Last minute oil filter wrench advice.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcayce, Oct 24, 2009.
  1. Oct 24, 2009 at 6:22 PM
    jcayce
    jcayce [OP] Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Bought a case of 90915-20004 and a Fumoto valve and will be changing oil this weekend. What is the least painful method of removing the oil filter for the first time (without jamming a screwdriver through it)? I've done a search and narrowed it down to end cap filter wrench with some sand paper or the 3-jaw filter wrench. I'm on the fence.
  2. Oct 24, 2009 at 6:32 PM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I could not find my filter wrench the last time I did the oil change and used a large pair of pliers to get it off,pulled the little plug from the aluminum filter surround and used a plastic drink bottle that had the top cut off to catch the oil from the used filter as I unscrewed it. the first 5k oil change on my truck happened at the dealer so they got off the - from the factory - filter, I've read the originals are a real pain to get off because their so tight
  3. Oct 24, 2009 at 6:33 PM
    AK27
    AK27 Well-Known Member
    i picked up an end cap wrench from napa, works well :)
  4. Oct 24, 2009 at 6:47 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    You use the dealer filters? What size wrench did you get?
  5. Oct 24, 2009 at 6:48 PM
    AK27
    if you buy the steel wrench, it fits 3 sizes. i'll go take a look right now, i have it in the garage.
    brb
  6. Oct 24, 2009 at 6:51 PM
    AK27
    the model number is "KD 2790" thats all it says on it, besides USA :D
    i took a filter in with me just to make sure it fit
  7. Oct 24, 2009 at 6:56 PM
    ImpulseRed008
    Susan
    SC
    Muchos Gracias :D
  8. Oct 24, 2009 at 6:57 PM
    AK27
  9. Oct 24, 2009 at 6:58 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    well i like to use the k and n filters with the one inch nut on the bottom it makes it super easy to take off
  10. Oct 24, 2009 at 7:02 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    End/filter wrench is what I use, backup is one of those strap wrenches but doesnt work so well of the filter is oily.
    I find it useful to loosen the filter until it can be turned by hand , but not leaking, before I actually drain the oil that way oil doesnt migrate to the filters outside and the hard part is over.
  11. Oct 24, 2009 at 7:34 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Filter wrenches seem like a waste to me. I have bought a few in the past and they only get used once...to get the first filter off.
    I only tighten the filter hand tight so the next change I never needed the wrench.
    Try pliers or if it's clean and you can get a good grip, muscle it off. You may not need to buy one afterall.
  12. Oct 24, 2009 at 7:41 PM
    Tacoyota
    08 4wd
    Mostly true, then someone wants to borrow it, or one of the filters gets stuborn, costs less than a meal at Muck Darn-old's
  13. Oct 24, 2009 at 8:24 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    My hand is my wrench. Oil filter pliers wrk well if needed
  14. Oct 24, 2009 at 8:37 PM
    BlueXenon
    BlueXenon Well-Known Member
    Los Angeles and Newport Coast
    2009 Magnetic gray TRD sport (SOLD) 2004 Radiant Red TRD Off Road (SOLD)
    Pro Comp 6" Stage 2 lift, N-Fab nerf bars, tinted windows, debadged, 6000k xenon headlights, 18" ProComp 7089 Wheels in black with BFG AT KO 33's, SnugLid tonneau cover, Line X'ed TRD skid plate. SOLD! Waiting for the 3rd Gen!
    I use something similar to this http://www.sears.com/shc/s/p_10153_12605_00999839000P?keyword=oil+filter+wrench
  15. Oct 24, 2009 at 9:18 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    If you have the room to use it, (which you should) this is the last and only oil filter take off tool you will ever have to use. You can pick them up at all or most auto part stores.
    EDIT: Yep you'll have the room, I have used this tool on my 2nd generation like your truck.
  16. Oct 25, 2009 at 1:53 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Exactly. I also use Purolator PureOne filters that have the textured paint. Just did an oil change yesterday, actually, and the POS filter wrench stayed on the workbench.
  17. Oct 25, 2009 at 6:39 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    It sucks the first time because you never know how it was installed. I never use one either, as I don't over tighten them to begin with. But that being said,
    I never liked the ones like this:
    First off I have too many different vehicles and they don't adjust. The dealer used one of these on the factory filter (just to loosen it for me, and it would just jump/spin after massive muscle trying to get it off.
    I prefer the ones like this:
    And if it slips, put a piece of sandpaper grit side to the filter and it'll twist the base off the body before it slips.
    Then non-mechanically inclined people come up with crazy crap like this:
