LCA Bushings: OEM, Energy Suspension, Whiteline
Discussion in '1st Gen. Tacomas (1995-2004)' started by alphabravo, Oct 8, 2015.
  1. Nov 11, 2018 at 8:29 AM
    #161
    Wulf
    Wulf so stupid it's contagious
    Jake
    Southlands mall
    96 Tacoma WIP
    Trail damage
    Necro quote. I have been chasing an issue with the brakes pulling intermittently and never considered that the LCA bushings could be shot.
    Edit: I still had the issue after replacing the steering rack, TREs, calipers, rotors, and lines and having a shop verify no braking issues so this seems pretty likely
    frenchee, lukester78 and JayRolla like this.
  2. Nov 11, 2018 at 5:41 PM
    #162
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Yep, one on each side of a bushing, and still 4 left over. Weird. I'm going to email whiteline in the morning just to check. The job is done and everything is working well.
    Btw, for those on the fence about installing these bushings, do it! It's hard to explain, but the truck's steering just feels tighter and more responsive. I'm happy.
  3. Nov 11, 2018 at 7:37 PM
    #163
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    That’s certainly odd...sounds like they stuck four extra washers in by mistake :notsure: if you installed 2 for each bushing, then that’s all there should be.
    gunn_runner likes this.
  4. Nov 12, 2018 at 9:44 AM
    #164
    frenchee
    frenchee Well-Known Member
    Campbell CA
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Did the whitelines a few weeks ago and it's completely changed the truck.
    I had replaced the whole front end, rack,rack bushings, ball joints, big brake upgrade etc etc and I still had a pull to the left when braking.
    FINALLY, replacing the LCA's got rid of it. My truck finally goes straight on the highway.
    TIP: Use a torch to help push out the old bushings. I used an air chisel and it would have been a lot more gentle on the arms with a little heat help.
  5. Nov 12, 2018 at 10:58 AM
    #165
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    I've got the same symptoms, pulls to the left. Did the tundra brake swap thinking it might be a caliper. Guess I'll add this to the list.
    frenchee likes this.
  6. Nov 12, 2018 at 11:53 AM
    #166
    tony2018
    tony2018 Well-Known Member
    Same, lucky me I still have lca's with good bushings on them. I'll swap em out, get an alignment and rebuild the old ones with whiteline to keep for spares.
  7. Apr 14, 2019 at 3:47 PM
    #167
    lukester78
    Luke
    Got the Whiteline bushings from Amazon, came loose in a box with the original bag. Must’ve been a return. Just want to make sure before I tear the truck apart, all 4 bushings should be identical, correct?
  8. Apr 14, 2019 at 4:28 PM
    #168
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    2004 Ext Cab V6 5MT 4X4 162k
    881/5100/Dakars 4R wheels / TBU New frame
    I've still got mine sitting around, but haven't installed them yet. All four of my bushings are the same size.
    lukester78 likes this.
  9. Apr 15, 2019 at 8:48 PM
    #169
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Yup. All four are the same. Just completed my LCA bushing job a little while ago using the Whiteline bushings. I rented a ball joint press to make use of the different size cups to press in the bushings. It worked beautifully.
    cruiserguy likes this.
  10. Apr 15, 2019 at 8:59 PM
    #170
    jjsul
    jjsul Well-Known Member
    James
    Massachusetts
    95.5 OME
    Should also have 8 big washers, two per bushing.
    cruiserguy, lukester78 and MedicMutt like this.
  11. Apr 15, 2019 at 9:38 PM
    #171
    MedicMutt
    Josh
    Baton Rouge, LA
    And the metal sleeve inserts.
    A side note: During my shower "After action review" of the job, I realized that I grabbed the "Wrong" grease gun for this job. One gun has a basic, moly fortified grease, and the one I grabbed has Valvoline Synpower.
    After a little research, I think the Valvoline gun may be the better of my two options since it's full synthetic and has molybdenum disulfide. Not super lube like what OP suggests, but maybe the best of both worlds?
  12. Apr 16, 2019 at 6:29 PM
    #172
    lukester78
    Luke
    Sounds like I have everything I should. Definitely getting a floor jack before I bother with this, so sick of the stock bottle jack
  13. Apr 17, 2019 at 7:48 AM
    #173
    MedicMutt
    Josh
    Baton Rouge, LA
    Riding around for a day, I'm amazed at the difference so far! So much better!
    SwampYota and Area51Runner like this.
  14. Apr 17, 2019 at 8:12 AM
    #174
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    For the poly bushings, first: the grease from the manufacturer of the bushings is best, and second: the energy suspension grease should work on any of the polys. The big difference is both the greases you had are petroleum based. Poly bushings call for synthetic, either PTFE(Teflon) or silicone grease or the manufacturer proprietary blend.
    Area51Runner likes this.
  15. Apr 17, 2019 at 10:23 AM
    #175
    MedicMutt
    Josh
    Baton Rouge, LA
    Hmm. Might just wait until the next alignment is due and apply the appropriate grease. It was a duh moment, but at least everything will hold together fine for now.
    Anyone have any pointers on breaking things apart for such a job? Would really like to not rip it completely apart again.
  16. Apr 17, 2019 at 11:39 AM
    #176
    cruiserguy
    Elijah
    SLC
    I dunno man, the only way to truly get those friction squeeky areas lubed is disassembly. You might be able to use PTFE or silicone spray to get you through the squeeks. Or it might not ever squeek. You'll know what you need to do at least, if squeeks show up
  17. Apr 17, 2019 at 11:52 AM
    #177
    MedicMutt
    Josh
    Baton Rouge, LA
    For sure. Maybe dropping the arms at the cam bolts and letting the rest of the steering assembly just droop down will get it.
    Gonna try and not lose any sleep over it. Losing enough to my 1 month old son as it is. Lol
    Thanks for the info, my man.
  18. Apr 17, 2019 at 10:16 PM
    #178
    SJTaco4x4
    SJTaco4x4 Active Member
    Charlie
    San Jose, California
    2004 DC 4x4 TRD
    Anyone tried to remove the washers from the oem bushings and use with the Whitelines? Or is this no bueno?
  19. Apr 17, 2019 at 11:04 PM
    #179
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Diode Dynanics SS3 Sport Selective Yellow Fog Lights 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Doug Thorley Headers Magnaflow 18" Muffler w/upstream CAT delete 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Why do you want to do that?
  20. Apr 17, 2019 at 11:18 PM
    #180
    SJTaco4x4
    Charlie
    2004 DC 4x4 TRD
    I was under the impression that the washers that come with the Whiteline bushings do not have grooves like the oem bushings and that this can cause problems with keeping an alignment. Is this incorrect?
