LCA Bushings: OEM, Energy Suspension, Whiteline
Discussion in '1st Gen. Tacomas (1995-2004)' started by alphabravo, Oct 8, 2015.
  1. Apr 9, 2017 at 6:55 PM
    #101
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I just did energy suspension upper and lower about 3 weeks ago and so far I love them. I used an oxy/acetylene rose bud to separate/burn out the old rubber and maybe took 2 minute per bushing. After completing the drivers side the passenger side went fairly quickly.
    tymeson likes this.
  2. Apr 9, 2017 at 11:23 PM
    #102
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Tim how does that truck ride with those rear axle wrap bars? What brand are they?
  3. Apr 10, 2017 at 1:02 PM
    #103
    Timmah!
    Timmah! Well-Known Member
    TIM
    I don't know exactly what you talking about. Are you talking about the rear control arms? This is not my truck. It belongs to this guy Fred who I met on toyota-4runner.org. If you can tell me the playtime in the video you saw the parts in question, I'll know what you're talking about and I could shoot a message to Fred and ask him about them.
  4. Apr 14, 2017 at 1:39 PM
    #104
    alphabravo
    alphabravo [OP] Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I got a suggestion to copy these updates into a separate post so they don't get lost in the OP. Thanks @quetzal.
    Update: April 30, 2016
    A note about squeaking and poly bushings...When I first installed the Whitelines they squeaked like crazy. I think I was going crazy and I never even got it offroad.
    Anyway I went back in and completely tore everything down. Total Chaos UCA bushings, Whiteline LCA bushings, AND Energy Suspension steering rack bushings. I cleaned all the bushings, bolts, contact surfaces of grease, grit, paint, and then instead of using Redline, I greased everything heavily with SuperLube. That stuff is completely synthetic and free of petroleum based additives. It is a food grade grease and playsnice with the polyurethane. For two months now I have 0.000 squeaks. Zero. I am using it on everything now except CV boots.
    Update: April 2017
    I've had the Whitelines on for about a year and a half and wanted to add an update.
    1. On the positive side, the Whitelines are still squeak free after doing the careful cleaning and greasing I described last year.
    2. On the downside, the Whitelines do not have the grooves on the bearing face that the OEM bushings have. These grooves allow the bushing to bite into the metal on the frame under proper alignment bolt torque. The Whitelines have thick smooth aluminum washers which are prone to slipping under heavy load and throwing alignment. I just had this happen to me yesterday when I was changing out tires. When I dropped the jack on the front end the suspension droop caused the tires to land on the outside shoulders which put the LCA into compression and caused one of the back LCA cam bolts to bang to the limit. It took me a bit to figure out what had happened. I'm limping on a manual alignment til I get it re-aligned. I have been using a higher torque then OEM (more than 100 ft-lbs) to prevent this from happening but the potential still exists. I have been thinking of a way to roughen the face of the washers and improve the grip but no great ideas yet.
    tymeson, jjsul and boostedka like this.
  5. Apr 23, 2017 at 6:06 AM
    #105
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    @Squeaky Penguin Have you had any trouble keeping your alignment with your white lines as described above?
  6. Apr 23, 2017 at 6:19 AM
    #106
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No, and that includes lots of wheeling.
    jjsul[QUOTED] likes this.
  7. Apr 23, 2017 at 7:07 AM
    #107
    Chinle
    Chinle Active Member
    Tom
    Wichita, KS
    02 Red X-cab 3.4 5-speed SR5 3" OME lift
    ARB bar, XRC2 9500lb winch, Full OME set-up, 882's w/ JK spacer, dakar w/ D6XL AAL, Camburg UCA's, extended brake line, Snugtop Rebel, Weathertech mats, extended rear breather, Rigid Dually D2's, Odyssey Dual battery, Blue Sea ML-ACR, Blue Sea Fuse Block, Dometic CFX65DZ more to come, albeit slowly.
    I have run the whitelines for about a year now myself. They are great, no alignment slippage or squeaks or any problems of any nature. Taken a few good hits while fully loaded out in the field. No complaints here. I do not crawl, but rather haul gear for field work, usually loaded up right to GVW. I lubed the bushings up real good before putting them together. Hope this helps anyone on the fence about them.
    MacGyvR, jjsul and boostedka like this.
  8. May 24, 2017 at 1:44 PM
    #108
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Can you post me a link to this establishment??? Did a search but only San Diego Truck Springs and they did not seem to have LCAs.
    Thanks!!!
  9. May 24, 2017 at 2:01 PM
    #109
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    http://sdtruckshop.com/ Call them and/or email. They currently have 2nd Tacoma LCAs in stock.
  10. May 24, 2017 at 2:03 PM
    #110
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I have always burned them out, then using a hacksaw sliced the metal sleeve, usually I have to get a chisel in there though as my goal is to not eff up the control arm.
    Seeing some of these other methods though is interesting as perhaps something may work better.
  11. Jun 3, 2017 at 1:21 PM
    #111
    tony2018
    tony2018 Well-Known Member
    Maybe Op put too much grease on them, some excess cover some of the washer's surface? I'm debating on either ES or Whiteline and Whiteline might be my go to because i just don't feel like breathing in any toxics.
  12. Jul 31, 2017 at 11:03 AM
    #112
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Anyone know of a place to order the whitelines without it being weeks before they ship? Amazon says they are unavailable, anyone have an idea of when they will be back in stock?
  13. Aug 11, 2017 at 9:32 AM
    #113
    Timmah!
    TIM
    Try this company to buy the bushings: http://www.suspension.com/w53377a
    They say it's for the 3rd Gen 4runners but the 1st Gen Tacomas have the same front end so it should work.
    boostedka likes this.
  14. Aug 11, 2017 at 11:03 AM
    #114
    gray223
    SE Missouri
    2014 Tundra Limited
    Yeah I saw that, shays 4-8 weeks for shipping though...
  15. Aug 11, 2017 at 11:47 AM
    #115
    Timmah!
    TIM
    Bummer. I'd contact the company and ask if that's really an accurate shipping time or can you get them much sooner.
  16. Aug 11, 2017 at 12:04 PM
    #116
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Timmy,
    What ball joint separator did you use to break apart that LBJ? Shown @11:20 -
    I used an autozone one and it was crap. The one you used there seemed to work very well.
  17. Aug 11, 2017 at 12:24 PM
    #117
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    That looks just like the one I got at HF. Mine works fine
    jjsul likes this.
  18. Aug 11, 2017 at 12:59 PM
    #118
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I did put alot of grease on the bushings and washers but mostly I think my issue was the torque spec. The rear cam nuts are blocked by the steering rack and I'm guessing the shop didn't torque them. If the other guys here have subjected the Whitelines to hard wheeling then I'm sure they are fine.
    tony2018[QUOTED] likes this.
  19. Aug 11, 2017 at 4:25 PM
    #119
    tony2018
    np, will be looking into this soon.
  20. Aug 11, 2017 at 4:57 PM
    #120
    Timmah!
    TIM
    Hey Ramon, that puller came from a kit I bought from OTC via Amazon. I've gotten tons of use out this kit. Well worth the expense.
    Here's a link:
    https://www.amazon.com/OTC-6295-Fro...qid=1502495780&sr=8-6&keywords=otc+puller+set
