leaf spring question, again....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Dec 16, 2009.
  1. Dec 16, 2009 at 5:36 AM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    but this one is a little different from all the other threads.
    When I was looking for a used rear leaf they told me it had to be 95-97 standard cab, and left and right sides were different...
    I found a set of used springs... but they are off an extended cab. Does anyone know if they will work on my standard cab?
  2. Dec 16, 2009 at 7:26 AM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    used ?
    is this the type of part you want to buy used?
  3. Dec 16, 2009 at 7:28 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Hahhahaha.... have you seen my truck???? :D
  4. Dec 16, 2009 at 7:46 AM
    gofas
    Russell
    Ukiah
  5. Dec 16, 2009 at 8:23 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I got pics posted in my re-build thread. there is a link in my sig, "black Beater"
    I found a set online $215 shipped for a pair, 4 leaf pack.
    I am looking to save some. The used ones I found were used for a lil over a year, and they are a lift spring. If they are not sagging, cracked or twisted up, I think they are worth $90obo. I hate to spend the extra on new ones.
  6. Dec 16, 2009 at 8:32 AM
    gofas
    Russell
    Ukiah
    ah C,,
    the lift is what's up.
    well when looking/shopping for leaves i don't see them ask for extedend cab or regular cab. so I would think they are the same. but, I might not know what the heck I'm talking about. hopefully you will get solid answer on your question so you can purchase in confidence.
    I'm new to a lot of this and that is why I was curious about buying used leaves. my leaves and coils have 175, 000 miles on em. So i'm thinking they will need replacing. if i knew they were ok. I would just buy new shocks. But I think i'm getting the lift bug the more I read over this site.
  7. Dec 16, 2009 at 9:03 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I think the extended cab leaves will work
  8. Dec 16, 2009 at 9:56 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    a member on TTORA said the 97's had shorter leaves. The ones I found are off a 99.
  9. Dec 16, 2009 at 10:00 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
  10. Dec 16, 2009 at 1:46 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    My springs are 51" Any idea what years will work for sure with my truck?
  11. Dec 16, 2009 at 10:19 PM
    gofas
    Russell
    Ukiah
    I got under my truck tonight and measured from one end to the other of my leaf and got 51". as well.
  12. Dec 17, 2009 at 12:29 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    95.5-97 springs are interchangeable within the same years, while 98-04 springs are interchangeable within the same years, BUT they are NOT interchangeable between the 2 sub-generations. For example, springs from an 01 will not be swappable with springs from a 96 because springs from the 95.5-97 will be shorter than those from the 98-04. Reg. cabs, extended cabs all used the same leaf packs IIRC.
  13. Dec 17, 2009 at 3:30 AM
    johneman
    johneman Life is good!!
    Ken
    Warwick, PA
    2007 AC 4X4 2.7L 5 speed SR5
    Weston tube steps, EXtang Black Max tonneau cover, Wet Okole's, Front WeatherTek mats
    If I had the lean with the 3 leaf pack it was not noticable. Just had the spring TSB done and It isn't noticable but after reading this I'm going to measure it out and see if it's even. Had no problems at the dealer getting the TSB.
  14. Dec 17, 2009 at 5:14 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    You had 51" as well??? WHat year is yours? Xtracab or regular?
    It appears to me that the front spring mounts have been rewelded to the frame of my truck, so I am thinking somewhere along the line the springs have been swapped to the newer (98+) style.
  15. Dec 17, 2009 at 5:55 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    re welded?
    how long are yours
  16. Dec 17, 2009 at 6:28 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Mine measure out at 51"
  17. Dec 17, 2009 at 7:20 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    then they are 95.5-97s
    right?
  18. Dec 17, 2009 at 8:44 AM
    gofas
    Russell
    Ukiah
    i have the 96 extended cab truck!
  19. Dec 17, 2009 at 8:54 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Ummmm, the dude has a 1st gen not a 2nd gen.
  20. Dec 17, 2009 at 10:13 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Could someone with a 98+ please measure your springs???? Please????
