LCE big brake kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grousehunter 12, Aug 1, 2012.
  1. Aug 1, 2012 at 7:29 AM
    Grousehunter 12
    Grousehunter 12 [OP] Well-Known Member
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    Tundra brakes on front
  2. Aug 1, 2012 at 9:26 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Are you hauling/towing or lifted with large wheels and tires? Is that why you want a big brake kit? Just curious.
  3. Aug 1, 2012 at 10:45 AM
    Grousehunter 12
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    Tow boat over mountains of Ky. & Tenn.,truck is a stock 2002 SR5 V6 TRD Off Road with 98K and untouched brakes and it's time to replace the front ones, dealership just replaced ball joints under a recall and undercoated the truck they also inspected the truck and rated the rear brakes at 90%,which leads me to suspect that it's been awhile since they worked. That kit is not a true Big Brake Kit,it's a Tundra brake system that was on Tundra's until 2003,I think.Replacement cost for the Tacoma brakes or Tundra system is about the same.The Tundra system has bigger rotors,bigger calipers with 4 pistons that are also bigger than the two smaller pistons in the Tacoma calipers.The line and bracket kit from LCE makes this a "plug & play" replacement.
  4. Aug 1, 2012 at 2:26 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Might be cheaper to get the tundra parts used and then order the brake lines, your choice of rotors, etc.
    Oh and you need at lest 16" rims to fit the tundra parts.
  5. Aug 1, 2012 at 2:48 PM
    Grousehunter 12
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    It would be. I don't mind paying extra for new parts as long as they do what they claim,I'm thinking Brembo solid rotors,Autozone's rebuilt calipers which have a lifetime warranty,with LCE's line & bracket kit with their Hawk LTS pads.As you can guess from my screen name I go places that drilled and slotted rotors shouldn't. Truck came off the showroom floor with BFG 265/70/16R RUGGED TRAIL T/A's.
  6. Aug 2, 2012 at 12:02 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
    Where are you getting the brembo rotors from?
  7. Aug 2, 2012 at 1:48 PM
    Grousehunter 12
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    Not sure, most online brake supply houses carry them and if you purchase so much shipping is free.
