Leaf recommendations
Discussion in 'Suspension' started by ToyotaZaBest, Sep 15, 2022.
  1. Sep 15, 2022 at 4:17 PM
    ToyotaZaBest
    ToyotaZaBest [OP] New Member
    2015 Tacoma TRD
    Hey I got a 2015 DCSB. I’m going to be installing BP51’s all around. I will be purchasing a cap for the back (around 200lbs), other that only occasionally loaded bed of gear, like for trips.
    I’m looking for suggestions for a leaf pack 2-3 inch of lift. So far I’ve been told the ARB MD and HD ain’t the greatest.
    Any recommendations? Thanks guys
  2. Sep 15, 2022 at 4:28 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    http://nationalspringinc.com/
    They will make you whatever you want.
    Over 150 years in the business.
    Good luck with your truck.
  3. Sep 15, 2022 at 5:02 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
  4. Sep 15, 2022 at 9:46 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Dobinsons, Deaver or icon rtx.
    Sna, Mattynokes and clenkeit like this.
  5. Sep 15, 2022 at 10:09 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Deavers, either stage 1 or 2. I love the ride of the stage 1’s on my 3rd Gen.
  6. Sep 16, 2022 at 11:42 AM
    TacoSurfer27
    TacoSurfer27 Active Member
    Colin
    11' TRD Sport AC 6speed
    Toyotec boss kit in front, diff drop, dura bumps, tuff country UCA’s Rear: icon RXT’s stage 2. Fox 2.0 remote reservoir adjustable shocks. Dura Dumps w/U-Bolt flip kit. Archive Garage Hammer hangers Reverse lights: HID 921 Osram, 860 lumen mod. ARB differential breather kit. KC halogen spots x2, and floods x2 leer 180. Sony 6x9 speakers + tweeters. Alpine head unit with amplifier
    I'm in the same dilemma . I've got leer 180 and full size spare.Figure it's about 250lbs.. gunna add slider once I get new frame after the winter. . Can't decide between stage 1 or 2 deavers
  7. Sep 16, 2022 at 11:44 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This thread has been posted 50000x times.. That said, Deaver u402 or Icon RXT if you're going to be adding weight. Having had both brands, Deavers ride nicer.
  8. Sep 16, 2022 at 12:01 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Darnit, lol. I was shopping these two and wasn't sure which to pick so just jumped on the first, decent deal that popped up - which was the RXT. I'm sure they'll be fine and they seem to pop up used a lot more than the Deavers.
    drizzoh[QUOTED] likes this.
  9. Sep 16, 2022 at 12:10 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Icon RXT optiion 2 with your weight will put you just over 2" but being that they allow for additional droop you'll want extended travel shocks.
    drizzoh likes this.
  10. Sep 16, 2022 at 12:17 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Haha they are fine, just extra stiff if you have no weight (little bit of false advertising on Icons part IMO). I would recommend swapping out the shackles at least with a greaseable version when you do the install. They are noticeably smoother thru the leaf's operation than the factory shackles that bind. I run the BAMF's but there are a few options.
    clenkeit[QUOTED] likes this.
  11. Sep 16, 2022 at 12:20 PM
    clenkeit
    Colin
    Lakewood, CA
    Ha, stiff is exactly what I didn't want - overall, I'd prefer as cush of a ride as I can get. But beggars can't be choosers.
    Thanks for the tip on the shackles. I'd been thinking about whether I wanted to address the shackles or not. From your experience it sounds like it's worth upgrading the shackles without doing all out with a hanger upgrade?
  12. Sep 16, 2022 at 12:22 PM
    tymebandit951
    tymebandit951 Well-Known Member
    Boise, ID
    2013 4x4 DCSB
    I’ve had OME springs in my truck in the past and not a fan, big fan of the deavers I have now. I went with stage II, wish I would have gone with stage I but they are awesome still.
  13. Sep 16, 2022 at 12:24 PM
    TacoSurfer27
    Colin
    How much rear load do you have? That you wish you went with 1s?
  14. Sep 16, 2022 at 1:05 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Yeah weighted the RXT's ride pretty nice (unweighted they are excessively harsh), the shackles are like upgrading control arms to beefier ones - simply swapping them out isn't as drastic as doing full hangers, but they are worth upgrading while the leaves are out of the truck since you have to remove the leaf packs to change them. I put a little blurb about them in my build thread here if interested.
  15. Sep 16, 2022 at 1:40 PM
    clenkeit
    Colin
    Lakewood, CA
    I guess I'll just have to see how it goes for me. I'm at 24" (+/-0.25") from axle center to fender currently and don't want to go any lower but wouldn't mind if it's a tad higher. So far seems like Stage 2 is the best option for me. I only keep around 50-100lbs in the bed normally (but truck also has sliders and skids) so I expect it'll be pretty harsh like that based on your feedback. But it doesn't get much use like that since it's not a daily driver. Most of the miles it sees are for camping/exploring trips where it gets more loaded down. I'd think at least a few hundred extra pounds with all that gear.
    Thanks for the shackle/hanger info as well. I'm definitely thinking these are worth it. I'd just like to see if I can find a better deal. The BAMF setup seems fairly reasonably priced, not sure I could justify the cost of the Archive setup. BAMF and Rago are more moderately priced and I feel like there was one other brand available now but I can't remember.
  16. Sep 16, 2022 at 2:11 PM
    tymebandit951
    Boise, ID
    2013 4x4 DCSB
    I have a leer topper and decked drawers all the time(probably 225lbs combined) then I’ll often add ice chest, gear, etc. Between my archive hangers and the deavers my rear is a little too high, and I didn’t really need all the weight support of the stage II.
    TacoSurfer27[QUOTED] likes this.
  17. Sep 21, 2022 at 12:15 PM
    Sleddog0311
    Sleddog0311 Active Member
    Black 2020 DCSB TRD OR
    Barricade HD rear bumper, Cali-raised smoked rear LED lights, Black Rhino (Chamber) black 17x8.5, 0 offset, 4.75 backspace wheels, Toyo Open County AT III 275x70R17
    This has been very informative in helping me decide between the Stage 1 & Stage 2.........thanks
  18. Sep 21, 2022 at 12:23 PM
    TacoSurfer27
    Colin
    @tymebandit951
    You say a little higher than you'd like? What are you shooting for for height? Rake , no rake? Any pics of your rig?
  19. Sep 21, 2022 at 7:05 PM
    tymebandit951
    Boise, ID
    2013 4x4 DCSB
    Truth be told I don’t have a specific height in mind, just by look. I’d say no rake is preferred, and my front isn’t lifted lots so the rear sticks up too high for my preference. SUA will fix that for me no problem. You can see my build here…
    https://www.tacomaworld.com/threads/tymebandit951s-1-step-forward-2-steps-back-build.389082/
  20. Sep 21, 2022 at 7:42 PM
    tymebandit951
    Boise, ID
    2013 4x4 DCSB
    No problem. I do think it’s worth noting that it’s my preference of look and that I’d still stick with the weight recommendations of deaver obviously. But unless you’re going to be loaded to the gills with a full broverland setup all the time you’re probably good with stage I.
