LARGEST TIRES ON STOCK 2004 TACOMA V6 4X4???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Aug 1, 2011.
  1. Nov 8, 2016 at 2:07 PM
    #41
    eon_blue
    Azusa, CA
    I'm going to go slightly larger than the stock 31's on my next set, but the problem I'm having is that I'm already rubbing my stock size 31's when doing a full turn and going over a bump in the road/off-road, even with 2" lift up front. The aftermarket wheels my truck came with have some funky backspacing is my best guess. They rub the pinch weld.
    What kind of basic tool/s to do the pinch weld cutting? Will a dremel rotary saw do the trick?
  2. Nov 8, 2016 at 3:00 PM
    #42
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Side snips for plastic. bfh for pinch weld. you should always trim tires to work for the full suspension travel. take the strut out and jack the suspension up to bump stops and clear them that way. dont rely on lift for clearing tires (coilover lifts anyways)
    eon_blue[QUOTED] likes this.
