LCE Electric Fan Kit - 2TR/1GR (05-09 Tacoma)
Discussion in '4 Cylinder' started by 08pretaco, Oct 13, 2010.
  1. Oct 13, 2010 at 12:12 PM
    08pretaco
    08pretaco [OP] IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I went over the DIY from either the member here or on TN and decided this winter to tackle an electric fan switch! Was looking over his install and seemed very tedious and just stumbled across this!
    http://www.toyotacatalog.net/M1WebG...UniqueID=D77E2B8D-E400-4221-AACA-AE550FFCEF30
    This seems like it will make the switch so much easier!
    Is the fan big enough? Is the airflow good?
    If anyone has any insight or a good place to further look for components to fullfill this task I am all ears!
  2. Oct 13, 2010 at 12:54 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    How much of a performance gain do you guys think you can get from this?
  3. Oct 13, 2010 at 1:15 PM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    i asked them about this says the gains are around an intake or exhaust ~ 5 hp
    which isnt bad for the 4 bangers, we can take anything we can get :)
  4. Oct 13, 2010 at 1:17 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    oliver i am interested in this and would like to help w install
  5. Oct 13, 2010 at 1:17 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It's nice if you have $375 lying around haha...maybe I'll do it one day.
  6. Oct 13, 2010 at 1:25 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup
    A few bolts are different.
    Thats a flexalite kit, not made by LCE. flexalite part number is 678. I can get you one for about $371.99 to your door...
    :cheers:
    edit: link
  7. Oct 13, 2010 at 1:36 PM
    08pretaco
    Oliver
    az
    ^thanks for the link!
    For you local guys ill keep you updated with the install...the more there the better!
    I personally would be happy with some power from this but really want to do this more for hopefully letting the engine relax a little more and if power follows that's a plus! My 4 banger works pretty damn hard and I feel he would like this!
    Any more links and posts for me to look into are always appreciated!
  8. Oct 13, 2010 at 1:53 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    how about you go to a local junkyard and pull out a thunderbird fan like i did and i'll just sell u the bracket i made then you go to autozone and buy a fan controller and radio shack to round out the goodie bag and you do this switch for under 200:) and you can even add a switch to kill it if ur ever in mud or water and a little indicator light so you can know when it kicks in
  9. Oct 13, 2010 at 2:04 PM
    08pretaco
    Oliver
    az
    Thats why i posted! Can you post some pics when you get a chance of your setup inside the bay and then post up some more info on your bracket and what your using and a controller and whatnot!
  10. Oct 13, 2010 at 2:19 PM
    revhappyleon
    Manny
    Tampa near macdill
    it's a bracket i made out of some 1/8" flat bar and painted red. I't bolts onto the stock points for the shroud and the fan slides down into and then mounts to the bracket. you can use this for a controller from jegs http://www.jegs.com/i/Flex-a-lite/400/31147/10002/-1 and use two 30 amp relays from radioshack. . . now for the downsides, you need at least a basic amount of electrical knowledge just enough to make the connections with crimp connectors and this is a big stinkin fan it's for the 4.6 v8 so you could go with a smaller fan and only need one relay and we could work something out for the bracket. you send me the cash to go pull out the fan at a junkyard and i build you a bracket(don't worry no nigerian princesses in need of financial assistance)
  11. Oct 13, 2010 at 2:22 PM
    revhappyleon
    Manny
    Tampa near macdill
    i recently sat a a border crossing from mexicali to calexico for about an hour with my windows up and my a/c on with no problems . . . it was 105* outside:cool: so yeah it moves enough air lol
  12. Oct 13, 2010 at 2:24 PM
    revhappyleon
    Manny
    Tampa near macdill
    better idea i'll do a swap on a friends truck and make two brackets and send you one bcuz i'm not sure if the L4 and V6 radiators are the same
  13. Jan 23, 2011 at 5:37 AM
    michaelg589
    michaelg589 Well-Known Member
  14. Jan 23, 2011 at 7:43 AM
    08pretaco
    Oliver
    az
    Well I ended up getting a p/t job to help fund some mods and life....which did not include the electric fan. I will do the electric fan mod but probably wont be till the summer :D
