Late oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, May 23, 2010.
  1. May 23, 2010 at 2:03 PM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    So what exactly can happen to my engine (or entire truck) if I don't change my oil on time? Lets say I post-pone the oil change for about 5k miles after its really do (change at 10k miles instead of 5k miles)
  2. May 23, 2010 at 2:04 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
  3. May 23, 2010 at 2:07 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    You could potentially have sludge problems, excessive wear on various engine components, damaged rings, etc.
  4. May 23, 2010 at 2:08 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  5. May 23, 2010 at 2:13 PM
    chiefridr
    chiefridr I don't want a large farva!
    Carrollton, TX
    16 DCTRDOR
    Just change it when yer sposed to and you'll be all set!
  6. May 23, 2010 at 2:18 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Why would you risk damaging your truck by not changing the oil?
  7. May 23, 2010 at 2:21 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    jeez a simple question turned into more questions. I'm just curious damnit
  8. May 23, 2010 at 2:26 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    what if you went 6 days without water in the desert, instead of 3 days?
  9. May 23, 2010 at 2:28 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  10. May 23, 2010 at 2:36 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Nothing immediate most likely...but you will hurt your engines lifespan.
    Some folks swear by a filter change every 5K and oil changes 10 to 15K. If you are going to start custom making oil change intervals you need to invest in oil analysis on a regular basis to ensure you are not approaching a component failure.
    All that being said- "Why??" is a great question...
  11. May 23, 2010 at 2:42 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    All lubricants break down over time. This is due to heat, pressure, contamination and so on. When a vehicle has a recommended interval or a system to alert you to change a fluid, it is at a point where the fluid will still have some life left to it. In other words it can still do its job but is nearing the end of its useful life.
    If we decide to overshoot those times we risk damage and shorter service life from the vehicle.
    The above is the basic concept. There are always variables and opinions. Unless one really knows what they are doing, it is best to stick to known suggestions for best practice.
    HTH FWIW
  12. May 23, 2010 at 2:52 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That solely depends on the oil you have there....
    Some oils are good for 90K
    Some barely last 2k
    So Unless you have one that is made for extended drain you should change oil sooner
  13. May 23, 2010 at 3:12 PM
    Barnone
    Barnone Guest
    Karo,
    No one knows the answer to your question.
    Send a sample of your oil off after 5K miles and then decide after you get the results back.
    BTW, My 2002 2.4l owner's manual calls for 7.5k oil change under normal use. 5k interval for heavy duty use.
    I change it every 5k because old habits are hard to break.
  14. May 23, 2010 at 3:17 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    IF it's synthetic oil 10k is easy to get by with. I change my mobile 1 on my Jeep GC every 8-10k, which equates to twice a year for me. 266k on that engine with no problems. Had the head gasket replaced at 230k miles and the shop said the engine looked pristine for the miles.
  15. May 23, 2010 at 3:31 PM
    wlmuncy
    William
    Knoxville, TN
  16. May 23, 2010 at 3:36 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    You will void your warranty.
  17. May 23, 2010 at 3:44 PM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    I tried to kill my old toyota corolla by not changing the oil, 40 000 km and it still wouldn't give, so i drove it 200 km with no oil cap, still worked fine. But I still would not recommend going past your regular oil change
  18. May 23, 2010 at 3:51 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Yeah, condensation is rough when you run it a bit then let it sit for long periods of time. My wife's car is the same... she MIGHT drive it 5000 miles per year but I still change the oil twice a year. Cheap insurance...
  19. May 23, 2010 at 3:53 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I think maybe someone forgot to change their oil at 5 k and now they are at 10 k and realized they haven't changed it yet .
  20. May 23, 2010 at 4:00 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    if you have engine failure and you cant prove you changed your oil every 5,000 miles it will void your warranty. i take a picture of my speedo oilfilter oil and reciept every time i change my oil.. all in one picture.
