Largest Tires to clear on 09 2WD Base Reg. Cab
Discussion in '4 Cylinder' started by motoretro, Jun 6, 2010.
  1. Jun 6, 2010 at 9:19 PM
    motoretro
    motoretro [OP] Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I'd like to put some larger rubber on my 09 2WD Base 5 lug Regular Cab and perhaps some different wheels. I really don't want to lift it, just bigger tires to fill the wheel wells and add a little more ground clearance. I'm thinking 235/75/15" or maybe a 16" wheel. I'd like to run a 7" wide wheel, will it clear the caliper on these trucks? I'm a old guy and would like a wheel which looks old school and sits under the fender w/o excess stick-out. Are the factory wheels hub-centric? An alloy wheel would be great as long as it's something I can run year around, so clear-coat might be a given.
    Any ideas or suggestions would be appreciated.
    Motoretro
  2. Jun 7, 2010 at 6:17 AM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    I am currently running on my 08 base 5 lug 4 cyl. 235/75/15 And i have no issues with fitment. The tires fit on a stock rim and they look good and add about an 1" of clearance from the ground. The only issue i had was power was reduced for a i do a lot of highway driving, but in the city and didnt change much. I am running BFG All Terrains and they are great
    Hope that helps
    Brad
  3. Jun 7, 2010 at 11:49 AM
    motoretro
    Michigan
    Brad,
    Thanks for the confirmation & help:thumbsup:, I plan on re-gearing to a 3.73 or 4.11 to gain the power back once tires are switched. Stock wheels are 6" between beads, right?
    Motoretro
  4. Jun 7, 2010 at 4:59 PM
    Cappy Cap
    Boston
    08 Reg. Cab
    Yeah, i dont know what bead spacing is sorry but if you mean the width of the wheel, yeah its 6". The tire recommends a 6.5" minimum width wheel, but i have had them on for over 30k and no issues, the place i had them installed also said this wont be an issue. I re-geared my truck to a 3.73 and it is a little better than it was stock. I am averaging aroung 23-25 mpg, so it wasnt that much of a loss. the only issue is your speedo and odometer are f*ed lol. You just have to find that out and always keep it in mind. When the speedo says 90 im really at 80, and thats about 3ooo rpm, which isnt bad doesnt hit the powerband yet unless you step on the gas hard. If you plan on re-gearing i would like for a used third member from like a pre-runner or sumthing, thats where i got mine off of, just make sure it doesnt have an e-locker. Anyways hope this helps.
    Brad
  5. Jun 7, 2010 at 5:10 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    i have a 225 75 15 on mine with no probs. dont notice much difference in power, at least i dont.
    there a toyo open country a/t
  6. Jun 7, 2010 at 8:02 PM
    motoretro
    Michigan
    Thanks for the info and pics guys. Not sure how things are measured now although when buying wheels back in the day we considered the distance between the beads the wheel width. I checked out some wheels sites and a few are measuring edge to edge so maybe things have changed. I'll have to look into this further.
    Cappy, did you get your rear from a V6 Pre-Runner, I think the 4 cylinder Pre-Runners came with 4.11's
    Motoretro
  7. Jun 7, 2010 at 10:26 PM
    prdltakid
    prdltakid Dick Richards III
    Dick
    Kaneohe, Oahu, HI
    08 4x4 5spd Tacoma
    I've got 265/75/16s Kumho on mine and then fit well. Look better then the stock tires also.
    yeauxta330 likes this.
  8. Jun 8, 2010 at 5:24 AM
    Cappy Cap
    Boston
    08 Reg. Cab
    Motoretro,
    Thats the wonderful thing with these trucks theres about 5 different variations of the third members. I got mine off of a 6 cyl. pre runner their third memebr is a 3.73, if you get it off of a 4 cyl. pre-runner it will be 4.11, im not sure if the tranny will affect that setup it may. So if i decide to regear again i will get it off a 4 cyl. pre-runner. Funny isnt it?
  9. Jun 13, 2010 at 12:22 PM
    sjdm4211
    sjdm4211 Member
    Tennessee
    Toyota Tacoma 2WD 2.7L
    I put some 235/75 R15's Goodyear Wranglers on my 06' 2WD. There is plenty of clearance for a larger tire but I don't think any bigger of a tire would fit on the rims. I haven't noticed any loss in power but I installed a CAI around the same time. Gas mileage wasn't affected as I got 25 MPG on my last fillup.
    I wouldn't go with a 16" wheel mainly because the cost of tires is going to go up dramactically. Stick with the 15" stock wheels and go with the 235/75 R15's. If you want something nicer looking than the stock wheels take a look at these: http://www.hubcaphaven.com/mm5/merc..._Code=HC&Product_Code=3796&Category_Code=1829
    I plan on buying a set as soon as I have some extra cash.
    Joseph
  10. Jun 14, 2010 at 7:17 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I put 235-70-15s on my 5 lug. It made my speedometer agree with my GPS. It also locked down the handling on windy bridges.
    I may have lost a little bit of power on the Interstate but not enough to matter.
    Mileage is consistent.
  11. Jun 14, 2010 at 9:55 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    the largest tire I had before the lift and on stock steelies was 30x9.5
  12. Jun 14, 2010 at 9:04 PM
    motoretro
    Michigan
    Thanks for the help guys:cheers:.
    By sticking with the stock 15" rims w/ 235/75 or 235/70 tires the tires should still stay inside the fenders.
    Motoretro
  13. Jun 18, 2010 at 4:09 PM
    AlexA
    AlexA Well-Known Member
    Alex
    Newport News, VA
    2012 DCSB Prerunner SR5
    i put 30's on after market wheels with no lift
  14. Jun 18, 2010 at 4:57 PM
    motoretro
    Michigan
    Which aftermarket wheels did you go with? size?
    Thanks,
    Motoretro
  15. Jun 18, 2010 at 4:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    He's a 5 lugger. Those wont come close to fitting.
  16. Jun 18, 2010 at 9:19 PM
    jakara059
    jakara059 Member
    JB
    Missouri
    2WD I4 Manual
    I went with 235/70/15s also...Goodyear Wranglers. Looks great..fills out the wheel well nice and even looks good around stock wheel. However, does anyone know if my odometer will be a little off now and how I would fix that if so?
  17. Jun 19, 2010 at 1:34 AM
    AlexA
    Alex
    Newport News, VA
    cragar soft 8's. 15x8 with 4.5'' of backspacing
  18. Jun 19, 2010 at 5:35 AM
    Barnone
    Barnone Guest
    Check your odometer with mile markers on the interstate or with a GPS. Do several tests at say 10 miles with different sets of mile markers to verify the results.
    There are devices that you can add to correct the odometer but usually just a correction percentage will do.
  19. Jun 19, 2010 at 11:24 AM
    jakara059
    jakara059 Member
    JB
    Missouri
    2WD I4 Manual
    Using the tire guide tutorial on this site...it says the base tire to the 235/75/15 is about 7% diff. Question: If the speedometer is 7% more is that an exact correlation to the odometer?
  20. Jun 19, 2010 at 7:15 PM
    motoretro
    Michigan
    My guess is it will read about 4 MPH high since stock speedo tends to read 3 MPH low.....
    Motoretro
