Leaf spring question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rozz, Feb 3, 2011.
  1. Feb 3, 2011 at 5:18 AM
    Rozz
    Rozz [OP] Well-Known Member
    Sturgis, SD
    '98 TRD SR5
    Toytec/Eibach 3" coils, 5100's front shocks, Light Racing UCA's, Allpro 3" leaf springs minus 2 leaves, 7100 SB rear shocks, 15x10 slots, Yokohama Geolanders 32x11.5 tires, 4 runner seats
    When I bought my truck about three years ago, the PO had just replaced the leaf springs, now I'm trying to figure out which ones for shock length purposes. Do you count the overload spring in a 4 leaf vs 5 leaf spring pack? Mine have 4 leaves plus the overload spring. Thanks
  2. Feb 3, 2011 at 5:58 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    take measurements from the center of the mounting points at full stuff and at full droop. then you can search out the specific shocks you need based on those measurements.
    i think the standard 5100 bilisten shocks that all the vendors sell will work with lifts up to 3"
    http://www.wheelersoffroad.com/9504tacoadjbils.htm
  3. Feb 3, 2011 at 10:33 AM
    Rozz
    Sturgis, SD
    '98 TRD SR5
    Thanks, I'll try that, though I'd still like to know if mine are considered 4 or 5 leaf springs.
  4. Feb 4, 2011 at 5:42 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    i've never really thought about it. ....but i assume the overload is included in the leaf count. ..so a 4 leaf is 3 leafs + the overload. 5 leaf is 4 leafs + overload. ...someone may want to verify that though.
  5. Feb 5, 2011 at 8:20 AM
    Rozz
    Sturgis, SD
    '98 TRD SR5
    Alright, it is 4 leaves plus an overload for a 5 leaf pack.
