Largest Tires to clear on 09 2WD Base Reg. Cab
Discussion in '4 Cylinder' started by motoretro, Jun 6, 2010.
  1. Jun 19, 2010 at 7:16 PM
    motoretro
    motoretro [OP] Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Thanks for the scoop on wheel info although are you sure about the backspacing? Cragar site showed only 4" I believe. Any pics?
    Motoretro
  2. Jun 20, 2010 at 7:01 AM
    AlexA
    AlexA Well-Known Member
    Alex
    Newport News, VA
    2012 DCSB Prerunner SR5
    not sure on the backspacing but heres a pic
  3. Jun 20, 2010 at 11:13 AM
    motoretro
    Michigan
    Thanks for the pic, looks great.
    Motoretro
  4. Jun 25, 2010 at 10:45 AM
    Goatus
    Goatus Well-Known Member
    Dillon
    Asheville, NC
    2011 TRD Off-Road TX MGM
    Floor Liners, AFe Filter, Leer Cap, Bed Mat, Roof rack, Cap Rack, Rack Rack, Burt Bacharach
    When Running my 5-lug with stock 215/70r15 my speedo read 65 when I was really doing 62 according to GPS (which is dead on in my wife's Honda Fit).
    With 235/75r15 when my speedo reads 65, GPS says I'm Going 66. So I would imagine with 225/75r15s or 235/70r15s it should be about dead on.
  5. Jun 25, 2010 at 11:05 AM
    motoretro
    Michigan
    Goatus,
    Good info to have, Thanks
    Motoretro
  6. Jun 25, 2010 at 11:20 AM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    if your looking to run larger wheels i would get teh 30" tires, they measure .5" larger than the 235/75/15 which is a 1/4" wider each side. Those will allow you to run 8" wheels which are the more common truck size tire. I havent found a set of 7" truck wheels, i only see the sporty 5 spokes. When i need new tires i will get the 30" and wider wheels. Dont get me wrong though, i do muchly enjoy my AT's at 235/75/15 they should have come stock right out of toyota, and it does make the speedo correct till i re-geared which screwed it up royally lol. and the 29" tires i have now fit no prob. still have good clearence
  7. Jun 25, 2010 at 11:26 AM
    Goatus
    Dillon
    Asheville, NC
    Don't 30s require you to trim and take out the black boxes from behind the wheels? or is that 31s?
  8. Jun 25, 2010 at 12:50 PM
    motoretro
    Michigan
    Cappy,
    I don't care for the way 8" wide wheels kick the tires out close to or just beyond edge of body so I'll either run stock 15x6" wheels, Cragar Soft 8's or something equivalent in a 15 x 7" size. If i can get a nearby tire dealer to mount up both I try them for looks and then decide. I know I'll have to re-gear to get the power back down where i want it. I need to find a quite tire in 235/75/15 that still works reasonably well in snow, dirt, etc
    Motoretro
  9. Jun 28, 2010 at 6:33 AM
    Cappy Cap
    Boston
    08 Reg. Cab
    Goatus,
    I dont see why the 30's would make you cut out the black box, they are only 1/4" wider than the 235's, but i could be wrong. Correct me if i am
    Motoreto,
    if you can find a nice truck wheel at 7" wide i would like to know too. I would actually get a set of those and continue to run the 235's. The only difference between the 235's and 30's is like 1/2" or so. I wish the 235's had the ability to run the 8" wheel. The only reason i would get the 30's is for the 8" wheel. I dont think it would stick out at all, but again i could be wrong. I would actually like the tires to be a little wider, for better traction and handling purposes, at least thats what i think it would do.
    but again 2 each is there own,
  10. Jun 28, 2010 at 10:41 AM
    AlexA
    Alex
    Newport News, VA
    i had to remove the black box when i installed my 30's
  11. Jun 28, 2010 at 10:54 AM
    Goatus
    Dillon
    Asheville, NC
    Thanks for the confirmation man!
    So I would say that 235/75r5 is the largest you can go without modding at all.
    Does anyone know if 31x10.5 will fit non-lifted but with the black boxes off?
  12. Jun 28, 2010 at 1:01 PM
    Cappy Cap
    Boston
    08 Reg. Cab
    thanks thats good to know.
    How do you remove the black box, and do you have to fill it when its off?
  13. Jun 28, 2010 at 2:32 PM
    AlexA
    Alex
    Newport News, VA
    if i had to guess i am pretty sure u could fit 31's no lift, but definitely need to remove the black box.
  14. Jun 28, 2010 at 3:10 PM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    you def have to get rid[​IMG] of the black boxes for 30x9.50 even with lift. this pic i still had them but they scrubbed slightly.
  15. Jun 29, 2010 at 5:54 AM
    #35
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I have read from a post in CustomTacos about someone who ran 31s (no lift) with the "right" wheel specs. By "right", I don't know what they are. The person ended up removing the tires because it was too much for his engine.
    Also, like what Tim said, the black box behind the plastic fender needs to be removed.
  16. Jun 29, 2010 at 6:17 AM
    #36
    Goatus
    Dillon
    Asheville, NC
    http://www.toyotanation.com/forum/showthread.php?t=183794&page=3
    That page has some good info on the black boxes and how to remove them... Apparently it's super simple as you just have to cut the wheel well lining and unbolt them... As for filling the cut area back in I thought about cutting a triangle out of the removed material and using a soldering iron to "weld" it back to the other plastic by just melting the edges together, but that might look funky and until I re-gear and go up to 31" tires i won't have to worry about it.
    If anyone does the removal and gets some pictures it would probably make for a good sticky.
  17. Jul 6, 2010 at 12:49 PM
    #37
    grizzlytravis
    grizzlytravis Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    mmmm thats what i gots!!!:D
  18. Jul 6, 2010 at 1:07 PM
    #38
    AlexA
    Alex
    Newport News, VA
    post pics when u get em on
  19. Jul 6, 2010 at 5:14 PM
    #39
    grizzlytravis
    tampa florida
    08 taco 5 lug
    theyve been on i posted pics awhile ago lol ef it heres another...i need some wicked action shots taco001_4952b630cd499a9fcf2cef2158faeeb9dfb8f5b2.jpg and heres before my 31's with 235's (yes both pics are with lift):Dtac001_2ea68215cc2fe487d4d7a9e2df717baaffdf9dad.jpg
  20. Jul 6, 2010 at 7:27 PM
    #40
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    dont know about all the posts i got a little lazy and didnt read them all haha,
    but im running 255/55-18 and i think they look good and fill out the wheel wells pretty well. and at 65mph i believe that im really goin about 66/67 mph according to the GPS
    heres a pic
