LCA Bushings: OEM, Energy Suspension, Whiteline
Discussion in '1st Gen. Tacomas (1995-2004)' started by alphabravo, Oct 8, 2015.
  1. Aug 30, 2017 at 11:44 AM
    #121
    alphabravo
    alphabravo [OP] Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Dropbox is discontinuing the "Public" folder support next month so I have to convert all my links to their new sharing method. The links in this thread will probably be dead for awhile.
    jjsul likes this.
  2. Aug 30, 2017 at 12:21 PM
    #122
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I finally popped in some white lines over the summer. Sweaky as hell!
    I don’t mind because my front end is real tight.
    JayRolla likes this.
  3. Aug 30, 2017 at 12:27 PM
    #123
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    They are squeaking? We lubed them up pretty good too!
  4. Aug 30, 2017 at 12:29 PM
    #124
    jjsul
    James
    New Hampshire
    95.5 OME
    I thought so! Some of the guys in this thread say to use super lube, which I had brought to the meet.
    But, yes, these puppies squwak like crazy. I kind of like it :anonymous:
    fivefoot likes this.
  5. Aug 30, 2017 at 12:37 PM
    #125
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Well that just proves to me how crazy you are! :der: Lol
    jjsul likes this.
  6. Aug 30, 2017 at 12:53 PM
    #126
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I put a link at the top of the OP to PDF copies of the first couple of pages of this thread so the photos are not lost.
    Snowman, 2002Tacoma4x4 and jjsul like this.
  7. Aug 30, 2017 at 3:28 PM
    #127
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So are people replacing these only when the truck can no longer be aligned due to seizure? I hope I never have to do this..
  8. Aug 30, 2017 at 5:10 PM
    #128
    Jaysjammin
    Jaysjammin Well-Known Member
    Jay
    Upstate SC
    '98 SR5 5-speed 4x4 3.4L, 07 FJ Auto 4x4, 97 Locked 80
    That's a good question. I'm at 300k+ but alignments go smoothly.
  9. Aug 30, 2017 at 5:19 PM
    #129
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Mine are seized. Doesn't take much rust to freeze a bolt in a sleeve that's rubber mounted. No leverage and can't use heat to loosen it up.
  10. Aug 30, 2017 at 6:20 PM
    #130
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Interesting. I put white lines in around the beginning of Summer and they don't make a sound. I lubed the heck out of them though.....
    Running Board Man likes this.
  11. Aug 30, 2017 at 8:23 PM
    #131
    jjsul
    James
    New Hampshire
    95.5 OME
    Honestly, it may mostly be my rear springs that I hear while I’m driving around town. But I thought I remember some serious squeaking when I took it for a shakedown run after installing them.
  12. Aug 31, 2017 at 1:40 PM
    #132
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    Anyone know where I can find these?
  13. Oct 18, 2017 at 7:37 PM
    #133
    tony2018
    tony2018 Well-Known Member
    curious, they have upper bushings?
  14. Oct 19, 2017 at 6:33 AM
    #134
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    They offered it at one time.
    I confirmed it with them earlier this yr. They didn't have them in hand when I called. They had 2nd gens tho.
    $500 ha? Is that for the whole arm assembly or just the parts and labor or replacing the bushings. Oh, and last I checked they use "their own poly bushings" no oem option.
  15. Oct 19, 2017 at 6:36 AM
    #135
    quetzal
    Mario
    Long Beach, CA
    SD Truck shop? @tony2018 I don't believe they offer(ed) a deal but I'm sure they can do it for $$$
  16. Oct 19, 2017 at 6:38 AM
    #136
    tony2018
    White line, but it looks like they only had the lower control arm. Was hoping they had upper and lower. I don't see any oem options for the upper, just lower. I guess the reason is people replace the upper control arms as they raise their trucks.
  17. Oct 19, 2017 at 6:48 AM
    #137
    tony2018
    I kinda look for quality too, I guess I'm being picky. Just want my truck to last.
    jjsul likes this.
  18. Oct 19, 2017 at 3:53 PM
    #138
    jjsul
    James
    New Hampshire
    95.5 OME
    I went with white line in my lowers and am glad I did. They seems real nice
    Also looked at uppers and only saw them offered by energy suspension. I figured mine were still okay and I’ll probablt upgrade uca’s at some point in the near future, so I passed.
  19. Oct 19, 2017 at 3:56 PM
    #139
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    If you have a lift and wheel really hard they will wear out. So much that my brakes almost pulled me off the road a few times.
    What people dont realize are when wheeling the OEM bushings are so tight that they bind up and can stop a tire from drooping as far. Polys allow full unbinding movement of both control arms.
    Byb127 likes this.
  20. Oct 19, 2017 at 6:00 PM
    #140
    quetzal
    Mario
    Long Beach, CA
    For me:
    OEM lasted 200k miles. Poly or Whiteline won't come close. OEM FTW
