LCA Bushings: OEM, Energy Suspension, Whiteline
Discussion in '1st Gen. Tacomas (1995-2004)' started by alphabravo, Oct 8, 2015.
  1. Oct 19, 2017 at 6:07 PM
    #141
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I’ve never heard of this before. Interesting.
  2. Oct 19, 2017 at 7:13 PM
    #142
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    It's more they bind and tear than hold up droop but they do allow smooth movement.
  3. Oct 19, 2017 at 9:15 PM
    #143
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    I'm sure this is based on documented facts Lol..
    Wulf and Digiratus like this.
  4. Oct 20, 2017 at 4:04 AM
    #144
    tony2018
    tony2018 Well-Known Member
    I only see the lower control arm bushings being sold on oem toyota sites. The upper control arm is sold as a whole w/ bushings.
  5. Jan 5, 2018 at 11:18 AM
    #145
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    What lube would you guys use for OEM steering rack bushing??
  6. Jan 5, 2018 at 11:34 AM
    #146
    tony2018
    Same thing that comes with the poly bushings.
    Running Board Man likes this.
  7. Jan 5, 2018 at 11:56 AM
    #147
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You don't "need" to lube the steering rack bushings. The poly kits don't even come with lube for the rack bushing kit.
    If you feel like you must lube the rack bushings, use NON-petrolium based lube (for either OEM rubber, or a poly aftermarket) Superlube is a good choice.
    tymeson[QUOTED] likes this.
  8. Feb 5, 2018 at 7:42 PM
    #148
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I know, this is old.
    I’ve heard a few people say the moog bolts aren’t good but what was wrong with SPC? Did they break or strip? I am in the process of getting everything to replace my bushings and bolts (seized solid) but OEM bolts will cost me $300+ up here and SPC will be like $75. That being said I don’t want to waste $75 on shit either.
  9. Feb 5, 2018 at 7:59 PM
    #149
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    They don't hold alignments as well, and after a couple will round and be completely useless. The interface between the bolt and cam is significantly less than the OEM setup.
    Stick with OEM. If you can afford the down time, take it apart before buying new ones. You might be lucky and be able to save a couple of the old ones. Also, the part that's usually seized is the sleeve, so you should be able to reuse the bolt and the cam that's attached to the nut.
    Snowman[QUOTED] likes this.
  10. May 25, 2018 at 11:42 AM
    #150
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I’m hoping this will limit slipping. Did the other side as well, closer to the center to meet the ends of the bushing sleeves. 632A2472-7E23-492A-90C7-B8F8D4F2F2D7.jpg
    Running Board Man and Rocan like this.
  11. May 25, 2018 at 11:44 AM
    #151
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I did my Whitelines about 6 months ago. I didn't do anything to the washers. I haven't had any problems or noises.
  12. May 25, 2018 at 12:11 PM
    #152
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    May not help but I figured it wouldnt hurt.
  13. May 25, 2018 at 1:56 PM
    #153
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    :thumbsup:
  14. Nov 11, 2018 at 7:17 AM
    #154
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Anyone that's installed the whiteline bushings: I have 4 extra washers with the smaller inner diameter. Did I miss something? Lol.
  15. Nov 11, 2018 at 7:20 AM
    #155
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Did you put two washers to each bushing? IIRC, mine only came with the large, flat washers, and I believe each bushing received two?
  16. Nov 11, 2018 at 8:29 AM
    #156
    Wulf
    Wulf no brain just damage
    rock raisin
    Necro quote. I have been chasing an issue with the brakes pulling intermittently and never considered that the LCA bushings could be shot.
    Edit: I still had the issue after replacing the steering rack, TREs, calipers, rotors, and lines and having a shop verify no braking issues so this seems pretty likely
  17. Nov 11, 2018 at 5:41 PM
    #157
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Yep, one on each side of a bushing, and still 4 left over. Weird. I'm going to email whiteline in the morning just to check. The job is done and everything is working well.
    Btw, for those on the fence about installing these bushings, do it! It's hard to explain, but the truck's steering just feels tighter and more responsive. I'm happy.
  18. Nov 11, 2018 at 7:37 PM
    #158
    kuntry09
    Cam
    Douglas, Georgia
    That’s certainly odd...sounds like they stuck four extra washers in by mistake :notsure: if you installed 2 for each bushing, then that’s all there should be.
    gunn_runner[QUOTED] likes this.
  19. Nov 12, 2018 at 9:44 AM
    #159
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Did the whitelines a few weeks ago and it's completely changed the truck.
    I had replaced the whole front end, rack,rack bushings, ball joints, big brake upgrade etc etc and I still had a pull to the left when braking.
    FINALLY, replacing the LCA's got rid of it. My truck finally goes straight on the highway.
    TIP: Use a torch to help push out the old bushings. I used an air chisel and it would have been a lot more gentle on the arms with a little heat help.
  20. Nov 12, 2018 at 10:58 AM
    #160
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    I've got the same symptoms, pulls to the left. Did the tundra brake swap thinking it might be a caliper. Guess I'll add this to the list.
    frenchee likes this.
