leaf spring bushing
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmcbride2012, Jul 1, 2013.
  1. Jul 1, 2013 at 6:10 PM
    jmcbride2012
    jmcbride2012 [OP] wheelin and dealin
    Jordan
    00' 4wd 5-spd Reg cab
    4" suspension lift leveling kit bilstein 5100 rear shocks
    I own a 2000 toyota tacoma 4wd , i am replacing my sqeaky leaf spring bushing. i already bought new bushings for it but i need the bolts that hold them in (shackle pins?). I cant seem to find just the bolts/pins anywhere.
  2. Jul 1, 2013 at 6:12 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    You sure the squeak isn't from just the leaf springs rubbing? Most of them have an anti friction pad between the leafs, generally doesn't allow it to squeak.
  3. Jul 1, 2013 at 6:22 PM
    jmcbride2012
    Jordan
    well i can feel the vibrations coming from the front of the leaf spring where the bushing is at. i did oil the whole area just to see if it would fix it but it didnt
  4. Jul 1, 2013 at 10:56 PM
    james
    james In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    :popcorn:
    here we go (again).
    I doubt it's the bushing, but you can lube it up with some Lithium grease and test your hypothesis. If you need some paid advice, call Dan over at Wheelers Offroad and have him fix you up with a new OME shackle set (greasable). Everything you need is in there. Run your issue past Dan - it can't hurt - and he's seen it all...
