LCA bolt and sleeve that becomes seized... ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gdog, May 1, 2017.
  1. May 1, 2017 at 5:17 PM
    gdog
    gdog [OP] Well-Known Member
    NOVA
    2022 TRD Off-Road
    Wheels, lift, more as I discover them....
    So I am talking to a guy at a shop about a lift and he informs me that almost all Tacoma's have some steel bolt that is in an aluminum sleeve and almost everyone ends up with at least one being seized. What could he be referring to?
    Thanks
    G
  2. May 1, 2017 at 5:20 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Google ! Start reading. Unsub
  3. May 1, 2017 at 5:21 PM
    719bloodhound
    719bloodhound Well-Known Member
    cos
    06 trd off road
    Omd rear leafs Ome 886 up front
    lower control arm cam bolts
  4. May 1, 2017 at 5:23 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Well there's only a handful of bolts on the LCAs. The 2 bolts for frame mounting/alignments and the lower shock mount. For those in the rust belt or wet climates the 2 for frame mounting/alignments the bolts for those can rust up and seize if they aren't touched in a long time.
  5. May 1, 2017 at 5:24 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    It's a common problem in your LCA bolts (as you mentioned in your thread title). If yours aren't seized yet, I'd suggest removing them, cleaning off any surface rust or contamination and greasing them inside and out and replacing them. If they are damaged/seized, there's no way around it, you'll need to replace them and grease the new ones. Link for reference from the all-knowing @Crom :
    https://www.tacomaworld.com/threads...t-2005-tacoma-4x4.176250/page-14#post-7658474
    Edit. Anyone else notice "coolavatars.net" Google took OP that far, but not far enough to learn about seized cam bolts?
    OP: "I need a cool avatar."
    *types in "cool avatar" into Google search bar
    EDDO and Drainbung like this.
  6. May 1, 2017 at 5:40 PM
    Pigpen
    Dan
    Northwest Montana
    Mine had to be cut off and everything had to be replaced - LCA and all hardware. Search for the thread "cam part numbers", I believe.
  7. May 1, 2017 at 5:43 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    Here are the part numbers for the cam bolts and other Lca bolts.
    Qty. 2 4819860011 front suspension, lower control arm, adjust cam Tacoma Camber No.2 4WD
    Qty. 2 4819060020 front suspension, lower control arm, adjust cam Tacoma Camber No.1 4WD
    Qty. 2 4840960020 CAM SUB-ASSY, TOE AD
    Qty. 2 4845235020 PLATE, TOE ADJUST, N
    Qty. 2 90119A0166 BOLT, W/WASHER
    Qty. 2 90178A0001 NUT, FLANGE
    Steves104x4 and GHOST SHIP like this.
  8. May 1, 2017 at 8:35 PM
    gdog
    NOVA
    2022 TRD Off-Road
    Wow....I had no idea.....ugh
    Thanks everyone!
    G
  9. May 10, 2017 at 2:34 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Well just found out mine are seized. If I buy a new bolt I should be able to jut zip the old one off and replace it correct? I can get the nut and rear side adjustment off, just cant get the actual bolt and front side to move.
  10. May 10, 2017 at 2:38 PM
    Large
    Large Red
    Best thing to do is buy new nuts, bolts and cam tabs, then sawzall everything off. Make sure not to damage the LCA or your frame mounts.
  11. May 10, 2017 at 2:49 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    ya I was gonna do that but then the dealer wanted $30 alone for just the bolt, i didnt even bother pricing up the rest. My truck is aligned good now I was just worried about next time I do it
  12. May 10, 2017 at 2:50 PM
    Large
    Large Red
    Next time just spray some PB blaster very liberally all over the bolts a few days ahead of time, and do it a few times a day. That would be your best bet in unseizing them
    maxpower29[QUOTED] likes this.
  13. May 10, 2017 at 2:51 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    thanks i'll try that for a few days. Last fucking tire that needed to be done too and it seized for the guy
  14. May 10, 2017 at 2:59 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    I paid 130 for everything today:censored:
  15. May 10, 2017 at 3:00 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    just one side? Fuck this pisses me off
  16. May 10, 2017 at 3:03 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Both sides. Rebuilding the front end, and I really didn't want any unnecessary down time with the truck being my DD
  17. May 10, 2017 at 3:06 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I dont even drive mine much now, considering selling because of the hassle the maintenance is becoming
  18. May 10, 2017 at 3:10 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Thanks for this. I am debating whether I should be lazy and order to have them just in case, or take apart in advance to find out if needed or not. I want to replace LCA bushings with poly..
  19. May 10, 2017 at 3:14 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    All 4 of my bolts were hard seized. I had to cut all of them out. No "just zip them out". It was a huge pain in the ass.
  20. May 10, 2017 at 3:25 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    I have been debating the same... Something every month it seems.
    Thats what I'm in the process of doing right now. New LCA's, bj's, poly bushings, and all new hardware... Shit better work
