LCA Bushings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Nov 2, 2020.
  1. Nov 2, 2020 at 3:39 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    The only reason I could see having an alignment done beforehand would be to mark where the oem cam tabs are located. Then, find the matching Bison OffRoad tab position which most closely matches it. That way your alignment is as close as possible to straight once you install them. Fine tune it afterwards if necessary. I had to go back once after the initial installation of mine to get the passenger side dialed.
    Naveronski likes this.
