LCA Ticking Sound???
Discussion in 'Suspension' started by Slimwood Shady, Aug 17, 2012.
  1. Aug 17, 2012 at 2:39 PM
    Slimwood Shady
    Slimwood Shady [OP] I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Or could try to have the dealer replace under warrenty :laughing:
  2. Aug 17, 2012 at 2:42 PM
    jandrews
    '09 FourDubDee TRD OR
  3. Aug 17, 2012 at 2:42 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    there you go....
    just bring it in and make them do it....:D
    tell them u herd it on a road trip stopped by a mech. and he told you bushings are shot....and to take it to dealr
  4. Aug 17, 2012 at 2:46 PM
    jandrews
    Page 71 here:
    http://energysuspension.com/assets/files/2010-energy-suspension-catalog.pdf
    Energy makes a front end control arm bushing kit for FJ Cruisers.
    Guess what uses the same front LCAs as an FJ Cruiser?
    I would call Energy Suspension first and make sure this kit includes LCA bushings. UCA replacements are popular on these trucks. LCAs, not so much. Before you drop your hard earned cash, I'd make damn sure they have the right parts for the application.
  5. Aug 17, 2012 at 2:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Me too :)
  6. Aug 17, 2012 at 2:54 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    try this before moving and taking off stuff. wet the whole front end with water or spray what you think it is with WD-40 let it sit and try it...if it's still popping try spraying something else that you think moves, i had the same problem and i did that with all the bolts nuts joints everything and i found out it was my strut where it goes in the other one the seal was making it pop wired but a cheap way before you remove the cams and have to take it to get it aligned again.
  7. Aug 17, 2012 at 3:08 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I'm voting no to the bushings being bad. The cams may be seized but I doubt this is your noise. Your cam tabs would most likely be bent if you wheel and they are seized. Every time you cycle the suspension the tabs would move if this was the case.
    How old are your shocks and how are they mounted? Heim, bolt with rubber bushing?
    My truck makes a very similar noise (with new LCA bushings) and it's the heim on the lower shock mount of my Kings. I need to replace it but if I keep it lubed it's fine for a week or so depending on rain/mud.
    Never seen them before and I looked all over when I replaced mine. I surely book marked that link and will make sure I pay attention to the outcome should someone buy these.
    This is always a great idea and how I tracked down my noise after I checked the torque of everything.
  8. Aug 17, 2012 at 3:11 PM
    jandrews
    I'm not even sure the bushing is bad...it's definitely flexing some, and the ticking could just be the rubber catching and sliding as it moves down the cam bolt while the bushing flexes.
  9. Aug 17, 2012 at 3:12 PM
    OZ-T
    Peter North
    British Columbia
    My LCA's made a similar noise but it was due to the bolts being under torqued
  10. Aug 17, 2012 at 3:13 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Call bomb squad for the ticking sound dah
  11. Aug 17, 2012 at 3:13 PM
    OZ-T
    Peter North
    British Columbia
    Or the through bolt binding on the inner metal sleeve
  12. Aug 17, 2012 at 3:15 PM
    XXXX
    sKiP
    05 Prius
    The bushing rubber was fused to the sleeve by superman at the factory. No way in hell could it be loose IMO. I had tons of pressure trying to get mine out for 2 weeks with zero to show for it.
    The bushing can't really go bad unless the rubber is totally degraded or the bushing sleeve seizes to the bolt or the cam sleeve. Mine were seized, but the rubber was A OK...until I cut it :D
  13. Aug 17, 2012 at 3:16 PM
    XXXX
    sKiP
    05 Prius
    this would do it for sure. whats it supposed to be 100 or 110# I think :notsure:
  14. Aug 17, 2012 at 3:17 PM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    I have Icons they are coming up on a year old. I just sprayed down my cams to see if that is where the sound is coming from. My cam tabs are not bent and they do not move, however, Firestone bent my alignment tabs on this side a while ago and paid Toyota to replace them with TC ones. I can not remember if this is when the noise started or not. It very well may be, as I used to think that the sound was because of my caster was at 3.0. Obviously that was all in my head:pout:
  15. Aug 17, 2012 at 3:22 PM
    #35
    XXXX
    sKiP
    05 Prius
    Check the torque and post a pic of the tabs.
    For reference rubber was fine with little play and the sleeve was seized in the front and the bolt in the rear.
  16. Aug 17, 2012 at 3:23 PM
    #36
    OZ-T
    Peter North
    British Columbia
    100
  17. Aug 17, 2012 at 3:29 PM
    #37
    jandrews
    That's a good option. I've had my LCAs clunk at me before because alignment guys left 'em loose. Never had any ticking, but see no reason why it couldn't occur just as easily.
  18. Aug 17, 2012 at 3:34 PM
    #38
    XXXX
    sKiP
    05 Prius
    Signs of improper torquing and seized sleeves (don't ask) :(
    then the issue leads to constant alignments followed by welding work to stop the need for constant alignments :D
    should look like this
  19. Aug 17, 2012 at 3:42 PM
    #39
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    HOLY LOOSE CAM BOLT BATMAN!!!! The cam bolts were pretty loose. I tightened them to 100 ft/lbs and the clicking is gone. Or it was the WD 40 I sprayed earlier, but I doubt it. Thanks again guys, the only thing is I moved a tab a bit, I put it back the best I could. Oh well...looks like I need to go to Firestone and get my alignment done again. Thank good for the lifetime alignments! This is probably my 6th one!!!:D
  20. Aug 17, 2012 at 3:47 PM
    #40
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The cam bolts were probably loose from your previous trip to Firestone. :D
