LCA Ticking Sound???
Discussion in 'Suspension' started by Slimwood Shady, Aug 17, 2012.
  1. Aug 17, 2012 at 3:48 PM
    #41
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    Fack, I'm pretty sure my cam bolts are the same way. Thanks for the pics!
  2. Aug 17, 2012 at 3:54 PM
    #42
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sweet
  3. Aug 17, 2012 at 3:54 PM
    #43
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    should take them apart and lube them all then go for alingment....
    wouls suck to have them sieze in the next few months because you got lazy
  4. Aug 17, 2012 at 3:59 PM
    #44
    OZ-T
    Peter North
    British Columbia
    Not a bad plan
  5. Aug 17, 2012 at 4:00 PM
    #45
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :woot:
    Yep :laugh:
    Good one! They are already loose and out of alignment so nows the time.
  6. Aug 18, 2012 at 1:24 PM
    #46
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    If its knocking back and forth when u roll a bit then stab brakes u need new bushings. They are $60 ish a pop and a giant pain in the ass to take out and reinstall
  7. Aug 18, 2012 at 5:14 PM
    #47
    Slimwood Shady
    Slimwood Shady [OP] I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    I figured it out that my cam bolts were not torqued enough....:rolleyes: damn firestone!
  8. Aug 18, 2012 at 5:25 PM
    #48
    no mods
    cincinnati
    Some stickers
    Good deal.. the bushings are a kick in the dick to change.
  9. Aug 18, 2012 at 5:27 PM
    #49
    Slimwood Shady
    Linwood
    Hampton, VA
    Yeah I saw boyd's posts when he was changing his...smh...I was contimplating just buying TC LCA instead of swaping them :anonymous:
  10. Aug 21, 2012 at 9:52 AM
    #50
    no mods
    cincinnati
    Some stickers
    Yes that my recommendation. My bud has similar issue and went w the OEM length Tc lcas. I can vouch they top quality.
  11. Aug 21, 2012 at 4:08 PM
    #51
    Slimwood Shady
    Linwood
    Hampton, VA
    But other than durability, what do you gain with them?
  12. Aug 21, 2012 at 4:16 PM
    #52
    XXXX
    sKiP
    05 Prius
    a shit ton less money in your wallet. actually better response due to real bushings not POS rubber ones.
    wait for these to be tested and marketed. supposed to be much less money then TC. and I would wait good and long for them to be tested. by the time my next set of bushings seize up they should have plenty of beatings on them for me to decide who to go with.
    http://www.tacomaworld.com/forum/suspension/200644-mid-travel-bs-thread-272.html#post5568513
    hopefully by then TC will reevaluate their pricing and lower it due to competition. until now they have a monopoly and their pricing reflects so IMO.
  13. Aug 23, 2012 at 11:42 AM
    #53
    no mods
    cincinnati
    Some stickers
    Yes they are expensive ...
    This is how I ended up going LT ,couldn't justify price of new arms just for a better design.
  14. Aug 24, 2012 at 5:38 PM
    #54
    stuart1996t100
    stuart1996t100 New Member
    stuart
    san diego
    96 4wd T100 longtravel
    deaver, king, built right, fuel safe, dj safety, crown performance, hanneman, general grabber, speedway engineering, willwood,
    I recently had to replace my LCA bushing because of extensive play and noise, I called around and found an aftermarket upgrade. instead of the crappy rubber the factory bushing are made off, I got the polyurethane bushings and it drives so much nicer. took me a couple hours to do but not to bad.
  15. Aug 24, 2012 at 5:40 PM
    #55
    OZ-T
    Peter North
    British Columbia
    Link?
  16. Aug 24, 2012 at 5:40 PM
    #56
    no mods
    cincinnati
    Some stickers
    On 05+?
  17. Aug 24, 2012 at 5:48 PM
    #57
    no mods
    cincinnati
    Some stickers
    Looks like he owns a 96 not 2006.. not even comparable
  18. Aug 24, 2012 at 5:49 PM
    #58
    OZ-T
    Peter North
    British Columbia
    ah so
  19. Aug 25, 2012 at 7:22 PM
    #59
    stuart1996t100
    stuart
    san diego
    I have a 96 T100 but i recently purchsed an 05 tacoma as a failure driver, when i got it i started doing all the maintaince that had been Neglected by the previous owner , i replaced my power control arm bushings as needed with the polyurethane bushings, it was easy to do, very well priced up grade and my Truck derive better than before, so yes if you need to replace your lower UCA bushing i highly recommend you upgrade to the polyurethane instead of replacing them with the factory rubber bushings, i got them from The Truck Shop in Sam diego talk to James, the shop number us 858-408-0314
  20. Aug 25, 2012 at 10:08 PM
    #60
    no mods
    cincinnati
    Some stickers
    If u dont mind me asking how did u get old bushings out?
    When I had OEM lcas It took me over an hour hour just getting the old out.. then to reinstall I spent another hour driving around looking for someone w a 50 ton press that was willing to even try to put it it back in. Not even considering the time for removal and install of arm itself
