 AM
    especk
    Erik
    Redding, CA
    www.tirerack.com . Ive never ordered from there but i use it as a good source for info. I heard its about 50 cents per pound for shipping. I think those tires weight about 50 lbs each - so shipping will be about $100 for 4 tires
  12. May 20, 2011 at 7:15 AM
    xxsoccafreak09xx
    Louisiana
    alright thanks
  13. May 20, 2011 at 7:17 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Might want to check tirecrawler.com as well. Crazy cheap prices and just about normal shipping costs, depending on your location.
  14. May 20, 2011 at 7:23 AM
    xxsoccafreak09xx
    Louisiana
    thanks, onlinetire.com has some really good prices but not the size tires i want
  15. May 20, 2011 at 8:40 AM
    tacocrum
    tacocrum Member
    Arkansas
    09 PreRunner SR5 TRD Sport
    none.....but ever hopefull
  16. May 20, 2011 at 8:50 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    My 285/70/17's are basically 33's. I think it converts to like 32.89 or something close to that.
  17. May 20, 2011 at 10:41 AM
    xxsoccafreak09xx
    Louisiana
    why are the numbers on the tires different
  18. May 20, 2011 at 12:29 PM
    robdawg14m
    robdawg14m Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Exactly, you removed your fender flares. I am talking about buying fiberglass, and the pinch weld is a given for 35s.
  19. May 20, 2011 at 2:21 PM
    especk
    Erik
    Redding, CA
    my bad. i thought you meant aftermarket fender flares, not actual glass fenders.
  20. May 22, 2011 at 10:12 PM
    808Renato
    808Renato Well-Known Member
    Renato Medeiros
    Kauai
    16 MGM DC 4x4 6spd Manual
    [​IMG][​IMG][​IMG]
    18"x10" wheels wrapped on 325/60/18 Mt (no rubbing)
    Must do: Cut plastics/fender, remove flaps
    Recommend: chop cab mount (Pic #3)
