LARGEST TIRES ON STOCK 2004 TACOMA V6 4X4???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Aug 1, 2011.
  1. Aug 1, 2011 at 9:26 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    When I put some new 265/75/16s on my truck when I first got it, the tires rubbed on the frame. Maybe it's because yours was a reg cab or my bfgs are more aggressive tread? Here's a VERY old thread with my tire rub issues lol.
  2. Aug 1, 2011 at 9:35 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Ya that could be...weird.
  3. Aug 1, 2011 at 9:38 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    mine barely rub at full turns...
  4. Aug 1, 2011 at 9:39 AM
    kmok
    Kyle
    Columbus, Ohio
    After I put on small wheel spacers the problem went away. It still rubbed inside the fender well a little still but it wasn't that big of a deal and it was probably because my front coils were completely shot.
  5. Aug 1, 2011 at 9:40 AM
    kmok
    Kyle
    Columbus, Ohio
    What tires do you have? :confused:
  6. Aug 1, 2011 at 9:40 AM
    ColtsTRD
    Scott
    AZ
    yea I guess it all depends on the circumstances...like tires and body style I guess. But I had no rubbing at all.
  7. Aug 1, 2011 at 12:01 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I am also running 265/75/16s and the only rubbing issue I have is because the plastic liner that is bolted under the wheel well keeps coming a little loose and it rubs a little. I just have to tighten a bolt every once in a while and it doesn't rub anymore. Oh and my coils are also in pretty bad condition, so that probably doesn't help much.
  8. Aug 1, 2011 at 12:10 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    bfg a/t's
  9. Aug 1, 2011 at 12:40 PM
    kmok
    Kyle
    Columbus, Ohio
    Alright he may or may not have minor rubbing with 265/75/16s :cool:
  10. Aug 1, 2011 at 12:48 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I don't recall my MT's rubbing in that size, but I didn't really wheel it either. the BFGs on my new wheels (slightly different BS from stock) rubbed the fender liner until the lift. It wasn't bad though.
  11. Aug 1, 2011 at 12:55 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    The stock tires are either P or LT265/70R16 which is a 31 inch tire. You can use a LT265/75R16 which is a 32 inch tire. To go any larger you would need a lift and a wheel spacer or different rims. Stock rims are 7 inches wide with 6 lugs on 5.5 inch spacing but the off set is too wide to use a wider tire since it will rub the upper ball joint unit thus requiring a wheel spacer or different rims for the front wheels. The stock rims in the rear are OK for large tires. The recommended rim for a LT285/75R16 tire (33 inches) is 7.5 inches but most tire shops will put them on a 7 inch rim. The advantage of a 7 inch rim over a 7.5 inch or larger rim is that it acts as a poor mans bead lock when you air down the tires.
  12. Aug 1, 2011 at 1:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    My tires rub on the frame, to the rear of the suspension. Driver side rubs a little worse (more paint worn off).
    I have 265/75R16s now, and I'm getting 70's when these are done (soon)...
  13. Aug 2, 2011 at 9:29 PM
    joeer77
    joeer77 Active Member
    North Plains OR
    Bilstein 5100s
    I have 2004 V6 TRD 4X4 extended cab. For some reason my stock 265/70/16 BFGs would rub on the chasis (enought to remove paint). Replaced stock rims with Mickey Thompson 16x8 on 3.5" offset. Still rubbed. Upgraded to 265/75/16 Goodyear duratracs and 2.5" Bilstein 5100s. Still rub at full turn and have to remove mud flaps to offroad. Tires just rub on this truck unless you are willing to start trimming plastic and metal.
  14. Aug 3, 2011 at 5:34 AM
    TacomaPilot2004
    TacomaPilot2004 [OP] Active Member
    Miami, FL
    2004 Tacoma V6 4x4 Crewcab
    Thank you so much everyone!! Your input has really been helpful. I'll let you guys know what I end up going with and if I have any rubbing issues. :)
  15. Aug 4, 2011 at 5:16 AM
    #35
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    265/70/17 .... get a small amout of rubbing at full lock but not all the time, depends on angle of truck.
  16. Nov 7, 2016 at 7:38 AM
    #36
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Nice Truck;)
    I have 16x8 Procomp 8069 and 265/75/16 BFG all terrains. Left, 2.5" coilover in the front and stock rear.
  17. Nov 7, 2016 at 9:55 AM
    #37
    viverr
    viverr Member
    WA
    '02 dcsb
    Since you're looking at wheels as well, don't get anything other than the stock backspacing on 265/75r16 without a plan to lift the ride height and beat down the pinch weld. You'll rub like a mofo.
  18. Nov 7, 2016 at 11:15 AM
    #38
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I want tall skinny tires
    I have a 4 cyl double cab
    Currently it has 225/70/16
    What would you recommend size wise ?
  19. Nov 8, 2016 at 7:42 AM
    #39
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
  20. Nov 8, 2016 at 8:28 AM
    #40
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    This thread is old as hell but heres a guide to fitting tires without lift
    31s- with no modification (i mean... 31s were a factory option)
    32-33s- with basic trimming and pinch weld mod (average guy can do with basic tools)
    35s- inner fender tub aswell as outer fender trim (skilled guy with welding/metal working experience required but quite doable)
    37s- cutting fucking everywhere and lots of tears(the handful of people that have done it have to be questioned for their sanity)
