LCA Ball Joints/Hydraulic Press
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Oct 5, 2012.
  1. Oct 5, 2012 at 9:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They shouldn't. Loosen the nut and see if the bolt will spin inside of the LCA bushing (mark the alignment tabs to the frame to make sure you don't mess up your alignment in the process). Honestly, unless you have a reason to replace the bushings, I wouldn't mess with it just yet unless you can get the bolts out, grease them, then reinstall them. If the bushings are still good, it doesn't matter if they're rusted in or not.
    Is that a stress crack on the LCA in the pic?
  2. Oct 5, 2012 at 9:50 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    ahahahahaha your screwed
  3. Oct 5, 2012 at 10:08 AM
    XXXX
    sKiP
    05 Prius
    make sure and gusset the real failure point
  4. Oct 5, 2012 at 10:10 AM
    XXXX
    sKiP
    05 Prius
  5. Oct 5, 2012 at 10:11 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    kinda looks like it
  6. Oct 5, 2012 at 10:21 AM
    Pugga
    Massachusetts
  7. Oct 5, 2012 at 10:24 AM
    XXXX
    sKiP
    05 Prius
    you and me both buddy... I searched for days and days...
    I just saw these on another forum a month ago :(
  8. Oct 5, 2012 at 10:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's just a seem
  9. Oct 5, 2012 at 10:52 AM
    Pugga
    Massachusetts
    So a stress crack in the making :D
    If you get them, post up your review. I'd be curious to see how they hold up and they've got to be easier to install. The metal bushings were a little tough to press into the rusty LCA.
  10. Oct 5, 2012 at 12:07 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i went outside and set my tq wrench to 100 lbs and the one with back ones tightened some...the front ones were able to spin in the sleeve without moving the cam tab....so i hope im fine? lol
  11. Oct 5, 2012 at 12:13 PM
    Pugga
    Massachusetts
    Sounds like you're fine. For comparison, I had a box wrench on mine with a 4' pipe and mine wouldn't budge. I could get the nuts off but that was it, the bolts wouldn't spin inside the sleeves.
