LCA Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pugga, Apr 28, 2012.
LCA options...
Poll closed May 28, 2012.
  1. Let Toyota have at it and pray
    5 vote(s)
    14.3%
  2. Replace LCA bushings myself
    18 vote(s)
    51.4%
  3. Deal with the crappy ride
    0 vote(s)
    0.0%
  4. Something else
    3 vote(s)
    8.6%
  5. Potato (Click here if you're a tool and have nothing constructive to offer)
    9 vote(s)
    25.7%
  1. May 17, 2012 at 1:02 PM
    #141
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Agreed, but I didn't need help load only bumps. My tongue weight of my boat is not that much but on RR crossings the sponginess was a problem.
    I normally ride on the 4 position and it's stock smooth. I tow my boat with passengers in the 8 postion. For towing with passengers and a load in the bed like say going camping I set it to 9. Works perfectly.
  2. May 17, 2012 at 4:09 PM
    #142
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Could someone please point me in the general direction of where I'd find the LCA bolt torque specs? :eek:
    If anyone knows, it would be much appreciated!
    EDIT: Found it 150 ft-lbs according to this guy:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/193626-lca-moves-its-mounts.html#post4209760
    Also think I found my problem... I was able to tighten them with my torque wrench set to 110#, 150 means they were REALLY loose.
    And.... wasn't the problem. Tightened them down and it's still making noises (actually seems to be worse now). :mad:
  3. May 17, 2012 at 5:18 PM
    #143
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    I have them at home but I'm at work I'll check when I get home
  4. May 17, 2012 at 5:29 PM
    #144
    Pugga
    Massachusetts
  5. May 21, 2012 at 4:56 AM
    #145
    Pugga
    Massachusetts
    Everything is torqued to spec, alignment went well and my truck drives and handles well without any stray noises :yay:
  6. May 21, 2012 at 5:08 AM
    #146
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    WOOT SO WAS IT THE LCA BOLTS THAT WERE MAKING THE NOISE
  7. May 21, 2012 at 5:13 AM
    #147
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    someone needs to finish the LCA cam replacement thread :D
    I did mine to 100#
  8. May 21, 2012 at 5:17 AM
    #148
    Pugga
    Massachusetts
    Yep, I think the fronts were shifting. I retorqued everything else also and found that the bolts holding the LCA to the spindle were loose! I'll recheck them in a week to make sure they haven't backed off again. If they do I'll put some Threadlocker Red on them.
  9. May 21, 2012 at 5:34 AM
    #149
    XXXX
    sKiP
    05 Prius
    and Toyota fails again....
    Idiots should know how to tighten their own bolts up...
    That could of been really bad for you and whoever you hit when your LCA came off. I would write them a letter or call them up.
  10. May 21, 2012 at 5:44 AM
    #150
    Pugga
    Massachusetts
    Nah, that one would be my fault, Toyota never touched those bolts (at least they shouldn't have). :eek: I tightened them when I installed the LCA but then read they were supposed to be torqued to 118 ft-lbs. I pulled the wheels to check and retorque everything again now that it's been a week and noticed those bolts had loosened up. Yeah, that could have been bad if they came off! I'll retorque them again in a week just for my own piece of mind.
  11. Jul 25, 2012 at 10:05 PM
    #151
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How do you get that part out ? The splined cam bolt I mean
  12. Jul 26, 2012 at 4:54 AM
    #152
    Pugga
    Massachusetts
    In a perfect world (meaning if Toyota actually used neverseize), they should just push it through the bushing and it'll pop out the other side. In reality, I cut the bolt on the other side of the frame mount (cut between the frame mount and the LCA on both sides of the bushing) then the LCA will drop out and that spline bolt thing is seized inside the bushing.
  13. Jul 26, 2012 at 7:21 AM
    #153
    OZ-T
    Peter North
    British Columbia
    Thanks Mike
    The amount of the spline sticking out on my driver's side seemed to be less than on my passenger side .
    Also the " cap " that goes onto the spline end on my driver's side didn't feel like it registered onto the spline , I could spin it freely
    I inspected the splined end and it didn't seem damaged
    :confused:
  14. Jul 26, 2012 at 7:38 AM
    #154
    Pugga
    Massachusetts
    If I'm not mistaken, the only way you see that spline is if you snap the end off of the bolt. When new, the part below is what it looks like (notice you can't see the splines). The splines appear when you snap off the washer looking thing on the left side. It didn't take a whole lot to break the end off to expose the splines. It's almost like they're just pressed together at the factory.
  15. Jul 26, 2012 at 8:05 AM
    #155
    OZ-T
    Peter North
    British Columbia
    I was talking about this ^^^
  16. Jul 26, 2012 at 8:07 AM
    #156
    OZ-T
    Peter North
    British Columbia
    and this ^^^^
  17. Jul 26, 2012 at 8:11 AM
    #157
    Pugga
    Massachusetts
    When new, I believe those 2 pieces are actually one part (the one I pictured above) just factory pressed together which might be why you're having trouble getting the splines to engage.
  18. Jul 26, 2012 at 8:22 AM
    #158
    OZ-T
    Peter North
    British Columbia
    I thought the front sleeve part came through from the rear toward the front , maybe I'm turned around
  19. Jul 26, 2012 at 8:26 AM
    #159
    OZ-T
    Peter North
    British Columbia
    Went back and looked at the pics again and I think you are right Mike
  20. Jul 26, 2012 at 8:35 AM
    #160
    Pugga
    Massachusetts
    I just went searching for stock suspension pictures cause you had me second guessing!
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
    I believe that sleeve assembly gets pushed through from the front, then the bolt also gets pushed through from the front and the rear is an alignment tab and bolt all in one. That stupid nut/tab thing was like $17 if I'm not mistaken but you should be able to reuse the originals.
