latex paint splatter removal
Discussion in 'Detailing' started by Greensystemsgo, Oct 6, 2011.
  1. Oct 6, 2011 at 8:35 AM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    thousands of little dots of latex paint are on my tailgate, ive tried buffing when i did my debadge, which didnt help much. It did help on my ghosting, but still have quite a bit left.
    Thoughts?
  2. Oct 6, 2011 at 9:15 AM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Clay bar maybe?
  3. Oct 6, 2011 at 9:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Are you sure it's latex and not the 2 part epoxy they use for roadway striping? Either way, have you tried acetone, gasoline or something like goof off? You will need to wax the area when it's done because all of those will strip the wax off the clear coat. Clay bar might have even taken it off but I'd have my doubts if a buffer didn't do the trick.
  4. Oct 6, 2011 at 9:21 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    it scratches off with your fingernail, but theirs THOUSANDS of little dots :(
  5. Oct 6, 2011 at 9:24 AM
    Pugga
    Massachusetts
    If it comes off with your fingernail, try claybar. That's supposed to do a great job taking off things that are sitting on top of the clear coat. You'll have to detail the paint afterwards but it should remove the paint.
  6. Oct 6, 2011 at 9:28 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    A belt sander will take it off.
    But I won't recommend it.
    Most types of paint thinner, acetone, goof-off etc. might damage your clearcoat so although it might work, I would try a small area first.
    When I had my truck painted it came back with overspray all over the truck. I tried all kinds of solvent type products and even polish and could not get it off. I took it back to the painter and he was able to buff it off which appeared to be fairly effortlesly. He did use a power buffer (angle grinder attachment). Maybe this is what made the difference. I then used a clay bar after that and applied a good coat of wax.
  7. Oct 6, 2011 at 10:22 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Thats what i used to take off most of the ghosting on my emblems, buffer attachment on an angle grinder. Ill give the clay bar a shot and report back. thanks folks. any specific type/brand to reccomend?
  8. Nov 16, 2011 at 7:26 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Squirt Liquid Clay Bar on it and rub it with a Clay Bar then wash it...will look mint!
