Last minute check before pulling trigger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 2, 2011.
  1. May 2, 2011 at 2:40 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    Going to throw down some money for new wheels and tires...headed to town fair tire now....just wanted to double check my research before leaving. This is what I plan on getting:
    Pro comp 1069 wheels
    17x9
    4.75 bs
    -6mm offset
    BFG A/T 265/70/17
    load range c
    I just want to make sure I will be okay putting this on a stock Tacoma?
    Also do they make a BFG AT 265/75/17? if so, will that tire fit?
    Thanks for everyone's help! Pics to follow
  2. May 2, 2011 at 2:41 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    do you mean bfg?
  3. May 2, 2011 at 2:45 PM
    TOYOTA 09
    Maine
    Yeah... IPad auto correct was on
  4. May 2, 2011 at 2:46 PM
    TOYOTA 09
    Maine
    Could I fit a 265/75/17 on stck sus with out rubbing?
  5. May 2, 2011 at 5:19 PM
    TOYOTA 09
    Maine
    Also... Just saw a post saying a 265 would look like crap on a 9 inch wheel?
  6. May 2, 2011 at 5:25 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    i had 265s on an 8" wheel and it looked good. I would imagine that the 9" wide would be a little wide for that tire. It would work, but it will be more likely to get scraped up. Go with the 16x8" with 265/75/16 if u can
  7. May 2, 2011 at 5:56 PM
    TOYOTA 09
    Maine
    ^but then I need ton worry about clearing the caliper right?
  8. May 2, 2011 at 7:04 PM
    especk
    Erik
    Redding, CA
    most 16" wheels work fine.
    I think those in 16" will work too.
  9. May 3, 2011 at 3:57 AM
    TOYOTA 09
    Maine
    Anyone have pics of a 265 on a 9" wheel?
  10. May 3, 2011 at 9:49 AM
    TOYOTA 09
    Maine
    My contact at town fair tire said that the 265/70/17 BFG ATs. Would be okay because the section width is 10.5...can anyone confirm. Trying to figure out if I want to run the 16's pro comp 1069 (and have to grind the calipers).... Or go with the 17's and hope the 265 BFG's would look/ work ok (and have the benefit of having the 17's in case I wanna ever step up to 285's and a lift... Does anyone have any suggestions to point me in the right direction?
  11. May 3, 2011 at 11:42 AM
    TOYOTA 09
    Maine
    So nO one is running 17x9's with 265/70/17's. ????
  12. May 3, 2011 at 12:29 PM
    especk
    Erik
    Redding, CA
    id just go with the 17s if u need to grind the calipers to fit the 16s.
    here's my old 265s on 8" wide. 9" will stick out 1/2" wider on the outside and 1/2" wider on the inside.
  13. May 3, 2011 at 12:48 PM
    TOYOTA 09
    Maine
    Thanks man ..... Anyone else wanna chime in?
  14. May 3, 2011 at 2:21 PM
    TOYOTA 09
    Maine
    so i just called pro comp and they say the 17x9 wont fit either...this whole thing is giving me a f'ing headache.
  15. May 3, 2011 at 2:21 PM
    especk
    Erik
    Redding, CA
  16. May 3, 2011 at 2:24 PM
    especk
    Erik
    Redding, CA
    Are those the steel procomp? I was told the aluminums would fit. The problem isnt the diameter of the wheel, it is the part of the wheel where the lug nuts attach that causes the problem
  17. May 3, 2011 at 5:41 PM
    Mescalero
    Mescalero Beretta Taco
    Clemson, SC
    '10 PreRunner DCLB BSP
    5100's x 4, radar detector, dual usb plug, mag-light, satellite radio hard wire
    wrong bolt pattern?
  18. May 3, 2011 at 5:54 PM
    TOYOTA 09
    Maine
    The pro comp phone support (Eric) said no 1069 wheel would fit a 09 Tacoma...said none of the pro comp round hole wheels would fit... They would hit the caliper... I know people are ruNning them...they just must be grinding their clippers down. Eric said that only a pro comp spoked wheel would fit...this does not seem right to me. The funny thing was I called earlier in the morning and another phone tech told me the 17x9 6 on 5.5 4.75 bs would fit!
    Ahhhhhh
    At this point I really don't want to give pro comp any of my business. Eric also said that polished AL would be harder to maintain than chrome. Said that they would stain very easy. Does anyone have a another wheel suggestion?
  19. May 3, 2011 at 6:15 PM
    NCTaco
    NCTaco Well-Known Member
    Brandon
    NC
    05 SR5
    secondary airfilter removed, deblinged , bhlm , satoshi grill
    my 05 has 17x9s with 265 70 17 nitto terras they rub . had to trim a lil bit to make them work. but i think they look fine
  20. May 3, 2011 at 6:25 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
